X
X186841
Joda og han kunne også lære meg litt om det meste så jeg slapp å gå rundt å innbille meg ting.
Det er ikke verre enn innstilling til hobbyen, som er diametralt forskjellig.Du er ikke så lidt uforskammet. Har du aldrig haft en far som kunne opdrage lidt på dig?Er vel på tide med en ny diagnose, HiFiHypokondri.
Og de som har reelle problemer burde gå på produsentene av det ustabile utstyret eller ellevrandørene for å ta problemet ved roten.
Så jeg var litt nysgjerrig på hvilke strømforsyninger som brukes for å drive de instrumentene og hvilken forbedring som hadde blitt gjort der. Det var ikke vanskelig å finne ut: https://www.kepcopower.com/jqe-ligo.htmThe field “has exploded,” says Nergis Mavalvala from the Massachusetts Institute of Technology. “I’ve really been amazed at what we’ve been able to achieve. It’s staggering both on the astrophysics side, and the immense improvements to the instruments that have come about.”
Including that first discovery, a total of 23 confirmed gravitational-wave detections have been made to date across three observing runs. Within those, 20 have been black hole mergers, two have been neutron star mergers, and one is the suspected first known instance of a merger between a black hole and a neutron star. Each has been exciting in its own right, but the sheer volume of detections—moving from one a month to nearly one a week, thanks to upgrades to LIGO in 2018 and 2019 that improved its sensitivity—is hugely impressive. By some estimates gravitational-wave observatories could catch a merger every hour by 2023. “It’s hard to overstate how explosive the growth of gravitational-wave astronomy has been,” says Ben Farr of the University of Oregon.
https://www.kepcopower.com/specs/jqespecs.pdfKepco's JQE 25-20M power supplies were added during LIGO's (Laser Interferometer Gravitational-Wave Observatory) recent upgrade to significantly reduce the RF noise that was interfering with LIGO's measurements. Prior to the upgrade the power supplies in use had noise levels in the 180mV range, whereas the JQE replacements have noise levels of 3mV, a reduction of more than 98%. Kepco is delighted to have played a role in proving Einstein's general theory of relativity.
Men Asbjørn da. Det er jo ikke det samme som en forsterker som skal spille musikkFor hva det nå enn er verdt: Jeg leste en artikkel i Scientific American om LIGO, observatoriet som kan detektere gravitasjonsbølger fra den andre enden av universet: https://www.scientificamerican.com/article/the-gravitational-wave-revolution-is-underway/
https://www.kepcopower.com/jqephys.htm
3 mV RMS på 25 V forsyningsspenning er -82 dB rippel om jeg regner riktig. Alt de sier om hvilke strømkabler som brukes på nettsiden av PSU’ene er «detachable IEC-type 3-wire» for halfracks og «permanently wired» for fullracks.
Årets innlegg og jeg finner det merkelig hvis noen fortsatt forsvarer kabler etter detteNei, det er jo klart. Disse bølgene beveger seg bare med lysets hastighet gjennom apparaturen og gir utslag på ca 1/1000 protondiameter i lengdeendring av fire kilometer lange rør. Det regnes som verdens mest sensitive vitenskapelige instrument noensinne, men er selvsagt ingen match mot middelaldrende menns hørsel i et delvis reflekterende stuemiljø under ukontrollerte forhold.
https://spaceplace.nasa.gov/gravitational-waves/en/
https://www.ligo.caltech.edu/page/what-are-gw
https://www.ligo.caltech.edu/page/ligos-ifo
https://www.ligo.caltech.edu/page/ligo-technology
Bare hyggelig å være til hjelpTakk for denne bastante og opplysende informasjonen.Nei, naturligvis ikke.Mye bedre lyd i forsterkeren påstår noen med en ny strømkabel. Er dette riktig og hvorfor. Vis vedlegget 516484
Hvorfor?
En skikkelig forsterker har en skikkelig strømforsyning som filtrerer bort all mulig AC-dritt. Forsterkere kjører på DC og ser ikke rusket på AC-en, med et ikke veldig relevant unntak av enkelte rørforsterkere som kjører AC på glødespenningen. Men til og med på disse må AC-en og konstruksjonen være usedvanlig råtten om du skal kunne høre dårlig lyd som følge av støyende AC.
