Paradigm Persona 9H
    Paradigm lanserte nylig sin satsing i det øverste High End segmentet; Persona Serien. Målsetningen var å utvikle en serie høyttaler med et tilsvarende pris/kvalitetsforhold som Paradigm har blitt kjent for.
    Med toppmodellen 9H har Paradigm hatt som mål å konkurrere med langt dyrere produkter. Dette har de også klart, skal vi tro den siste omtalen i The Absolute Sound, hvor Persona 9H overgår anmelderens sine egne referansehøytalere + hans 2 dedikerte subwoofere på flere punkter. Dette er velkjente høyttalere som koster fra 860.000,- avhengig av finish. Subwooferne kommer i tillegg.
    Utdrag fra The Absolute Sound:
    "Let me begin with the conclusion. The Paradigm Persona 9H is a new assault on the state of the art in speaker design by one of Canada’s leading companies. It may cost some $35,000 a pair, but it’s one of the best speaker systems I have ever had the opportunity to listen to or review."
    "The treble and midrange drivers are also exceptional and as important to the 9H’s success as its bass drivers, power, and room correction”
    "I got better and smoother bass out of the Paradigm Persona 9H in a variety of room locations than I have with any other system that did not have room correction. Moreover, it outperformed any other pair of speakers—or pair with separate subwoofers—that did have room correction. It measured better; it did a better job with a wide range of bass warble tones; and, most importantly, it sounded better with organ, jazz, rock, and the kind of sonic spectaculars you may hate as music but can’t resist using to test your system."
    "The Paradigm Persona 9Hs not only provide the best overall bass response I’ve had in my listening room, it did so when playing back deep bass at subwoofer frequencies and loudness levels. It virtually eliminated the mountain-sized bass resonance peaks that are inevitable in most real-world listening rooms, and it filled in much of the equally deep valleys in bass response."
    "Summary — One of the best around. Highly recommended."
    Les mer om Persona Series her
    authentic
    Er det mulig å få hørt disse ?
    GSolie
    Eydehavn
    Det jobbes med saken mot flere potensielle løsninger.
    skorob
    Brumunddal
    Se der ja.. ventet på de der.. ikke at jeg har råd... men altid moro å sjekke ut noe som har vekket oppmerksomheten min så lenge :D.
    Paradigm har jo levert varene år etter år nå. Kjempespennende merke!
    Vidar Øierås
    Smart å benytte isobaric på denne måten. Det halverer kassestørrelsen, og man oppnår dyp bass likevel.
    Dette likte jeg :) Men prisen er litt overkill.
    S. Lieng
    Det er vel ikke helt standard isobaric? Bassene har aktiv drift og deles foran på 400hz og de to bak på 200Hz, om jeg ikke har misforstått veldig
    Er jo dyrt, men om disse kan konkurrere med langt dyrere Wilson, Magico etc, så er det kanskje ikke så ille likevel. Aktiv deling på basser og innebygget romkorreksjon, beryllium diskant og mellomtone kan jo bli bra resultat
    authentic
    Hadde vært morsomt å fått lyttet til slike, + for center i samme serie :)
    hifiguru
    Porsgrunn
    Tja, hva er dyrt? Sonus Faber Il Cremonese koster 390' og er ikke så langt fra bestykket, 3,5 veis etc men helt passiv og følgelig uten romkorreksjon.
    GSolie
    Eydehavn
    350.000,- er utvilsomt mye penger, men opp mot konkurrentene disse er ment å matche, er det på ingen måter galt. Vi har også priset høyttalerne meget bra i forhold til USA/Canada. Pris i USA er 35.000 USD. Med dagens kurs er det rett i overkant av 300.000,-. Men viktig å poengtere at det er uten moms. Legger vi til norsk MVA, så lander faktisk prisen 25.000,- over pris i Norge.
    GSolie
    Eydehavn
    Persona Differential Drive bassdriver
    Exploded View
    S. Lieng
    Leste testen av 9H i TAS, men finner den ikke igjen når jeg googler, noen som kan legge ut link?
    coolio
    Spennende! Jeg har sansen for at høyttalere blir mer avanserte for bedre integrering i rom. Framtiden virker lovende ☺
    authentic
    120db @ 15hz, okey det var ambisiøst !?
    Få nå innstallert disse plassert en sentral plass på østlandet så bestiller jeg en demo asap :)
    EirikV
    Etter å ha sett presentasjonen er jeg mektig imponert over denne høyttaleren. Et av de fineste designene jeg har sett, og veldig solid bygd. Superelementer. Genial konstrukjsjon med aktiv drift av bassene pluss romkorreksjon. En skal nok opp i fysisk mye større høyttalere for å kunne matche lydtrykket til Persona 9H. Denne høyttaleren kan nok bli en seriøs utfordrer til Wilson, Magico, Focal, B&W m.m, som ble nevnt av andre. Heldige er de som har økonomi til å kjøpe disse.
    Eirik.
    jarste
    Kan du si noe om forskjellen mellom 9H og 3F? Kommer aldri til å ha råd til 9H, men 3F kan være innenfor rekkevidde.
    GSolie
    Eydehavn
    Forskjellene ligger i bassen. Diskant og mellomtone er samme. Bassene på 3F er mindre og færre uten aktiv drift og romkorreksjon.
