bluesbreaker
Hundeeier
REf 610 er ganske ekstremt.
Helt rått, men vi som har stereoanlegg i stua har neppe brukt for slike ressurser.
POWER OUTPUT: 600 watts continuous at 16 ohms from 20Hz to 20kHz. 1kHz total harmonic distortion typically 0.5% at 600 watts, below .05% at 1 watt.
Approximate actual power available at "clipping" 630 watts (1kHz). (Note that actual power output is dependent upon both line voltage and "condition" i.e.: if power line has high distortion, maximum power will be affected adversely
POWER BANDWIDTH:
(-3dB points) 15Hz to 150kHz.
FREQUENCY RESPONSE:
(-3dB points at 1 watt)
1Hz to 200 kHz. INPUT SENSITIVITY: 4.2V RMS balanced for rated output. (24dB Gain into 8 ohms)
INPUT IMPEDANCE: 200K ohms balanced.
OUTPUT: 4, 8, 16 ohms.
OUTPUT REGULATION: Approximately 0.8dB 16 ohm load to open circuit (Damping factor approximately 16).
OVERALL NEGATIVE FEEDBACK: 13dB.
POWER REQUIREMENTS: 105-125VAC 60Hz (210-250VAC 50Hz) 1700 watts at rated output, 2300 watts maximum, 800 watts at idle, 370 watts standby. TUBES REQUIRED: 8 Matched pair 6550C Power Output; 1-6550C Regulator; 1-6H30. Regulator Amplifier; 2-6550C Driver; 2-6NIP input, 1-6H30 Follower.
DIMENSIONS: 13.5" (34.3 cm) W x 23" (58.4 cm) H x (20.8" (52.8 cm) D. Handles extend 1.5" (3.8 cm) forward and rearward.
WEIGHT: 170 lbs. (77.2 kg) Net; Shipped in pairs, 495 lbs. (225 kg) per pair.
Og hva koster C-wing rør nå til dags??!!!
