Threshold sine venner
  • baluba
    Kopervik og Bergen
    Såpass mye som 15k, ja. Du har helt rett i at den ligger på den varme siden, og den var blant mine favoritter i sin tid. Fantastisk sammen med LS3/5A i mine ører, og glimrende til å drive ML CLS, som har vært denne forsterkerens jobb.
    Båret 500S inn i hus...Spent...Jæklar , hva tung den var.. :cool:
    Audirvana
    Er det noen her som har erfaring med Threshold SA/4e?
    el_mariachi
    Fant denne lista på Threshold sine hjemmesider.
    Papa forlot forøvrig Threshold høsten 1991.
    Historical/Discontinued Products
    NS-10 Stereo Preamplifier (1977-79
    800A 200 Watt/Channel STASIS Stereo Power Amplifier (1975-77
    400A 100 Watt/Channel STASIS Stereo Power Amplifier (1976-79
    4000 200 Watt/Channel STASIS Stereo Power Amplifier (1977-79
    SL-10 Stereo Preamplifier (1979-81
    CAS-1 75 Watt/Channel STASIS Stereo Power Amplifier (1979-81
    CAS-2 125 Watt/Channel STASIS Stereo Power Amplifier (1979-81
    STASIS-1 200 Watt STASIS MonoBlock Power Amplifier (1979-81
    STASIS-2 200 Watt/Channel STASIS Stereo Power Amplifier (1979-81
    STASIS-3 125 Watt/Channel STASIS Stereo Power Amplifier (1979-81
    FET-1 (two series) Stereo Preamplifier (1981-85
    FET-2 (two series) Stereo Preamplifier (1981-85
    SA-1 160 Watt STASIS MonoBlock Power Amplifier (1984-88
    SA-2 100 Watt STASIS MonoBlock Power Amplifier (1984-88
    SA-3 50 Watt/Channel STASIS Stereo Power Amplifier (1984-88
    S/150 (two series) 75 Watt/Channel STASIS Stereo Power Amplifier (1982-84
    S/200 (two series) 100 Watt/Channel STASIS Stereo Power Amplifier (1984-86
    S/300 (two series) 150 Watt/Channel STASIS Stereo Power Amplifier (1983-88
    S/500 (two series) 250 Watt/Channel STASIS Stereo Power Amplifier (1983-88
    S/1000 (two series) 500 Watt STASIS MonoBlock Power Amplifier (1984-88
    PCX (-X10) Stereo Electronic Crossover (1987-89
    FET-9 Stereo Preamplifier with Phono Stage (1986-89
    FET-10Pc Stereo Phono Gain Stage (1986-89
    FET-10HL Stereo High Level Preamplifier (1986-89
    SA/3.9e 60 Watt/Channel STASIS Stereo Power Amplifier (1990-94
    SA/4e 100 Watt/Channel STASIS Stereo Power Amplifier (1989-95
    SA/6e 125 Watt STASIS MonoBlock Power Amplifier (1990-94
    SA/10e 175 Watt STASIS MonoBlock Power Amplifier (1990-94
    SA/12e 250 Watt STASIS MonoBlock Power Amplifier (1989-95
    S/160 80 Watt/Channel STASIS Stereo Power Amplifier (1992-94
    S/250 125 Watt/Channel STASIS Stereo Power Amplifier (1992-94
    S/350e 150 Watt/Channel STASIS Stereo Power Amplifier (1990-94
    S/450e 200 Watt/Channel STASIS Stereo Power Amplifier (1990-94
    S/550e 250 Watt/Channel STASIS Stereo Power Amplifier (1990-94
    S/1600e 750 Watt STASIS MonoBlock Power Amplifier (1989-1994
    TA 300 150 Watt/Channel STASIS Stereo Power Amplifier (1993
    DAC1e Digital to Analog Convertor (1992-96
    DAC2 Digital to Analog Convertor (1995-98
    FET-9e Stereo Preamplifier with Phono Stage (1990-94
    FET-10Pe Stereo Phono Gain Stage (1990-98
    FET-10He Stereo High Level Preamplifier (1990-94
    T Zero Stereo High Level Preamplifier (FET-9e with Balanced Output) (1993
    T Zero P Stereo Preamplifier with Phono Stage (FET-9e with Balanced Output) (1993
    T 2 Remote Control Stereo Preamplifier (1994-98
    T 3/T 3i Remote Control Stereo Preamplifier (1994-98
    T 50 50 Watt/Channel Stereo Power Amplifier (1994-98
    T 100 60 Watt/Channel Stereo Power Amplifier (1994-98
    T 200 100 Watt/Channel Stereo Power Amplifier (1994-98
    T 400 150 Watt/Channel Stereo Power Amplifier (1994-98
    T 800/T 800D 200 Watt/Channel Stereo Power Amplifier (1996-98
    vega jon
    bærum
    noen som sitter på en 400a de skal kvitte seg med??