Knitring som følge av mekaniske termostater og desslike vil likevel en strømkabel med filter kunne fikse. Men fraværet av knitring er definitivt ikke det samme som bedre lyd.
Big Big Big mistake.... dette kan jo måles og kvalifiserer dermed IKKE...Nei, det er jo klart. Disse bølgene beveger seg bare med lysets hastighet gjennom apparaturen og gir utslag på ca 1/1000 protondiameter i lengdeendring av fire kilometer lange rør. Det regnes som verdens mest sensitive vitenskapelige instrument noensinne, men er selvsagt ingen match mot middelaldrende menns hørsel i et delvis reflekterende stuemiljø under ukontrollerte forhold.
Ja-Men, jord1 er da beviselig flad-ere mellom polene enn over ekvator..... men nå som ozonhullerne over ant-og-tarktis snart er tettet må jo atomer og annet quark finne nye vejer i molekylerne....Det skjer nok omtrent på den tiden Flat Earth Society kan føre bevis for sine påstander.
Mange af de forskelle vi hører på diverse komponenter er helt uforklarligt. Hvorfor er der så store forskelle på modstande, kondensatorer, kabler etc.Svaret ligger muligens mer på psykoakustikkplanet enn rent elektriske forhold, for de som nistirrer på Ohms lov.
Semantic forstyrrelse i hjerne barken?Mon tro hvorfor denne tråden oppleves helt lik denne:?
The Flat Earth Society Wiki | HomePage
Den forsto jeg ikke. Psykoakustikk er faget om hvordan lyd oppleves. F eks at øret er mer følsomt ved 3 kHz enn ved 30 Hz, eller at lavereordens forvrengning i større grad maskeres av grunntonen enn høyereordens.Svaret ligger muligens mer på psykoakustikkplanet enn rent elektriske forhold, for de som nistirrer på Ohms lov.
Det gjør de jo stadig vekk: produserer påstålige løgner for å 'bevise' at myndighetene lyver.Det skjer nok omtrent på den tiden Flat Earth Society kan føre bevis for sine påstander.
Venter på innhold her:Den forsto jeg ikke. Psykoakustikk er faget om hvordan lyd oppleves. F eks at øret er mer følsomt ved 3 kHz enn ved 30 Hz, eller at lavereordens forvrengning i større grad maskeres av grunntonen enn høyereordens.Svaret ligger muligens mer på psykoakustikkplanet enn rent elektriske forhold, for de som nistirrer på Ohms lov.
Den opplagte forklaringen på hørbare forskjeller mellom signal- og høyttalerkabler er små eq-utslag drevet av LCR-egenskapene i kablingen og impedansene i hver ende. Det er en dyr og lite effektiv eq-funksjon, siden utslagene bare er brøkdeler av en dB og brukeren ikke har kontroll på ved hvilke frekvenser de oppstår, men når det blir hørbare avvik tilsier psykoakustikken at det gjerne oppleves som «noe» i diskanten siden øret er mest følsomt der. Det er ikke noe problem å beregne disse effektene, og til og med jeg er i stand til å høre dem hvis avvikene blir store nok.
Med strømkabler er det ikke engang noen plausibel virkningsmekanisme, ingen dokumentert effekt, og min personlige erfaring er også at det ikke eksisterer noen hørbare forskjeller. Hvis det ikke eksisterer noen forskjell på det elektriske planet vil det heller ikke være noen forskjell i den fysiske lyden, og det hjelper ikke å påberope seg «psykoakustikk». Psykologi er noe annet.
Der er åbenbart mange der kan høre forskel selvom der ikke er forskelDer bliver meget bedre lyd med et godt strømkabel. Men der er mange muligheder og det er at prøve sig frem. Om du kan høre en forskel kan du kun selv afgøre. Nogle her på Hifisentralen kan ikke høre forskel og jeg fatter det ikke, fordi hos mig er det så nemt. Men du må så vælge, vil du lytte til dem, der ikke kan høre... , eller os der kan.Mye bedre lyd i forsterkeren påstår noen med en ny strømkabel. Er dette riktig og hvorfor. Vis vedlegget 516484
For nogle, skal der gøres ting ved anlægget, som de ikke kan høre, men så kan de måske ved den tredje ting.
