Finnes det noen "tweaks" som er så "over the top" at ingen går på de?
  • baluba
    Kopervik og Bergen
    A
    ANM
    Alt som er beregnet for det Amerikanske markedet må sikre seg, selv når produktet heter "Useless Box". "It’s not quite totally useless"
    Valfy
    Disse var gratis for meg. Hvor stor avanse kan man påregne med slik kreativ markedsføring?
    yosh81
    Flisa
    Du må nok ordne en noe mer flashy og flott embalasje enn det der om du skal lykkes.
    Bruk av ekstra merker og kommentarer om hvor bra produktet er på boksen hever prisnivået ytligere. :)
    8)
    DagT
    Dessuten må svadaen finslipes litt. For eksempel "Defies gravity. Once the speaker is set on the pillow it will never touch the floor", og (inspirert av VdH) "The weak nuclear quantum forces in between the pillow atoms interact and maintain the distances without ever touching each other, thus completely avoiding the resonating powers of the strong nuclear forces."
    Forsåvidt helt riktig, rent fysisk...:cool:
    The program makes a bit-perfect copy of the original, checks the bit-perfectness, and overwrites the original, retaining its file properties. If you open Explorer during the process, you see a temporary file whose name consists of digits.
    The target files must be on a Win7/8.1 PC. Applying to a network drive makes no sense. Copying the processed files as well as moving them to a different drive loses the effect.
    It is also effective to a USB memory and an SD card, which can be plugged out and be inserted into other pieces of equipment such as an SD card transport.
    The effect vanishes gradually and the program should be applied again.
    Drastic sound quality improvement: "Rewrite data" - audiophile software from Japan
    Gratulerer, en audiofil defraggler.
    Helt utrolig.
    [FONT=&quot]The base is a stable, anodized aluminum disk, designed to inhibit any transference of electrical charge from the floor to the cable and eliminate static build-up on the dielectric itself. This base supports the proprietary Floating Spring System. The Floating Spring System uses a flexible, titanium alloy spring-wire, which makes up both the support wings and tension wire supports. In both elements, the alloy wire is coated in FEP, mirroring the design of Nordost cables and making the supports an extension of the cable jacket. These specially treated wires eliminate any electrical interference, while allowing the cables to maintain their natural resonance properties. [/FONT]
    Olav2
    Helt utrolig.
    Ja. Jeg lurer på det der må være ny snake oil-rekord for Nordost?
    Nissen1
    Helt utrolig.
    Hvordan kan du vite at det er snake oil hvis du ikke har forsøkt det selv? :D:D
    lyntoft!
    Kløfta
    Emballert på denne måten vil nok produktet gå unna som varmt hvetebrød blant de mer lysskye entusiaster, avansen begrenses kun av din egen samvittighet.
    Olav2
    Helt utrolig.
    Kort svar: Fordi jeg tror på de etablerte fysiske lovene om hvordan elektiske signaler fungerer? ;)
    Litt lengre svar: Hvis man har kabler som er godt isolert - lydkabler konstruert for proffmarkedet feks. - er det absolutt ingen grunn til å tro at det skal ha noe å si å løfte kabler opp fra bakken. Selv med helt vanlige billigkabler som er dårligere isolert er det liten grunn til å tro at det vil utgjøre noen hørbar forskjell. Og i så fall er det uansett bedre å kjøpe nye kabler som er bedre isolert, siden det uansett kan finnes forstyrrelser, enten kabelen ligger på bakken eller ikke.
    Men hvis man absolutt vil løfte kablene opp fra bakken? Så trenger man ikke bruke 5000 kroner på det. Ut fra min enkle forståelse av slike ting, bør det holde å bruke noe enkelt med et materiale som ikke kan lede strøm. Man kan for eksempel bruke en matboks av plastikk, og feste kablene på toppen av den med gaffatape. Sånn, der sparte man 5000 kr.
    (men korrigér meg hvis dette ikke er presist. jeg tror jeg har en ok forståelse av elektronikk og de fysiske lovene, men er og blir en legmann på feltet)
    Valfy
    "Quantum pillows: rapes or sexually assaults gravity"
    Tja... :p
    Midas
    Stavangerområdet
    Hvorfor skulle det egentlig være det? At noen skulle ha funnet på en verdiløs gadget bare på kødd er jo ikke et helt ukjent fenomen.
    Nå er useless machine/useless box et (seriøst) fenomen da. Med bl.a. engineeringkonkurranser om hvem som lager den beste. Til og med blitt brukt som ansettelsesoppgave til en produtviklerstilling.
    lovemusikk
    Hvordan skal det gå med bransjen når alt blir skikkelig trådløst, inkludert strømmen?
