http://www.sperrling.no/
Alta 17 fra Sperrling ville jeg ha forsøkt! Helt passiv,og med 17 innganger.Dvs,om du ikke har ting i effekttrinnet du vil ha "justert" på.
Dette er informasjonen:
ALTA 17, STEREO Control-Unit
- This unit offers multiple inputs and a complete control-centre for multi-amping and the large number and varying types of signal-sources in ultra-high-quality modern STEREOPHONIC sound-systems.
- It is passive without the totally unnecessary active electronics that, in fact, can in reality only deteriorate the signal- and sound-quality! The up to about 2 V output-level from most common CD-players etcetera, is more than sufficient to drive the vast majority of all power-amps, and that even to the clipping-level!
- It has 12 ordinary line-inputs and another 5 monitorable inputs also suitable for recordable signal-sources and equipment like tape- and cassette-recorders, Computers, DVD- and MD-recorders, etcetera. But N.B. - You can also use these inputs just as another group of 5 line inputs so in reality the ALTA 17 is creating and offering You a total of 17 line inputs!
- It solves in an elegant way, the all too common lack of inputs that users often suffer when they want to connect more sound-signals, as from their PC, DVDs, TV, MP3-player, cassette-players, FM-tuner, SACD, DVD-Audio, etcetera.
- It is also a great relief to get rid of the last bit of noise and distortion and limitations that active pre-amps more or less ALWAYS introduce!
- It also offers You 4 extra sub-volume-controls, so that You can set up that professional multi-amping, You may have been dreaming about - as well as conveniently regulate all the levels of the treble, mid, bass and sub-bass level from a distance and at one and the same control unit, or set the level of our exclusively genuine Sperrling Sound-Around System.
- We also have included a direct output from the Main-Volume Control; so in reality You have in fact 5 pair of out-puts from the ALTA 17 control-unit!
- The lay-out etcetera is also made very practical and logical with different sizes of the input switches, Main and Sub-Volume control knobs. The main line input switch also has its 12 inputs numbered just as the positions on a clock.
- The rear panel is filled with the impressive number of in total 46 gold-plated RCA-connectors and we hope that it will be satisfying for the out-most needs!
- Level-adjustment is made with the finest available potentiometers that gives exactly equal level between the Left and Right hand channels also all the way from the lowest settings at the very, very beginning of the volume-controls!
- The R Record - Output presents a signal directly coming from the input-switch and You can simultaneously listen to any of the signals present at the A to E inputs of the T-switch at the same time as You are making a recording from any one of the number 1 12 Line-inputs.
- A combined stereo and 5.1 version is also available - ALTA 5.1/2.0 - offering 5 discrete analogue 5.1 inputs AND 5 ordinary stereo inputs in the same unit. In the stereo-mode simulated multi-channel signals can alternatively be sent to ALL surround-channels. So that all power-amplifiers and loud-speakers in a 5.1 set-up; i.e. also sub-bass-, centre- and rear channels, are used together with the left and right front channels to add extra ambience, timbre as well as low bass and front focal perspective to Your stereo-sound and greatly enhances the musical experience and exchange You can get! The main 6-gang volume-control can be remote controlled; although the pre-amp is all passive - and is supplied either by internal batteries or a small external battery-eliminator!
Mvh Rune
