Det ser ikke ut til at uansett hvor mye formalkompetanse det skal være her inne så begriper de
ikke sammenhengen med støy fra last og hvor den aller helst skal.
Det handler overhode ikke om hvor mye en last trekker av strøm og spenningsfallet over en sikring,
men om returstrømmene,støystrømmene og nettimpedans.
De fremste som forsker på dette tenker returstrømmer og nettimpedans og resonanser,
altså "den første meter" sett fra lasten mot kilden som er den trafoen til netteier som en er tilsluttet.
http://ltu.diva-portal.org/smash/get/diva2:996537/FULLTEXT01.pdf
Selv i proffstudio verden tenker de på slikt vis.
Power systems for critical audio installations - REFLEXION-ARTS
Simple good practice, engineering and an understanding of the true system requirements can result in a safe, well behaved clean audio system that sits as a good neighbour on the power network.
In all cases and in every aspect our friend is a low impedance source. [Source being at the local point of equipment power line connection, not just the utility company’s transformer]. Fortunately for us the output of a power distributor’s step-down transformer is usually clean and has a very low impedance.
The average electrician is usually only trained and disciplined in supplying power to average appliances, much of what they do on a day to day basis does not apply to high power or critical audio systems. It is imperative that in their day to day work they follow the standard basic rules if only to absolve themselves of any liabilities. It is important that we understand that the usual requirement for cable choice in standard installations is operating temperature and the calculated constant load end of line voltage drop. This is balanced against profit from the job and the smallest acceptable cable section is most often applied to that circuit. There is no consideration by the electrician of the ability of the supply line to conduct interference back to source, pick up interference, or in many cases for the demands of unusual dynamic peak loads.
The currents, once filtered are not very high and are generally assumed to be easily filtered out, but this assumption is based on a good low impedance return path being available.
If the power supply is not of adequately low supply impedance we can get these currents failing to be adequately conducted (filtered) out and beginning to remain present in the lines, equipment chassis, or in the supply output. In the case of such units it is critical that a good low impedance power line is supplied if we are to avoid high frequency interference.
Og slik tenker netteier
https://www.hifisentralen.no/forumet/mitt-anlegg-og-billedtra-der/72643-ymirs-audiofile-liv-25.html
Det utstyr som lager støy gjør det (hovedsakelig) i form av at de trekken en forvrengt strøm. De slipper igjennom/ trekker strøm i bare deler av «sinusbølgen». Sett fra disse støykildene (ulineære belastninger) blir dette å betrakte som en ulineær strømkilde. En strømkilde «presser» forvrengt strøm tilbake mot forsynende nett. Så det at vi henger på en ulineær last i form av f.eks. en PC, frekvensstyrt motor o.l. medfører at vi tilnærmet «presser» en tilsvarende ulineær strøm mot nettet.
Den ulineære strømmen vi presser mot nettet, ser impedansen i nettet. Sett fra en abonnent, vil den første impedansen av betydning være kiosktransformatoren. Jo større transformatoren er, jo mindre er impedansen og jo lettere er det å «presse» tilbake den «forurensede» strømmen. Det som egentlig skjer, er at når den «forurensede» strømmen møter impedansen til matende nett, så gir det forurensede strømmen et «forurenset» spenningsfall som igjen forvrenger spenningen i matepunktet. Alle abonnentene tilknyttet samme kiosktransformator (samme nätstation) opplever omtrentlig den samme forvrengningen av matespenningen.
Dersom nettimpedansen inneholder induktanser og kapasitanser (og det gjør den alltid), så kan også resonansfrekvenser i nettimpedansen sammenfalle med en av støyfrekvensene og vi får ytterligere forsterkning (det er dette vi ser i Hellandsbygd).
Sannsynligheten for å få stygg spenning avtar som regel med lav nettimpedans (stor transformator). Men dette gjelder bare den siden som forurenset strøm kommer fra. I Hellandsbygd har vi (antatt) lite forurenset støy fra abonnentene. Slik støy er det smelteverket som lager. Har vi derimot mye forurenset strøm som trykkes mot nettet (fra abonnent mot nätstation) så er det, som sagt, en fordel at impedansen i matende nett er liten. Vi sier at nettet er «stivt» eller vi kan også si at nettet har stor kortslutningsytelse. Disse begrepene betyr i prinsippet alle at impedansen er lav og det er lett å kvitte seg med den forvrengte strømmen uten at dette gir forurenset spenning og problemer for naboene.
Selv de som lager nettfiltre EMC filtre som Schaffner etc. tenker slik,
og hvor de er fullstendig klarover at lav nettimpedans gir negativt sluttresultat.
Schaffner emc filter
ONfilter
Dette sier også Ncom.EMC filtre er ett lotteri,ofte ingen virkning eller også en forverring.
Så det at der ikke finnes noen teknisk forklaring på støy,nettimpedans og den første meter
(som sikring er en del av) er BS.
Tar en det helt ut kan sluttresultatet bli som her,se Ref.level.
Automatsikring
Så vi vi det helt ut og da blir det slik,selv på en kurs som allerede har lav nettimpedans.
Med en kurs med "høy" nettimpedans,ca. 0,9 ohm.
Mye returstøy fra stereo som gjør at det blir mange harmoniske som ikke holder forskrift.
Det kan se slik ut også,her fra dedikert 16A kurs.
Her er det mange strømmer som skal i retur,og det er ikke snakk om A,men mA,
og da kan sikringer og "den første meter" bety en del.
Hos meg virker det som om preamp og kilde påvirkes mest sammen med Hypex forsterker til sub,
ikke fordi Hypex er feilkonstruert eller defekt,men fordi den har lovpålagt emc filter som
helt etter boken forsterker støy som ligger i område supraharmonics,
dvs der dagens forskrift slutter å gjelde,2500 Hz og opp til 150kHz der EMC forskriften begynner
å gjelde.
Mannen til høyre,min saksbehandler i en klagesak gav meg ikke beskjed om å bytte tilbake
til automatsikring når vi diskuterte sikringer.
Her settes Elspec nettanalysator og en Hioki transient recorder opp hos meg