    Best å selge aksjene nå :p
    Og hva skal vi diskutere da? Luftfuktighet og temperatur i stuen?
    Olav2
    Akkurat luftfuktighet, lufttrykk og temperatur er jo ting som faktisk påvirker lyden, selv om det er marginalt... i motsetning til hva som er tilfelle med mange andre tweaks. Så det forundrer meg egentlig litt at det ikke er flere som har installert luftfukter og perfekt termostat osv i lytterommene sine, for å sikre optimale lytteforhold - hvis man virkelig vil optimalisere hvert eneste lille område? Spesielt hvis man bor her Vest, der været stadig endrer seg, så vil jo sammensetningen av lufta stadig være i fluks hvis man ikke behandler det. Dersom man har et highend-flygel stående, er det selvsagt å ha et system for regulering av temperatur og fuktighet, feks. Og hvis man har woofere som er laget av papirmembran tror jeg faktisk at regulering av luftfuktigheten kan ha en hørbar betydning, siden papirmembran er sensitivt for endringer i luftfuktigheten.
    Når det er sagt kommer jeg aldri til å installere noe sånt selv bare for å optimalisere musikkanlegget, jeg tror de eventuelle endringene som følge av luftas sammensetning er så små at jeg aldri vil legge merke til det når jeg hører på muskk. Men for de som vil optimalisere hvert eneste punkt i kjeden? :)
    Og ufattelig mange tweaks som skal gjøre det trådløse renere (og selvsagt sortere bakgrunn som alle andre tweaks ;) ) Det er til og med kommet nettverksswitcher for audiofile. Helt sykt. Databransjen har ikke en sjans....
    Endel "ioniserende" bokser som gjør hele klimaet bedre lydmessig eksisterer også.
    Olav2
    Gode poeng!
    Klimaanlegg er bestilt!
    Fra spøk til alvor: Helt enig i at klimaanlegg er en fornuftig tweak, og på kjøpet får du bedre innemiljø året rundt, til prisen av et par Odin-kabler. Men jeg har aldri hørt om noen som har installert klimaanlegg for lydens skyld; det kan for øvrig skyldes at jeg hører for lite.
    Den dagen jeg endelig får meg et steinway-flygel i stua (og det SKAL skje en eller annen gang), skaffer jeg meg klima-anlegg. Ingen tvil. Det må til for å holde flygelet stemt. Men enn så lenge klarer jeg faktisk å nyte musikk helt fint i stua, selv med varierende luftfuktighet... :)
    ekstremsound
    Banned
    Du glemmer en vigtig ting og det er at det er mennesker-hjerne som vurderer, og den er 1000 gange bedre og mere avanceret end selv det bedste måleinstrument, vi kan på to sekunder , ja den første takt vurdere audio, en gengivelse.
    Og så kan de ellers påstår at det måler så og så nøjagtigt , det er fuldstændigt uden betydning hvis hjernen ikke godkender dette. Og ja det betyder at der er noget vi ikke som kan måle, men noget som hjernen kan detekterer på millisekunder.
    jeg ved ikke, og jeg kan ikke dokumentere hvorfor jeg synes at mit anlæg lyder rigtigt og godt , det kan jeg virkelig ikke , jeg ville ønske jeg kunne, men det er ikke tilfældet på trods af at jeg er elektroniktekniker og kender alt til måling.
    Distinctive
    Mhp. klimaanlegg er jo flere faktorer inne i bildet:
    - Operasjonelle betingelser for utstyr
    - Lydmessige betingelser iboende i rommet
    - Lyttekomfort
    - Støy
    En ellers fin tråd med glimt i øyet fikk seg et lite skudd for bauen idag.
    2 innlegg fjernet. Flere nedlatende kommentarer der eneste hensikt er å skape dårlig stemning får konsekvenser.
    Det er aldri et enkelt tema som er årsak til krangling men enkeltpersoner, holdninger og språkbruk.
    Luftfuktighet og membraner er nevnt, men bassrefleksavstemning påvirkes også av luftens tetthet (dvs temperatur og fuktighet). Dessuten endrer resistansen i kobber seg med temperatur, så en grad mer eller mindre i rommet gjør større forskjell for delefilteret enn hvilken som helst "oppgradering" med kabler i superrene metaller. Men det er ennå ingen som skriver lange utlegninger om ideell lytteromstemperatur for bestemte høyttalermodeller - "nytes best ved 21,3 grader og 60 % relativ luftfuktighet."
