Er ikke det åpenbart?
https://oslohificenter.no/stereo/stromrens/nordost-qrt-qbase-8-mk-ii
http://servo.lv/en/nordost-qb8-and-furutech-ncf
Nordost tar 19000 kr for en strømskinne med stjernejord og en
motstand til 5kr mot jordreferansen. solid aluminium. Og intet annet.
Mange ord og minimalt reelt innhold. De sierfaktisk rett ut at den
ikke inneholder noe utenom en motstand(ground lift).
Og så planter Nordost ideen om at skinnens AC impedance er viktig i en strømskinne, noe som er et ikke-problem. Ved 50Hz som nettspenningen svinger med er AC motstand og DC motstand det samme. Dessuten er feks min nettimpedans fra veggen 0.3 ohm og 70cm 2mm2 leder i en strømskinne utgjør 0.006ohm, dvs 2%. Men det er riktigere å sammenligne 12 vs 14 AWG leder, forskjellen mellom disse utgjør 0.7%.. Og det skal liksom bety noe for lyden.. hallo!!.
Og så fortseter de med at skinnen er mekanisk tunet og annet vissvas, som om det har betydning, snake oil igjen.
By eliminating any form of in-line filtering or active circuitry we maintain the lowest possible AC supply impedance, while a
tiny lift in the earth impedance of all but one of the output sockets routes the signal grounds directly to the center of the star and the clean earth terminal. Clearly identified on the casework, this Primary Earth socket is at the center of your system’s performance, literally and metaphorically. It defines both the order in which you connect your components and also, their listening priority in your musical enjoyment, allowing you to further optimize the performance of your primary sources.
The sockets themselves are mounted on a customized frame plate and solidly constructed aluminum extrusion with machined end-caps that deliver a reassuring sense of substance. But the casework has far greater significance than that, the metal pieces and internal PCB (deliberately preferred to hard-wiring) constituting a single, mechanically tuned construction, designed specifically to enhance performance. Compare the musical performance of the QBASE-Mark II to the competition and you’ll hear just how effective this is.
Og konkurrentene her er Isotek polaris/Venus og de andre entry modellene fra 4190, og da får man i tillegg til stjernejord, RFI filter og overspenningsvern. Men se heller på denne til 995 som gjør det samme
Stikkontakt 2+4 m/skittenstrømfilter, overspenniningsvern og nettfilter | EMF Consult
, den er fra Danell og det er samme produsent som In-Akustif/OHC leverer til 7000 kr
https://oslohificenter.no/stereo/stromrens/in-akustik-reference-power-bar-ac-2502-sf8
og er identisk med denne til 99.5Euro.
https://www.akuryprodukte.ch/abschirmprodukte/danell-steckdosenleisten/
I kjent stil multipliserer OHC grunnprisen med 5-10 ganger.
Vil man absolutt ha en HIFI strømskinne i aluminium uten filter har man jo dette til en brøkdel av Nordostprisen
https://njal.no/Kabel/Strøm-filter/Supra/Supra-strømfordeler-M-BLOCK-MD06-EU-SP-MK335441-p0000002852
Å så kan man fortsette med disse absurditetene:
Nordost | QRT Power Products
https://oslohificenter.no/kabler/tilbehor/nordost-sort-lift
https://oslohificenter.no/stereo/stromrens/nordost-qrt-qv2
Nordostkablene til astronomiske priser gidder jeg ikke engang kommentere,Men det er kjent at det er rebrandede Temp-Flex/Molex kabler. Og jeg kan garantere at Boing ikke betaler 100 000 kr meteren for sine. ( kan nevne at tremeningen min jobber for Boing fabrikken)
Skal man diskutere lureri i hifi bransjen må Nordost høyt opp på listen, JA