Jeg har for kort tid siden indkøbt 3 net kabler der bare er fremragende, og de har løftet mit anlæg op til nye højder og jeg nyder bare musikken, og skal hele tiden finde en ny cd frem, og den er blevet så meget bedre.
Jeg vil arbejde mere med strømmen hos mig, da det har så meget at sige for lyden.
Kanskje lidt pinligt. Vil dog pointere at det er omkring 6 år siden. Anlægget er forbedret på flere punkter siden det. Desuden havde vi ikke styr på netfasen dengang. Anlægget var koldt hver gang og havde stået minimum 3 uger i et andet rum. Gik tid og frembragte stress når det skulle sættes op hver gang. Nogle drak også for meget øl de aftener. Det var i et overdæmpet lokale i Avedøre eller husker jeg galt Sven Palvig?Der er åbenbart mange der kan høre forskel selvom der ikke er forskelDer bliver meget bedre lyd med et godt strømkabel. Men der er mange muligheder og det er at prøve sig frem. Om du kan høre en forskel kan du kun selv afgøre. Nogle her på Hifisentralen kan ikke høre forskel og jeg fatter det ikke, fordi hos mig er det så nemt. Men du må så vælge, vil du lytte til dem, der ikke kan høre... , eller os der kan.Mye bedre lyd i forsterkeren påstår noen med en ny strømkabel. Er dette riktig og hvorfor. Vis vedlegget 516484
http://kbh-hifi.dk/wordpress/wp-content/uploads/2015/02/140208-Klubmøde-Kabler.pdf
Jeg mener man skal finlytte i ens eget hjem, på sit eget anlæg og velkendt akustik. Netfasen skal altid være korrekt.^ Det er åpenbart mulig. Det virker som flere av de som formodentlig var til stede er like hellig overbevist om egen hørsels ufeilbarlighet som de alltid har vært.
Helt klart kan det ske, hvis man sugerer sig selv fordi man ønsker der skal være en forskel.Man må tro som det heter seg i religiøse kretser. Derfra blir troen raskt til sannhet... Det er skrevet bøker for dette......
Jeg var ikke tilstede ved det omtalte møde, men jeg undrer mig over, at dette kommer op igen og igen. Ligger der misundelse over, at vi kan lytte forskel. Naturligvis spiller psykologien en rolle.Kjære danske venner. Historien forteller at det ble hørt tydelige forskjeller på kabler som ikke var tilkoblet. I tillegg forklares at det var på et dårligere anlegg enn dagens, nettfasen var ute av kontroll, anlegget var kaldt, deltakerne stresset, halvfulle og det hele foregikk i et overdempet rom. Likevel hørte man forskjell.....
Finnes det et lite snev av erkjennelse om at det etter en slik opplevelse er mulig psykologien kan spille selv gullører et puss?
Det var i Avedøre, som var et øve rum for musikkere. Det var overdæmpet, hvilket var tydeligt, da vi havde en guitarist og en sangerinde til at optræde. Hun klagede over den akustik og der blev drukket meget vand.Kanskje lidt pinligt. Vil dog pointere at det er omkring 6 år siden. Anlægget er forbedret på flere punkter siden det. Desuden havde vi ikke styr på netfasen dengang. Anlægget var koldt hver gang og havde stået minimum 3 uger i et andet rum. Gik tid og frembragte stress når det skulle sættes op hver gang. Nogle drak også for meget øl de aftener. Det var i et overdæmpet lokale i Avedøre eller husker jeg galt Sven Palvig?Der er åbenbart mange der kan høre forskel selvom der ikke er forskelDer bliver meget bedre lyd med et godt strømkabel. Men der er mange muligheder og det er at prøve sig frem. Om du kan høre en forskel kan du kun selv afgøre. Nogle her på Hifisentralen kan ikke høre forskel og jeg fatter det ikke, fordi hos mig er det så nemt. Men du må så vælge, vil du lytte til dem, der ikke kan høre... , eller os der kan.Mye bedre lyd i forsterkeren påstår noen med en ny strømkabel. Er dette riktig og hvorfor. Vis vedlegget 516484