    Søsterselskapet Anthem kommer om kort tid med en integrert forsterker ved navn STR som har alt tenkelig innebygget - inkludert romkorreksjon. Sammen med f.eks. 3F har du mye effekt og korreksjon akkurat som 9H
    Lockis
    Hej
    Jag har läst era intressanta artiklar om 9H och 3F här på forum och tycker det verkar till att vara väldigt bra högtalare
    Jag undrar om någon har lyssnat till 5F eller 7F då alla modellerna verkar bra i rätt miljö så är det väldigt intressant
    Mvh Bengt
    GSolie
    Eydehavn
    Hej
    Mvh Bengt
    Alle modellene i Personaserien låter veldig likt. Diskant og mellomtone er samme. Forskjellene ligger i fundamentet og dypbass. Dette kan også ved flere omstendigheter påvirke helhetsbildet, men "familielikheten" er der hele tiden.
    Er du i posisjon til å vurdere 7F, ville jeg definitivt også vurdert 3F + 2 stk Persona SUB. Denne kombinasjonen sammen med elektronikk som har subwoofer management som f.eks Anthem STR, ville være en killer.
    Lockis
    Tack för snabbt svar
    Jag är inte intresserad av sub, däremot undrar jag hur mycket mer bastryck man får med 5F kontra 3F
    Där blir ju en bas extra! När det gäller 7F råder det nog ingen tvekan om att där är ordentligt med tryck i basen
    Så jag blev nyfiken om någon fått lyssnat på dom modellerna
    Mvh/Bengt
    GSolie
    Eydehavn
    Mvh/Bengt
    Jeg bare nevnte 3F + 2 stk Persona SUB da dette er i samme prisklasse som 7F, men en løsning som kan gi bedre resultat.
    5F har noe mer fundament enn 3F, og noe lavere forvrenging som følger av mer membranareal.
    alphamale
    Hvis du går for 3f med sub løsning som skissert over her slipper du også bekymre deg i hjel for å få nok forsterkerkraft, og kan dermed slippe billigere unna på forsterkersiden.
    En annen ting! systemet arc sørger for at du får ekstremt potent lyd med stålkontroll.
    DCM4EVER
    ikke helt ny denne tråden,men so what? har akkurat fått mine Paradigm Persona 5f i hus og med en Eminent forsterker i form av Bryston 4b3 (velvillig bygd etter mine egne preferanser i godt samarbeid med Lyric/Boahs og Bryston i Kanada)virker dette så langt å være en match made in heaven. Utrolig lettflytende lydbilde,har pin-point kontroll på stemme/instrumentplassering.Sart og sårt og skimrende samtidig som bassfundamentet virker å gå enda dypere enn de tørre spec's skulle tilsi.Sammen har Bryston/Paradigm et "framifrå driv" -og om du ikke Automatisk får fot av dette fra første takt så trenger protesen din smøring...
    -Vanvitting fin finish! men samtidig litt touchy for fingeravtrykk, men lett løst ved at alle får utlevert hvite hansker i entreen :rolleyes:
    Effektforsterkeren fra Bryston tilskriver jeg også mye av æren for sluttresultatet,den har krefter i overflod ,men uten å servere "rett i fleisen"opplevelse,
    stålkontroll på høyttaleren (som jeg vil beskrive som litt av et enigma eller kanskje heller som en selvmotsigelse) jeg opplever at Bryston har suveren bygge- og komponentkvalitet (jeg har hatt flere på lån) og finishen toppes Kun av Brystons (og Lyric/Boahs') Meget velvillige/No-crap samarbeid med Særs god oppfølging og Topp service hele veien!
    Nå har jeg selvsagt ikke hatt Allt av fancy-stuff tidligere men har jo hatt gleden av endel gromt utstyr men må si at Bryston/Paradigm overgår det-Enkelt. Pr dd kan jeg lett se for meg at dette blir det anlegget som følger meg til jeg selv forsvinner i ozonet..... men som de sier i Tyskland You never know 'till you know You know? Uansett-jeg ser frem til talløse kvelder/netter med god musikk på gutterommet.kjøleskapet fylt opp med akkompangnerende tilbehør som øl og børst,nøkkel til døra nysmurt og ladet,så jeg ser vel ikke kona før hu skrur ut sikringene og det allikavel er tid for å ta skjegget (mitt) :cool: En god helg til alle på avd B...
GSolie
GSolie sine annonser
AudioSolutions med ny høyttalerserie
Lydcompagniet AS presenterer AudioSolutions Virtuoso M AudioSolutions blir ofte omtalt som et av de mest spennende høyttalerprodusenten akkurat nå. Både Overture, Figaro og Vantage får...
Sommerkupp fra Lydcompagniet
Vi roer ned før sommeren med knallpriser på knallprodukter Av helsemessige årsaker har det skjedd store endringer hos Lydcompagniet de siste mnd. Av nevnte årsak måtte det gjøres nøye...
Nytt norsk høyttalermerke under etablering
  • 68
Lydcompagniet AS presenterer Det etableres i disse dager et nytt selskap som skal utvikle høyttalere og annet relatert til bransjen. Selskapets navn blir Norse Audio AS og merkevaren Norse...
Bli kjent med Cocktail Audio
Cocktail Audio Det prisgunstige High End alternativ Cocktail Audio er kanskje ikke det mest kjente merket blant streamere, men du må gjerne betale endel mer for de mer kjente merkene, skal du...
Kampanje på IsoAcoustics
  • 7
Vårkampanje på IsoAcoustics hos Lydcompagniet AS Det er ikke mye tilbehør som har fått så mye ros og utmerkelser som IsoAcoustics. Produktene er ikke bare populære i HiFi miljøet, men brukes...
Dutch & Dutch 8c Kampanje
Lydcompagniet presenterer D&D og Cocktail Audio Super-bundles Som flere kunder har fått oppleve i det siste, er det lang ventetid på Dutch & Dutch 8c. Etterspørselen er større enn...
