Diverse Dilldalltråden 1.5
  • H
    Hardingfele
    NSA finner verdens mest hemmelighetsfulle milliardær, oppfinneren av Bitcoin:
    The 'creator' of Bitcoin, Satoshi Nakamoto, is the world's most elusive billionaire. Very few people outside of the Department of Homeland Security know Satoshi's real name. In fact, DHS will not publicly confirm that even THEY know the billionaire's identity. Satoshi has taken great care to keep his identity secret employing the latest encryption and obfuscation methods in his communications. Despite these efforts (according to my source at the DHS) Satoshi Nakamoto gave investigators the only tool they needed to find him -- his own words. Using stylometry one is able to compare texts to determine authorship of a particular work. Throughout the years Satoshi wrote thousands of posts and emails and most of which are publicly available. According to my source, the NSA was able to the use the 'writer invariant' method of stylometry to compare Satoshi's 'known' writings with trillions of writing samples from people across the globe. By taking Satoshi's texts and finding the 50 most common words, the NSA was able to break down his text into 5,000 word chunks and analyse each to find the frequency of those 50 words. This would result in a unique 50-number identifier for each chunk. The NSA then placed each of these numbers into a 50-dimensional space and flatten them into a plane using principal components analysis. The result is a 'fingerprint' for anything written by Satoshi that could easily be compared to any other writing. The NSA then took bulk emails and texts collected from their mass surveillance efforts. First through PRISM and then through MUSCULAR, the NSA was able to place trillions of writings from more than a billion people in the same plane as Satoshi's writings to find his true identity. The effort took less than a month and resulted in positive match.
    Spiralis
    Det er så jævlig sykt at den antakelig er sant! Og er det noen som reagerer?
    Men å lage en helvetes masse styr om at jorden er flat, kun 6000 år gammel og at NASA aldri landet på månen, jo det tar folk seg tid til!
    Man burde vel egentlig bli vettaskremt.........egentlig!
    Reaksjoner: ePi
    weld77
    Med mine begrensede kunnskaper om maskinlæring og tekstanalyse høres det der faktisk ikke ekstremt komplisert ut - med unntak av å sitte på et lass med e-poster osv fra overvåkning da. Skal ikke påstå at jeg hadde fått det til selv, men selve konseptet er nok velkjent.
    G
    Gjestemedlem
    Tysken min er ennå ikke god nok til frilesing, men noe sier meg at googles oversetter fremdels har et stykke igjen til full nyttighet.
    AIen deres er creepy nok til å presentere meg for musikk jeg liker, men de har ikke overtaket ennå!
    mteinum
    Øya
    Det må være mange fine vinkjellere rundt om kring i byen her.
    mteinum
    Øya
    Stygt å le men en ikke alt for lite innslag av poetic justice over Marokkansk ungdomskultur.
    Rabies - teenagers gang tape donkey and contract disease in Morocco | World | News | Express.co.uk
    Gjengvoldtekt av et esel - jaja... Hvis en nå har sett hva en eselhingst er utstyrt med, så kommer uttrykket "kaste loff i Ekebergtunellen" i håg.
    Du har forsåvidt helt rett på begge punkter - man skulle ikke flire, og det er virkelig poetic justice..,
    Johan-Kr
    Denne tikket forbi på facebook
    totte
    Men i det minste kan Johaug slappe av. Man får fokusere på det positive.
    Fenalaar
    For å være ærlig så vil jeg betegne det meste av sugardating-scenen rett og slett for prostitusjon, uansett om de som betaler for "selskapet" ikke liker betegnelsen.
    Det var en eller annen blogger som var og ytret seg nylig om at om ikke mannen spanderte på dating, så ble det ikke flere dating-runder. Selv om det ikke er sex på første daten, så ligger det da temmelig nære prostitusjon. Om det blir sex på en slik date, så vil jeg si at juridisk sett har en trått over grensa for prostitusjon - det er sex mot vederlag, selv om vederlaget ikke er penger.
    Johan-Kr
    Slubbert
    Og så? Den der debatten har blitt gammelmoralistisk. Tvang, menneskehandel, misbruk? Ikke ok. Sex mot vederlag mellom to samtykkende og myndige parter? Kall det hva du vil, ser ikke problemet med det.
    G
    Gjestemedlem
    Johan-Kr
    So what? Er det virkelig fremdels andre enn bedehusgjengen og Ottar som henger seg opp i andre voksne menneskers frivillige relasjoner?
    C
    cruiser
    Det morsomme er at voss vann stort sett aldri har tjent penger på å selge nettopp vann. Dette er et marked som krever helt ENORME markedsføringsbudsjetter.
    Fenalaar
    Så lenge det er to voksne som fritt velger å ha sex, så er det ingen som har noe med hva de gjør med kroppen sin.
    Det jeg ikke synes noe om er dobbeltmoralen i dette - bare det er en rik mann som hoster opp nok penger, så er det greit. Eller om det er et norsk kvinnfolk i 50-60-årene som drar til afrika for å få seg mannebein i 17-20-års-alderen, så er det også greit. Ellers skal det hele kriminaliseres...
    Johan-Kr
    totte
    En sugarbabe krever visst også at den bemidlede daddyen er kjekk, verdensvant og Gud vet hva mer. En litt usjarmerende og grå daddy må altså gå hjem uten babe selv om han har penger nok. Det er vel diskriminerende, er det ikke? Man har riktignok lov til å diskriminere kunder så lenge det ikke er på bakgrunn av kjønn, rase, etnisitet og denslags, men når det gjelder bransjer som driver med grunnleggende og nødvendige tjenester kan det vel bli snakk om kontraheringsplikt?
    På vegne av flere,
    -totte
    H
    Hardingfele
    En av initiativtakerne var i radioen i dag og skulle (bort)forklare. Både menn og kvinner kunne være "sugardaddies", det var ikke noe ved annonsen som sa at dette kun gjaldt menn. Sa det fullstendig uten selv-ironi, med stort alvor og overbevist om at angrepene på selskapet var dypt urettferdige.
    Kanskje skrive "Sugarperson"?
    H
    Hardingfele
    Ærlig talt, har man først fått bestilt noen runder golf, så skal det spilles noen runder golf.
    Nordvestre del av USA sliter litt, og da blir det til slutt new-normal om det brenner i åssidene.
    J
    Jim I Hendriksen 2nd Edt.
    Enten eller der borte, samboer er på vei hjem fra Houston akkurat nå, 5 dager forsinket. Ingen golf spilling på henne siste ukene slik jeg har forstått det. Vannfast oppe på et høydedrag, stuck på et hotell.
