Nyhet fra Lumin - U1 Mini
Lumin lanserte i dag nyheten om en rimeligere utgave av sin U1 streamer som kommer uten DAC.
Denne minimodellen koster 25.990,- og det gis 15% frem til 22 september på denne også.
Vi gir gode innbyttemuligheter ved oppgradering av din eksisterende Lumin!
Why LUMIN U1 MINI
Following the huge success of LUMIN D2, we decided to investigate the possibility of making the LUMIN transport technology similarly accessible.
The result is a huge specification in a compact package.
Capable of upsampling and downsampling all the way from 44.1kHz to DSD128 and supporting playback of DSD256, LUMIN U1 MINI matches the U1 in almost every area - except price.
Transport-only unit combines the best of LUMIN U1 and LUMIN D2
Identical processor supports DSD256 and 384khz playback
Quad native clock system for precision timing
Low noise shielded switching power supply
5 types of digital audio output including USB
MQA Decoding
Resamping to every supported format up to DSD128
Supports DoP (DSD over PCM) for Optical, Coaxial RCA, Coaxial BNC & AES/EUB SPDIF
All the usual LUMIN refinements
From MQA to DSD, FLAC to WAV, LUMIN can play all the high-resolution formats you could ever want
Native support for TIDAL, Qobuz, Spotify and AirPlay, giving you access to tens of millions of songs
The unique and intuitive LUMIN App described as "the most convenient interface in existence" by Tinman
LUMIN programme of continuous development that has seen Roon, MQA, and Spotify support added in 2017 alone.
Tom Egil
tom@endpoint-audio.com
47832922
MusicBear
Seriøs streamer uten DAC - genialt!
Aukjsoneres den bort, byr man på den, setter man prisen på den selv, annet? Jeg spør, i og med at den ikke har noen salgspris...
Distinctive
Absolutt interessant, selv om SMPS bringer frem skeptikeren i meg.
Noen rykter om en kommende X1 mini over samme lest?
Endpoint Audio
Tønsberg
Nei,
Lumin er ekstremt dårlig på rykter...
Det sies at de har en meget god smps, og dette er laget for å få en rimeligere utgave av en high end enhet. Ps delen er i tillegg ekstra skjermet.
MusicBear
Nei,
Høres bra ut - alt sammen - er den allikevel uegnet som salgsartikkel for å beheftes med en antagelse av pris? :)
Endpoint Audio
Tønsberg
Jeg redigerte innlegget i dag morges til å inneholde pris. Men jeg kan gjenta her at den koster 25990,- men selges med 15% avslag frem til den 22 september.
Distinctive
Hadde jeg hatt en anstendig DAC (som jeg har) hadde U1 mini absolutt vært på innkjøpslista hvis jeg hadde trengt en god streamer i klasse med den jeg har nå.
I tillegg tror jeg min A1 må være i nærheten av det mest stabile apparatet jeg noengang har hatt i hus.
Bortimot fullstendig trøbbelfri uavhengig av oppdateringer.
Hi-rex
Etne
Nu begynder det at ligne noget, der ser fornuftig ut, i realization til Kost, kvalitet, osv.
MusicBear
Jøss, da snakker vi, sånne summer er betalbart!
Håper du får en sånn en ut til test, spesielt fordi mange mener god streaming er Naim til rundt 100 lapper eller mer, noe jeg ikke tviler på, men som gjør den du nå viser frem til et mulig svært så spennende alternativ.
Prebs
Hvordan er denne opp imot Lumin D2 lydmessig?
Endpoint Audio
Tønsberg
Jeg har ikke hørt U1 mini, men U1 har vært i særklasse som streamer. Når de nå har tatt så mye fra U1 og lagt denne inn i en mindre boks og droppet analogdelen så regner jeg med at dette er en killer hvis man allikevel har en god dac og ikke har behov for analog ut.
D2 er Lumins rimeligste streamer og har en innebygget analogdel og en enkel digital ut mot U1 mini som har 5 digitale utganger og ingen analoge.
Billa
Hei Endpoint, kan denne tilknyttes intern SSD harddisk eller lese fra minnepinne?
Er den egnet som "harddisk avspiller" i tillegg til streamer?
Endpoint Audio
Tønsberg
Hei den kan lese fra ekstern disc som man kobler til USB.
INPUT:
Ethernet RJ45 network 1000Base-T Gigabit
USB storage, flash drive, USB hard disk (FAT32, exFAT, NTFS and EXT2/3)
Endpoint Audio
Endpoint Audio sine annonser
Canor Audio hos Endpoint Audio
  • 1
Jeg er veldig fornøyd med å kunne re-introdusere Canor for det norske markedet, og gir i den forbindelse 15% avslag på alle produktene en kort periode nå i begynnelsen av april. Canor Audio har...
Lockwood Loudspeakers hos Endpoint Audio
  • 3
Jeg er meget fornøyd med å introdusere Lockwood for det norske markedet. Etablert i 1930, Lockwood har vært en av de mest foretrukne monitorer med over 1200 plateinnspillinger på ryggen. Så...
Innbyttekampanje! Oppgrader til Lumin U2 - Eller få 15%
Ønsker du å oppgradere til en av markedets beste streamere? Lumin U2 har oppgradert prosessor, dedikert Low Noise USB til DAC utgang, all-in-one chassis, fiber nettverk, OG lineær...
God Jul til alle!
God Jul til alle!
  • 9
Jeg ønsker alle en riktig God Jul, hvor kanskje både harde og myke pakker er det minst viktige. Det skjer såpass mye galskap i verden i dag, at den beste gaven vi kan gi er medmennesklighet...
EMT 912HI - Test.
EMT 912HI - Test.
EMT lanserte i 2022 nye utgaver av de legendariske tonearmene EMT 929 & 997. Disse er vesentlig oppgradert i forhold til forgjengerene og det legger man merke til med en gang man tar de ut av...
10/10 For Lumin T3
10/10 For Lumin T3
  • 1
High End streaming blir stadig bedre, og Lumin leder an med superb lydkvalitet og brukervennlighet. Alltid blant de første til å implementere nyheter - og de første som fikk på plass Tidal MAX...
