takk, fant også denne:System Audio Legend 60.2 Silverback Active Loudspeaker Lab Report
Lab Report As Mark discusses in our review, this 'Silverback' version of the Legend 60.2 is very much more than an actively-driven version of the 'passive' 60.2. Same cabinet and same combination of four 150mm carbon-fibre reinforced bass units, except the ports in the Silverback are internally...www.hifinews.com
System Audio Legend 7.2 Loudspeaker Lab Report
Lab Report With the speaker arranged in 'landscape' guise, and measured on the tweeter axis, its forward response shows a boosted presence and high treble [Graph 1], the trend giving high response errors of ±4.8dB and ±5.0dB but with a tight 1.2dB pair matching (200Hz-20kHz). The two 130mm pulp...www.hifinews.com
System Audio Legend 40.2 Silverback Loudspeaker Lab Report
Lab Report Tested here without any 'RAM Tweaks' this active version of the Legend 40.2 employs the same cabinet and trio of 135mm carbon-fibre reinforced bass and mid units, but with the rear-facing reflex port internally 'shorted' to yield a 2nd-order sealed-box bass alignment. Incidentally...
