OCTAVE lager elektronikk med rør som ikke er helt mainstream eller"gammaldags".
Futt og fart. Tighte i bassen.Håndlaget i Karlsbad De.
Kostbare saker i toppserien:
Octave Jubilee:
SPECS & PRICING
Octave Jubilee Mono Power Amplifier
Inputs: One RCA, one XLR
Outputs: Two loudspeaker
Power output: 250W into 4 ohms
Frequency response: 10Hz–80kHz +/- 0.5dB
Total harmonic distortion: <0.1% at 10W into 4 ohms
Signal-to-noise ratio: >103 dB
Minimum load impedance: 2 ohms
Gain/input sensitivity: + 30dB / 1.5V
Dimensions: 27.83” x 11.02” x 19.06”
Weight: 143 lbs. each
Price: $67,500 per pair
Jubilee Preamplifier
Inputs: Six RCA, two XLR, Home Theatre Bypass function on request
Outputs: Two RCA, two XLR, two Tape Record (RCA)
Frequency response: 3Hz–500kHz +/-1.5dB
Total harmonic distortion: 0.001% @ 3V/7.5k ohm
Signal-to-noise ratio (unweighted): 90dB (Gain High)/98dB (Gain Low)
Maximum output voltage: 8V
Weight: Preamplifier, 37.8 lbs.; power supply, 25.3 lbs.
Price: $35,000
Rimeligere løsninger finnes,-Octave V80 integrert m riia,pre out, hodetlefon uttak mm.
Phonotrinn:
