Resonessence Labs Herus
About.com Stereos: "Resonessence Labs Herus DSD DAC/Headphone Amp"HERUS: Asynchronous USB Audio 2.0, 24bit 352.8Ks/S, DXD and DSD64/128, 2.4VRMS Headphone DAC
HERUS is our smallest form-factor, audiophile quality USB to Headphone DAC. It uses the USB Audio 2.0 Asynchronous protocol and supports DSD64 and DSD128 as well as high data rate PCM at 24bits up to 352.8Ks/S. It is a USB powered device that achieves more than 100dB of SNR, (typically 108dB) and is capable of driving 2.4V RMS, (ie 6.8V pk-to-pk) into headphones from 600 Ohms to 32 Ohms. The distortion in all cases is better than 0.005% (85dB): the measured THD+N is typically 89dB for 32 Ohms and 90dB (about 0.003%) for 600 Ohms.
HERUS is designed to operate with MS Windows, MAC OS and Linux. You may download our Thesycon USB Audio 2.0 driver to enable USB Audio 2.0 on Windows. HERUS uses the ESS 9010-2M DAC, our custom code, and our own asynchronous algorithms that run in a generic Cypress USB interface chip.
We use Resonessence designed, advanced power line processing circuits that can reliably deliver more voltage range than the USB provided 5V, and we maintain the SNR of the power supply to a degree such that HERUS exhibits well over 100dB of SNR at the headphone output. HERUS also has a very low 0.2 Ohms output impedance that prevents external noise sources coupling into the output.
All Resonessence products feature upgradable firmware and hardware and despite its physically small size, HERUS also contains Resonessence upgradable hardware and firmware.
HERUS is machined from a solid block of aluminum and is 63.5mm (2.5in) long, by 31.7mm (1.25in) wide and 19mm (0.75in) high. It has just two connectors: a USB type ‘B’ socket on one end and a TRS 1/4inch Stereo Headphone connector at the other end. HERUS, like all Resonessence products is Designed, Manufactured, Tested and Shipped in Canada.
HERUS SPECIFICATIONS
HERUS will enumerate to the controlling computer and register itself as being able to handle volume control internally. Almost all music player applications will then send control commands to the HERUS which it will use within the ES9010-2M DAC chip to implement high performance 32 bit volume control processing. This is significantly better than the volume control implemented in the music player software.
HERUS is easy to use: plug HERUS into a USB 2.0 (ie High Speed port) [with USB Audio 2.0 enabled if on MS Windows] and select HERUS as the output device in your system control panel. That is all there is to it…
Finally, you may, if you wish, use HERUS as other than a headphone driving DAC. For example, when driving a power amplifier you will find that HERUS is a capable and high performance system component. It is perhaps the optimum and lowest cost solution to accessing DSD music from your computer collection. Read our FAQ on this question for more information.