    Newton
    Har sansen for vintage amper og melder meg på. Postet bilde av min S/500 med FET ten/HL pre og min Nakamichi PA7E MkII her på vintage tråden http://www.hifisentralen.no/forumet/vintageavdelingen/51670-vintage-bilde-36.html
    S/500 skal blåse liv i noen låvedører, Naka'en trekker nå opp noen elektrostater :-D
    edit-har forøvrig en GFP-750 som Pass snurret i hop for Adcom. Er dog tuftet på Pass Labs Aleph P, ikke Threshold...
    Ysthusen
    Fersking
    Jeg har en gammel Treshold Stasis 3 stående hjemme nå. Det var en forsterker jeg fikk som delbetaling for noen Pass blokker jeg solgte. Er det noen som kan fortelle noe om den? Den er vel over 30 år gammel. Er den verdt noe idag?
    MusicBear
    Hehe, stopp den ut og sett den på peishylla, med gravert messingskilt under: Det var forsterkere og tider, det!
    Ville sjekket med fagfolk om kondensatorene har lekket (noe de trolig har), så vurdert bytte av disse dersom resten spiller og samtidig ikke byr på unoter.
    Newton
    Noen ting er mer pop en andre fra Threshold, så google is your friend Threshold Stasis 3 Power Amplifier | eBay
    Altså ca 4000.
    Hadde det vært SA3 monoblokker så hadde nok takstameteret startet å tikke ;-)
    Bud mottas :)
    Solgte min S500 pga at den hadde vært innom noen som mente at de skulle forbedre den med noen nye komponenter. Tukling passet meg dårlig og fikk litt feelingen av å kjøre veteran bil som man aldri viste når den ville stoppe.... Havnet hos en entusiast i Thailand som hadde en S500 fra før.
    Skal du bruke den ville jeg gjort følgende:
    Sjekk ladelyttene- er de gåen så bytt.
    Gå så over alle loddinger og ikke begyn å mikke med no magiske komponenter som står i serie med signalet med mindre de er røke. Da beholder du den orginal og burde la seg evt selge hvis noen er interessert.
    Har selv enda min Nakamichi PA7 E II og fikk gjort det nevnt over og den låter fantastisk :)
    Hadde du hatt noen SA3 klasse A monoblokker hadde jeg nok vært på kroken....men da måtte jeg nok kvittet meg med noe av de 4-5 ampene jeg har :)
    Happy listening.
    N
    Ysthusen
    Fersking
    Altså ca 4000.
    Bud mottas :)
    Happy listening.
    N
    Takk for tips. Kan jo nevne at forsterkeren er i daglig drift og fungerer fint. Den drar opp et par Respons Baby Grand til dans. Det låter jo greit selv om det er endel høyere bakgrunnsstøy enn hva man er vant med.
    vega jon
    bærum
    kul den :D
    spiller på min 400a siden i går:D la mi mosfeten få et par ukers hvile. denne er noe moddet med ringkjernetrafo og rifa elektrolytter++
    den er gammel men god. ikke like god som mi mosfet men ikke langt unna. til uka kobbler jeg opp sl10 og skal snurre no plater i jula:)
    H._Lecter
    Noen som har erfaring med Threshold 4000? Vil bli en bra match med Infinity Sigma?
    Kabeldragern
    Kristiansund
    I dag byttet jeg kondiser i psu i min Stasis 3. WOW!
    Forsterker fra 1981 med originale kondiser - nye lytter ble byttet i dag.
    Jeg har vanskelig for å tro det jeg hører! De få lytene den hadde bl.a. litt hard diskant og litt forvregning i mellomtonen er borte! Tilbake er en silkemyk lyd med en brilliant diskant og en glitrende mellomtone - og en bass som virker å «puste lettere».
    Rett og slett ikke til å tro!
    vega jon
    bærum
    forsåvidt orginal sl 10 som pre urørt nesten. skiftet volum pot det er vel det eneste... spiller bra enda den og men snart på tide med recap og ei liten psu oppgradering hadde vert kjekt der og. kvailtet på dette vokser ikke på trær. 40+ still going strong. selv er jeg kun 35 og svak for vintage. jeg er sikker på at forsterkeriet overlever meg. og håper dette blir sikkelig samler amps. for en newbie i den fjerne fremtid.. :cool:
    Drossel
    Threshold fra før Nelson Pass gik fra snøvsen med primitive Klasse A shit. 😂
