Da denne DACen var ny for meg og jeg ikke fant noe om den her på sentralen lager jeg like gjerne en liten tråd. Er det noen andre som har den så del gjerne noen erfaringer.
Satte nettopp en bestilling på denne selv i dag. Har lest litt om den i romjula og den virker spennende. Har frem til nå brukt en Hegel HD25 i hodetelefonoppsettet i lang tid sammen med en Bryston BHA-1. Jeg er ikke så kjent med RME men skjønner at de har lang fartstid i pro markedet. DSP og EQ delen i denne DACen virker også lovende.
Link til produsent
RME: ADI-2 DAC
Fra Hedfonics.com
Our Verdict
I can’t think of any other desktop DAC/amp combo that would be easier to recommend in 2018. There is no magic involved in the RME ADI-2 DAC: no proprietary filters, no patented exclusive circuits, no unordinary connections and most importantly no voodoo buzz words. This is an extremely down-to-earth device that has just been given extreme thought, massive experience and great attention to detail. It’s not the supplier’s chip that makes a great device, it is how you use the tools.
The ADI-2 DAC is technically marvelous, regardless of whether you want to dive into the long feature list or not. I do recommend you do, though, because the equalizer with its many save slots, the customizable loudness function, the tight crossfeed, various DA filters and many controls to test your whole audio chain just keep on giving and giving. Despite the huge amount of functions, the software is extremely stable and hasn’t failed me once.
While the Phones output provides clean and linear amplification for even power hungry headphones, the new IEM output might just have reached a new reference level. Of course, the device will work just as well as a standalone DAC in case you want to connect some warm tubes with the line-out. The channel-specific dual EQ or quick bass/treble adjustments can work wonders for a speaker setup.
RME ADI-2 DAC Specifications
Digital Inputs
General
Lock Range: 28 kHz – 200 kHz
Jitter suppression: > 50 dB (2.4 kHz)
Accepts Consumer and Professional format
SPDIF coaxial
1 x RCA, according to IEC 60958
High-sensitivity input stage (< 0.3 Vpp)
AES/EBU compatible (AES3-1992)
SPDIF optical
1 x optical, according to IEC 60958
ADAT compatible
Analog Outputs
XLR
Output level switchable +19 dBu, +13 dBu, +7 dBu, +1 dBu @ 0 dBFS
Signal to Noise ratio (SNR) @ +7/+13/+19 dBu: 117 dB RMS unweighted, 120 dBA
Signal to Noise ratio (SNR) @ +1 dBu: 115,4 dB RMS unweighted, 118,9 dBA
Frequency response @ 44.1 kHz, -0.1 dB: 0 Hz – 20.2 kHz
Frequency response @ 96 kHz, -0.5 dB: 0 Hz – 44.9 kHz
Frequency response @ 192 kHz, -1 dB: 0 Hz – 88 kHz
Frequency response @ 384 kHz, -1 dB: 0 Hz – 115 kHz
Frequency response @ 768 kHz, -3 dB: 0 Hz – 109 kHz
THD @ -1 dBFS: -112 dB, 0.00025 %
THD+N @ -1 dBFS: -110 dB, 0.00032 %
THD @ -3 dBFS: -116 dB, 0.00016 %
Channel separation: > 120 dB
Output impedance: 200 Ohm balanced, 100 Ohm unbalanced
Chinch
As output XLR, but:
Output: 6.3 mm TS jack, unbalanced
Output level 6 dB lower than XLR (-5 dBu to +13 dBu @ 0 dBFS)
Signal to Noise ratio (SNR) @ +13 dBu: 117 dB RMS unweighted, 120 dBA
Signal to Noise ratio (SNR) @ +1/+7 dBu: 114/116 dB RMS unweighted, 117/119 dBA
Signal to Noise ratio (SNR) @ -5 dBu: 109 dB RMS unweighted, 113 dBA
Phones
As Cinch but:
Output: 6.3 mm TRS jack, unbalanced, stereo
Output impedance: 0.1 Ohm
Signal to Noise ratio (SNR) @ +22 dBu: 117 dB RMS unweighted, 120 dBA
Signal to Noise ratio (SNR) @ +7 dBu: 116 dB RMS unweighted, 119 dBA
Output level at 0 dBFS, High Power, load 100 Ohm or up: +22 dBu (10 V)
Output level at 0 dBFS, Low Power, load 8 Ohm or up: +7 dBu (1.73 V)
THD @ +18 dBu, 32 Ohm load, 1.2 Watt: -110 dB, 0.0003 %
THD+N @ + 18 dBu, 32 Ohm load: -107 dB, 0.00045 %
THD @ +14 dBu, 16 Ohm load, 0.94 Watt: -110 dB, 0.0003 %
Max power @ 0.001% THD: 1.5 W per channel
IEM
As Phones, but:
Output level at 0 dBFS: -3 dBu, 0.55 V
Signal to Noise ratio (SNR) @ -3 dBu: 115 dB RMS unweighted, 118 dBA
Max power, 8 Ohm, 0.001% THD: 40 mW per channel
Digital
Clocks: Internal, SPDIF In
Low Jitter Design: < 1 ns in PLL mode, all inputs
Internal clock: < 800 ps Jitter, Random Spread Spectrum
Jitter suppression of external clocks: > 50 dB (2.4 kHz)
Effective clock jitter influence on DA conversion: near zero
PLL ensures zero dropout, even at more than 100 ns jitter
Additional Digital Bitclock PLL for trouble-free varispeed ADAT operation
Supported sample rates for external clocks: 28 kHz up to 200 kHz
Internally supported sample rates: 44.1 kHz up to 768 kHz
General
Included power supply: external switching PSU, 100 – 240 V AC, 2 A, 24 Watts
Standby power consumption: 120 mW (10 mA)
Idle power consumption: 7 Watts, Max. power consumption: 18 Watts
Idle current at 12 V: 570 mA (6.8 Watts)
Dimensions (WxHxD): 215 x 52 x 150 mm (8.5″ x 2.05″ x 5.9″)
Weight: 1.0 kg ( 2.2 lbs)
Temperature range: +5° up to +50° Celsius (41° F up to 122°F)
Relative humidity: < 75%, non condensing
Link til produsent
RME: ADI-2 DAC
Fra Hedfonics.com
Our Verdict
Digital Inputs
General
SPDIF coaxial
SPDIF optical
ADAT compatible
Analog Outputs
XLR
Chinch
As output XLR, but:
Phones
As Cinch but:
IEM
As Phones, but:
Digital
General
