li ´ll trip down memory Lane: Merk: Q7II modellen.
- SANSUI XR-Q7II ¥77,000(1982年頃)
Model: record player
Drive system: Electronically controlled direct drive
Motor Quartz PLL Servo FF Coreless motor
Speed: 33 1/3, 45rpm
Turntable: 33 cm aluminum die cast, 1.7 kg
Wow and flutter: 0.009% or less (WRMS)
SN ratio 80dB or more (DIN-B)
Start-up characteristics 1 second (120°) at33 1/3rpm
Rotational speed deviation; ±0.002%
Temperature characteristics: 0.00003%/℃
Load characteristic: 0%
Tone arm: Static balance type Optimal support point method Straight arm
Effective length: 245mm
Overhang: 16mm
Offset angle: 22°
Conformity cartridge own weight: 4g-9.5g
Height adjustment range ±3 mm
Fully automatic mechanism Auto lead-in
Auto return
Auto repeat
With manual lifter
Rated power consumption: 8W
External dimensions: Width 490 x height 192 x depth 430 mm
Weight: 11.8kg
Attached straight type exchange arm
