NYHETER - platespillere
  • Hønndjevelen
    American Sound, «The Absolute Nothing»
    Med en old school SME arm
    Me like
    Grumpy
    Odyssey
    fra BennyAudio blir vist for offentligheten første gang under Munchen 2024
    In production: 2023 (prototype), 2024 Official
    Dimmensions: 242 (H), 400 (W), 400 (D)
    Dimmension with one tonearm: max 230mm + regular W and D
    Weight: 59 kg (without tonearm)
    Number of tonearms : Up to 3 tonearms (4 mounting points)
    Isolation feet: Stainless steel with ceramic insert (8 total)
    Tonearm weight: 0,52 kg (14 inch)
    Base weigth: 1,5 kg
    Length: 9 to 14 inches
    Headshell: Carbon Fiber (4,7g), Titanium (14,9g)
    Effective weigth (14 inch): 18g (Carbon fiber headshell) - 31g (titanium headshell). Final effective weigth depends on cartridge used
    Power supply: ULPS DC power supply
    AC input voltage : 110V or 220V (set by switch)
    DC output voltage : 12 VDC
    DC wire and plug : 2 wire cable, GX16 plug
    Rotational speed: 33.3 rpm and 45 rpm
    Motor: 1 BLDC, 3 phase, 8 pole 20W
    Motor mount: External steel case
    Speed guidance system: Continuous open loop feedback
    Sensors type: Motor HALL Sensors
    Correction cycle: Every 1 rotation(corresponding number of HALL sensor pulses)
    Speed Monitoring: HALL Sensor counting VS time
    Correction steps: 16 steps set on front panel
    Drive belt: 1 VMQ belt , 3mm diameter
    Additional features: Soft start (<20 seconds), soft stop, last speed save, auto corrections, 13 back light colors, 6 step dimmer
    Wow&Flutter : 0,07% (best run measured and saved on IOS RPM Speed app)
    Upper platter: Delrin, black, 300mm dia 5 kg
    Mid platter : Stainless steel, 300m dia 8 kg Lower platter: Stainless steel, 200mm dia, 4 kg
    Main bearings: Hydrodynamic inverted sleeve and ball (aluminium alloy, PEEK sleeve)
    Shaft type: 15mm hardened stainless steel
    Ball type: YG8 10mm sintered carbide
    Lubricant: High viscosity synthetic oil, oil refill from top of the platter
    PROTOTYPEN fra 2023:
    God design (må være i sort dog...) - i motsetning til forrige innlegg - den spilleren innehar en soleklar ledelse på min "Most tasteless" liste...
    Grumpy
    ...hvit Odyssey tilhører nok pikerom :LOL:.
    Riktignok kan man få hørt den på en førpremiere i morgen om man er i Sopot, Polen. Stikk i såfall innom Premiumsound i Niepodległości 645 B :coffee:
    Origin Live Renown. £ 25000 eller så. Launch på Münchenmessa.
    ou812rh
    HiFi, humle, malt & sykkel
    Der det finnes okser i Oslo
    Building the world’s finest analog playback system required the world’s most revered turntable designer: Helmut Brinkmann. With Apollo, he has been given the opportunity to create his “Dream Turntable” without compromise. Apollo utilizes two of Brinkmann’s proprietary Sinus™ Belt Drive Motors, placed 180-degrees from each other. While the benefits of multiple motors are well-known, overcoming the potential problems of dual motor design required a great deal of ingenuity. Not only is Apollo Helmut’s first multi-motor turntable, it is also the first ‘table for which he developed a digital speed controller. In addition to synchronizing the two motors, Apollo’s controller is more accurate than analog equivalents and will never require calibration; at the same time, Brinkmann’s techniques for “Soft” motor control, painstakingly refined over more than 40 years, further distance Apollo’s speed controller from those of other turntables.
    Balle Clorin
    Kan jo være at det blir blir da.., ;) Alt avhenger av beltet
    Balle Clorin
    Og den -125- spiller antagelig bedre også
    superhkm
    Jeg hadde neppe valgt bronse selv.
    Hvis det faktisk er bronse, hadde jeg valgt bronse. Men det er neppe tilfellet.
    Med tanke på hvor mye det visuelle skal ha å si for vår opplevelse av lyd - ja , 125 låter sikkert bedre.
    Reaksjoner: abl
    Steen
    bia
    Hvordan målte middagen i dag?
    Interessant, men det høres tungt ut?
    Steen
    Stift og lett ville jeg vel sagt. Med tanke på at hi-fi industrien allerede bruker slikt materiale til diskantelementer.
    Tipper relativt tungt. 9-tommeren i stål med fast hode er 19 g, og den med avtagbart hode er 28 g inklusiv hode. Korf driver ikke med lett men stivt. Det eminente alumina-armhodet er 13 g. Prototypen på det var 9 g.
    Trondmeg
    Det var ikke vanskelig å se. Knottene avslørte det. Personlig liker jeg nok originalen best med den lyse topplaten, men kassen er finest i tre.
    PeriodeLytter
    Ser ut som 2M Bronze/Black-generatoren i Concorde-hus:
    Tørr man seg på noe slikt da?. Ser jo ut som discotekverktøy. En dag så har poden med seg hjem besøk av "Whanna be DJ" og hifi nålen er knekket på første scratch.
    Man har selvfølgelig en Red-nål som sitter på når far ikke skal være audiofil med Black LVB-nålen sin!
    Ellers synes jeg at du har et poeng designmessig. Man tenker Technics 1200 tvert. Lenge siden Ortofon og SME koplet ihop Concorde-designet og 3009 Series III.
    Reaksjoner: KJ
    Det ser ut som det er noen forskjeller i spolene. Den nye Concorden har litt høyere motstand og induktans, 1k27 ohm, 815 mH og 6mV ut sammenliknet med 2M sort som har 1k2 ohm, 630 mH og 5 mV ut. Opphenget på den nye concorden er også en del stivere.
    Litt mer følsom for kabelkapasitans, bedre passende en typisk arm med bajonettfatning, og marginalt høyere utspenning, som blir ca 4 mV ved 3,54 cm/s om hodet mitt regner riktig.
    HasseBasse
    Hjortshøj, Danmark.
    Du er sikkert ikke langt fra sannheten.
    2M er i bunn og grunn "bare" LM/OM i nye hus. (Gammal vin på nye flasker).
    Er vel tidens trend??
    torem
    Du kan evt. ha en "Red"-nål til poden, og så bytter du til en "Black LVB 250"-nål når du skal spille plater selv:cool:.
    coolbiz
    Sydvestlandet
    Er Concorde Music kompatibel med OM-stiftene?
    Jeg leter på nettet uten resultat. Music er vel kanskje for ny til at noen har rukket å skrive noe om dette.
    En kan sette OM-stift på 2M så det bør gå å sette en OM-stift på Concorde Music siden den etter sigende slektes på 2M, men en vet jo ikke før en har prøvd. OM40 (FG70) er imho den beste slipingen som Ortofon har til MM-opickuper, og det hadde vært kult om de kunne sette i FG70 nål på en saffir eller bor fane.
    Uenig i remote-tanken, i alle fall som primær. Grammofoner skal betjenes på grammofonen. Dog: Kladeisen til TechDAS er ikke en vinner, og oval innramming av hastighetsviser og elliptisk innramming av modellnavn hjelper ikke på.
