Denne
MOON 380D dacen kan jeg ikke finne hos Acoustic Tuning ennå
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Spent på pris her hjemme.... (i det store utland: $3900 + $600 for volum kontroll)
Intr denne da jeg kjenner 300D dacen fra før
gismo
Litt skriverier her:
[h=1]An ultra-high performance DAC with versatile functionality[/h]Simaudio's Moon line should be something that most Listening Post customers are familiar with; we have had a couple of good examples on display here for quite some time. Well, Simaudio has done it again. In a similar vein to the 100D and 300D, they have released what promises to be a fantastic sounding,
asynchronous DAC. Built around their M-AJiC32 circuitry (an asynchronous jitter elimination system) performing in true 32-bit fully asynchronous mode, the MOON 380D features the ESS SABREP32P Ultra DAC operating in 32-bit Hyperstream™ where the conversion process uses an astonishing 8 DAC’s per channel.
Adding to this is it's unmatched flexibility with eight (8) digital inputs covering the full gamut of connections – 2 x AES/EBU on XLR, 2 S/PDIF on RCA, a S/PDIF on BNC, 2 Optical (TOSlink) and a USB connection. Any of these inputs can support a 24bit/192kHz resolution. There is also a digital output and, interestingly enough, a digital monitoring loop.
Enhancing this Digital-to-Analog Converter are two (2) separate options; (i) The MOON MiND music streamer module which is actually a digital 9th input via WiFi or Ethernet connection, and (ii) a high quality remote-controlled volume circuit feeding both balanced (XLR) and single-ended (RCA) analog outputs. The MOON 380D is targeted at individuals with computer-based audio setups, large digital music collections or multiple digital sources.
[h=3]Significant Design Features:[/h]
- True 32-bit Digital-to-Analog converter using ESS Technology SABRE32 Ultra DAC / Digital Filter (ES9016) working in 32-bit Hyper-stream™ to achieve unprecedented jitter immunity and low-level linearity via a patented Time Domain Jitter Eliminator
- Digital Audio Signal Processing using M-AJiC32 (MOON Asynchronous Jitter Control in 32-bit mode)
- A virtually jitter-free “1 pico-second” digital clocking system
- Optional MiND (MOON intelligent Network Device) module (9th input) via WiFi or Ethernet input for multi-room streaming
- Optional variable analog outputs (balanced & single-ended) using M-eVOL volume circuit which was originally developed for the MOON Evolution series. Accessible using the remote control, this volume operates in 0.5dB increments. M-eVOL is based on a resistive array configuration with no sonic degradation of the audio signal regardless of the chosen volume setting
- The entire analog stage is a fully balanced differential circuit for increased dynamic range and headroom, higher resolution, as well as improved signal-to-noise ratio.
- A very short signal path using a DC servo circuit and proprietary 12dB/octave analog filter
- Separate digital & analog power supplies using 2 independent toroidal transformers with 11 stages of voltage regulation
- Four-layer PCB tracings for a dramatically improved signal-to-noise ratio
- RS-232 port for (i) full unsolicited bidirectional feedback and (ii) firmware updates
- 12 Volt trigger outputs for remote operation and IR input for external control
- SimLink controller port allows for 2-way communications between other compatible MOON components
