Aha, skjønner. jeg prøver ut denne nå etter ditt forslag:
SET UP
Output setup (1st speaker setup)
Main Out / Main speakers:
Custom
Line out / sub speakers:
1 Custom sub
Setup main speakers
Routing:
Crossover - Filter - High Pass Filter
Level (dB):
0 - Filter Type - BW 2nd Order
EQ:
Neutral - Frequency (Hz) - 50
Enable limiter:
Limiter off
Enter Distance for main speakers:
L/H cm - 320
Setup subwoofer output
Routing:
Crossover - Filter - Low Pass Filter
Level (dB):
-12 - Filter Type - BW 2nd Order
EQ:
Neutral - Frequency (Hz) - 80
Output level control:
Regulated
Enable limiter:
Limiter on
Subwoofer delay settings:
Sub distance cm - 325 - Amplifier delay ms - 0
SET UP
Custom
1 Custom sub
Setup main speakers
Routing:
Level (dB):
EQ:
Enable limiter:
Limiter off
L/H cm - 320
Routing:
Level (dB):
EQ:
Regulated
Enable limiter:
Limiter on
