https://www.head-case.org/forums/topic/13532-kaldas-research/?do=findComment&comment=806373
"First off, this is set nr.4 so I very much view it as a "work in progress" but...they are pretty awesome. From the first impressions and until now they keep reminding me of the SR-007. Clearly power hogs (I measured the system with stock cable at 160pf) too and a bit dark sounding. Now in my book this is a welcome reprise from all the bright models out there now. Doesn't mean the treble is subdued or anything like that, it is just not as apparent as with the L700 or 009's for instance. This also gives it a fuller sound and well...that bass.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
The cups are ported so the bass could have been compromised due to that but not so here, it's deep, tight and tuneful. It doesn't match a closed SR-007 but I frankly don't mind that...I can always grab my 007's if I want to listen to them. These are a bit more tuneful with more presence higher up. One of the first tracks I tried on them is the one which 009, 009S and 009BK all fail miserably at, but no issues here. They replicate the snare drum perfectly and same goes for everything else I've thrown at them.
The midrange is perfectly fine and really showcases the difference in mastering on some tracks. The soundstage is just about perfect, follows what the tracks should sound like and doesn't pull a HE90 on us. Not quite up to the layering of the 007's but then again...that is the gold standard. Overall they are very neutral and do what any transducer should do, get out of the way. For me the biggest compliment to any headphones is me willing to listen to them as well, I have a lot of headphones at hand. I've used these almost exclusively since I got them, only swapping out to do comparisons.
Now for fit and finish, I have no complaints. The headband is very sturdy with nice spring steel for the main span and they fit my head nicely. A bit snug but then again, I have a melon for a head.
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I did bend the arc a bit and now I can use them for hours at a time. The housing is attached to the earcups with a single M4 bolt and I did experience some rubbing there. This joint wasn't really supposed to move but for my use, they fit better that way so I place a nylon washer between the two parts and that has fixed this. I've already relayed this to Aumkar who should be arriving back home soon.
The only major issue I've had is with the cable or rather one of the connectors. One channel started to drop out and after some troubleshooting this was traced to the mini XLR plug. I bought some new ones and made a quick replacement cable this morning and now it works perfectly. To keep the cost down the mini XLR does work for this but yeah... I'd like something better but given the cost constraints I get why they use it. Same for the cable, getting anything which works for this is difficult and costly. The cable is still better than what Hifiman are using so yeah... I'm not too worried about that.
So over all, I'm very, very impressed and I will be working with Aumkar to see if we can't improve on these small issues.