    For meg er det et praktisk sorteringskriterie for tweakeri: Hvis det gjør mindre forskjell enn en grad temperaturendring er det kanskje ikke så viktig.
    Fenalaar
    Luftfuktighet har enda en virkning som er kanskje mere relevant. Er det veldig tørr luft, så er en vesentlig mye mere utsatt for statisk elektrisitet, og spiller en vinyl er dette en pest og ei plage. At en kan gi anlegget en statisk karamell skal normalt sett ikke ha noe å si, men kjører en "rat rod" stil, med åpne cover, kan det tenkes at en tar kål på en ic, med max uflaks.
    noen store grønnplanter fikser luftfuktigheten og er supre diffusorer.
    Johan-Kr
    Syncrolux
    Jeg ser for meg å endre sammensetningen av gasser i lytterommets luft. Det vil vel også endre lydhastigheten?
    Mer oksygen når jeg hører Led Zeppelin? Mer nitrogen passer til The Doors?
    Fenalaar
    Det store problemet er at menneskehjernen er et temmelig upålitelig instrument. En greier rett og slett ikke å få til repeterbare resultater. Dette tror jeg også har med å gjøre at statistisk gyldige metoder (dobbel blindtest) er temmelig langt unna en normal lyttesituasjon. Musikk handler til syvende og sist om følelser, og det blir omtrent så langt unna en ABX-setting der en skal finlytte etter endringer som en kan komme. Det er som sådan ikke så rart at vi strever med å identifisere forskleller.
    Hjernen er humørsyk, så der man den ene dagen aldri finner noe interessant å høre på, så låter allt topp den neste.
    Hjernen er også påvirkelig av ytre stimuli - rødvin og annen alkohol er vel et av de beste lyd-tweakene som finnes. Store mengder av sorten kan dog føre til at man blir tunghørt og må skru opp.
    Det sagt - tweaks påvirker persepsjonen, så å vite om en faktisk hører forskjell eller om en bare tror en hører forskjell er vanskelig å si. Jeg mener å høre forskjeller på en del ting, men om jeg vil høre forskjell i en blindtest eller ikke er jeg ikke overbevisst om.
    Jeg tror på sett å vis at en del av de egenskapene som gjør f.eks. at en forsterker låter bra er det vanskelig å identifisere vha enkle målinger. Forvrengingsspektra, fordeling av høyereordens forvrengning, hvordan en rørforsterker handterer klipping i en kompleks last er alle egenskaper som kan måles. Hvordan dette gir seg utslag i hvordan øret oppfatter at dette gir utslag i gjengivelsen er vanskelig å måle. Det er på sett og vis her at ABX-testing er nesten det eneste verktøyet en har i skuffa. All dn tid hjernen er involvert, så er resultatet noe upresist.
    Johan-Kr
    sprellemannen
    https://oslohificenter.no/kabler/tilbehor/nordost-sort-lift
    6000 spenn :D
    "...[FONT=kelson_sans] enhances the sonic performance of loudspeaker cables, power cords, and interconnects, by minimizing the points of contact that cables make with the ground and reducing boundary effects, without negatively affecting the resonant properties of the cables themselves."
    jada jada ![/FONT]
    Kommer til å gå helt fint. Alle som spiller luftgitar har kjørt trådløst imange år nå :cool:
    A
    ANM
    6000 spenn :D
    Vis vedlegget 398498
    jada jada ![/FONT]
    Kan late som ingenting overrasker meg lenger...steiner, tekopper... Men synes nesten audiofile snart bør føle at noen håner dem litt. Jeg mistet litt piffen merket jeg.
    Z
    Zomby_Woof
    6000 spenn :D
    jada jada ![/FONT]
    Altså. Dette hjertesukket om at jeg og mange andre, som tross alt er interessert i kvalitetsgjengivelse av lyd i heimen, ble definert ut av gruppen 'audiofile'. Det fremstår mer og mer som et kompliment når man ser hvilken kant det kommer fra.
    Trondmeg
    Fantastisk. A bit isnt just a bit? Subatomic particle accelerator?
    D
    Dåbbel J
    Et mørkt rom...
    Men den er det jo ingen som går på... hehe. :rolleyes:
    Og det er det jo ikke noe og betale for - heller tvert om - enn sparer penger, men det er det jo ingen som er interessert i....
    Derfor så må det være et tweak som er over the top og beyond ?
    Eller ?? :cool:
