"The Classic 2/3s may look retro, but they sound as good as anything we’ve heard
at this level": WHAT HI-FI?
Hør Spendor Classic 2/3 hos Mala Audio og finn selv ut hva du synes!
Dette skriver WHAT HI-FI?:
"The Classic 2/3s may look retro, but they sound as good as anything we’ve heard at this level."
For:
• Impressive scale and authority
• Finesse and insight
• Lovely, unforced presentation
• Dynamic bite and subtlety
• Fine build
Against:
• Partnering stands cost £600
Verdict:
The 2/3s surprised us quite a lot during the review period. They retain the charm and easy-going nature of their highly regarded predecessors, but now have the punch and rhythmic precision to work well with a wider range of music.
Om du har byttet høyttalere flere ganger, uten å få den lyden du vil ha, vil Classic 2/3 kanskje være noe for deg, da de er helt usedavnlig lette å ha med å gjøre.
Ta kontakt med en av oss for å avtale en dag, eller kveld der det passer for deg å få en demo av Spendor Classic 2/3:
Sveinung Mala
Mala Audio
Hofgaardsgate 22
3011 DRAMMEN
Nettside: www.malaaudio.no
E-post: sveinung@malaaudio.no
Tlf.: 909 53 801
Hallvar M. Rostad
Mala Audio
Hofgaardsgate 22
3011 DRAMMEN
E-post: hallvar@malaaudio.no
Tlf.: 973 13 953
Her er noen utdrag fra testen i WHAT HI-FI?:
Few speakers on the market can match the heritage of Spendor’s Classic 2/3s.
This design can trace a direct line back to the highly regarded SA2s, which were launched in 1980.
The BBC-inspired engineering is most obvious in the speaker’s cabinet construction. Most rivals aim to make the enclosure as rigid as possible to give the drive units a solid foundation to work from and minimise any cabinet wall movement. Spendor’s Classic models take a different approach.
No matter how rigid you make the cabinet there will always be some cabinet resonance. This will add distortion to the sound the drive units make.
Making the enclosure more rigid will only make that resonance higher in frequency, crashing the midrange region where our ears are most sensitive.
The BBC approach is to make the cabinet walls thin (so they flex at low frequencies, where our hearing is less discriminating) and to control resonance by carefully, but heavily, damping the cabinet panels. Spendor’s Classic models have always used this method, and the 2/3s are no different - though this latest model features a far more rigid front baffle.
The Classic 2/3s have an easy-going sonic nature, one that draws the listener into the music rather than shouting for attention.
These speakers may not win out in a quick dealer comparison, but given time their considerable charms are obvious. Most modern rivals sound smaller, leaner and more aggressive by comparison.
There’s a beautiful sense of fluidity to the way these standmounters go from quiet to loud, and it’s coupled with a delicate sense of ease most rivals struggle to approach.
Of course, there’s lots of bass – how could there not be with such a generous cabinet volume and such big mid/bass units? But it’s delivered with finesse as well as plenty of weight and power.
There’s plenty of detail too, with the standmounts picking up subtle nuances and instrumental textures without highlighting the fact unduly.
These are speakers that we could listen to for hours on end without tiring, yet they have enough in the way of excitement and drive to entertain when the music demands.
Verdict:
Gratis utkjøring:
Bestill varer fra oss i dag og få gratis utkjøring med levering på døren. Samme dag eller dagen etter.
Vi leverer både på dagtid, kveldstid og helg til kunder som bor mindre enn 100 km fra Drammen.
Om du bor lenger unna, kan du kontakte oss og avtale et lite pristillegg.
Gjelder bestillinger på over kr 10.000,- og varer som er på lager.
Varer som ikke er på lager kjøres ut straks de ankommer vårt lager i Drammen.
Se vårt utvalg av produkter på denne siden: www.malaaudio.no
Ta kontakt med en av oss for å bestille og avtale utlevering:
Sveinung Mala
Mala Audio
Hofgaardsgate 22
3011 DRAMMEN
Tlf.: 909 53 801
Hallvar M. Rostad
Mala Audio
Hofgaardsgate 22
3011 DRAMMEN
Tlf.: 973 13 953
moto
moto sine annonser
Bestill nå fra Mala Audio og få varene levert med vår bil. Denne uken kjører vi til Østfold, Mjøs-regionen og Oslo. Vi tar med innbytte.
Dersom du ikke har emballasjen til det du bytter inn, har vi med utstyr for å frakte dette trygt. Vi har et stort utvalg av platespillere og kan transportere platespillere på en skånsom måte. Vi...
Mala Audio kjører ut varer til kunder i Mjøs-regionen, Glomdalen, Hadeland og Oslo-regionen mandag 30/10
Bestill nå og få varene levert på døren med vår egen bil! Har du innbytte? Vi tar også med tilbake innbytteprodukter som mangler emballasje. Da vi benytter egne transportmadrasser og myke...
Mala Audio kjører ut varer til kunder i Mjøs-regionen, Glomdalen, Hadeland og Oslo-regionen torsdag 27. juli
Mala Audio i Asker og Arendal kjører ut varer til kunder på Sørlandet og Vestlandet 13. - 15. juli
Gjelder også kunder, som vi kan kjøre innom i Vestfold og Telemark, på veien sørover. Avreisen fra vår butikk i Asker er flyttet fra fredag den 14. juli, til allerede i morgen, torsdag den 13...
Påske-utkjøring av varer til kunder i Østfold og hele Oslo-regionen FØR skjærtorsdag
Nyt synet av bilen fra Mala Audio som rygger inn mot din dør, med godsaker du kan kose deg med å pakke ut og koble opp i påsken. Bestill nå og få varene levert på døren før skjærtorsdag! Har du...
Mala Audio har utkjøring av varer til kunder i Mjøs-regionen, Solør, Hadeland og Oslo til helga
Bestill nå og få varene levert på døren med vår bil. Som tar med innbytte, om du har det. Vi kan også ta med innbytteprodukter uten emballasje. Vi har allerede bestillinger på varer som skal...
