Hei!
Fikk litt mere info fra Alex!
Hi!
APL Hi-Fi will be attending the Horten Hi-Fi Show this October 26th and 27th.
This will be "The World Premiere" of the entire APL-ILLUMI-FI audio system, first in Norway!
The audio system will consist of the following:
1. Gravitas NB-Master Reference Speaker System. It features a sealed sub-bass enclosure with one active and one passive Scan-Speak Revelator drivers. Paper-cone Revelator mid-bass units. Silk dome Revelator tweeters and Ribbon super-tweeters.
2. DTR-Master digital transport prototype with our proprietary PCM-to-DSD converter. The transport also has "Pure DSD" stream coming from SACDs and DVD-R with recorded DSF files on it.
3. DCT-Master computer audio transport prototype, capable of streaming DSD and PCM-to-DSD converted data to the DSD-Master via USB. It has Windows 8 (x64) with Intel quad-core processor without integrated graphics, 32GB RAM, 128GB SSD for the Windows operation system, and two mirroring 3TB HDDs for audio files only. USB-2.0, USB-3.0 and any memory card or external drive can be connected. e-Sata connection also available. Control through any hand-held device or keyboard. Internet connection is wired only through RJ-45 LAN connector.
4. DSD-Master D/A converter with two S/PDIF inputs and one AES/EBU balanced, accepting up to 192kHz/24bit, that is further converted to DSD by our proprietary PCM-to-DSD converter with DSD64, DSD128 and DSD256, user selectable. Special triple-balanced DSD-only input for connecting the DTR-M transport, proprietary asynchronous DSD-only USB interface accepting DSD64 and DSD128. The DSD-M also features our own proprietary "Pure DSD" double-differential D/A converter. No off-the-shelf DACs. The balanced tube output stage with custom OFC audio output transformers made by Lundahl is also intact.
5. PHS-Master phonostage prototype and my highly upgraded Technics SL-1210M5G with Dynavector XV-1s cartridge. The phono stage is MC-only with Lundahl OFC transformers and JFET/MOSFET input, followed by MUSES01 OpAmps and high-current MOSFET output stage, all working in "Class A". RIAA EQ is a split-type; half passive, half active.
6. HAS-Master 3-piece hybrid amplification system with 6SN7, 2A3 or 300B tubes and IGBT high-current power converters. It has three RCA inputs and one XLR. The built-in attenuator unit is very unique, featuring Opto-controlled devices and non-magnetic resistors.
7. Custom Power cables and Power Splitting Device.
8. Audio Racks by Music Tools, Italy.
Hope to see you there! We will have some great fun! Make sure to bring some of your favorite tunes for audition. CDs, SACDs and any other memory card or USB device containing any audio format will work.
Best wishes,
Alex
I mine øyne blir dette stort!
Her blir det noe for en hver smak når det gjelder kilde på øverste hylle, bakket opp av ekstremt bra komponenter!
For dere med gode kunskaper når det gjelder elektronikk skulle det være mulig å få "bryne" seg litt på Alex også vil jeg tro?
Mvh.
SAL
