coolio
"If I did not have the C1s around, that would have been it. Perhaps I will wax lyrically about how good the Special Forty speakers are, bar none. But the Confidence speakers do sound better, but they cost more than two times more. They also go down just a bit more. The C1s can be used in small to medium sized rooms, but the Special Forty is a good match for a study, or a modestly sized living room. Like mine… in my room, it was in it’s element, and since I prefer a good soundstage, and great mids, the lack of the final octave did not bother me. You would not miss that last bit that the C1s can churn out if you do not have them for comparison in the same room. You also would not miss the extra air in the higher frequencies until you have the C1s play the same song. The C1s convey music like a pair of electrostatics. They are that good.
Well like the Confidence 1s, I did find out that they can be quite fussy with speaker position. Even so, they withstand a closer boundary placement better than the C1."
- Pete's Write: Dynaudio Special Forty Speaker review
Ser ut som du fikk svaret her, C1 som du har hatt er en del bedre. Ser ikke noe stort poeng i å skifte ut XD 200 med disse med mindre du vil bytte for byttingens skyld.
Jeg skal selvsagt ikke være bastant på noen måte ettersom jeg ikke har hørt hverken C20 eller Special Forty, men jeg antar at du må opp i C20 for å oppgradere det du har, uavhengig av hvilken forsterker du velger.
Eventuelt C1 da...
Skal på en 3 ukers Europa-turné med forskjellige destinasjoner fra 9 september, lengter etter sol og varme. Bergen er en forbanna drittplass som burde vært spylt ut i havgapet først som sist!
Eventuelt C1 da...
