Medisin og helse Corona
  • weld77
    Sturgis var superspreader i fjor. I år var forskerne der, fordi det var så interessant å følge hvordan smitten ble spredt i motorsykkelfart gjennom USA i fjor.
    Hvem skulle trodd noe slikt?
    But while Southern states have been the main drivers of this surge thus far, the recent spike in cases in South Dakota warrants special concern.
    The state more broadly has witnessed a 686.8 percent increase in daily case counts over the past three weeks, currently more than 10 times the nationwide rate. Meade County’s post-Sturgis uptick is certainly a contributor to this state-level increase, but neighboring counties have experienced a sharp incline in cases, too—ranging from a 1,900 percent increase in the past three weeks in Butte to a 1,050 percent increase in Lawrence.
    Dr. Shankar Kurra, vice president of medical affairs at Monument Health in Rapid City, told The Daily Beast he was living through a nightmare on repeat.
    “We knew this was going to happen,” Dr. Kurra said. “It happened last year. It was just playing a reboot of last year pretty much.”
    ellers i en noe mer opplyst del av US of A
    Take Lollapalooza, for instance. The largely (but not entirely) outdoor four-day music festival in Chicago was held July 29 through Aug. 1, but catered to a very different demographic than the Sturgis Motorcycle Rally.
    Despite hosting over 100,000 individuals on each day of the festival, all signs suggest that Lollapalooza didn’t result in a superspreader event. This may be thanks to the fact that Lollapalooza organizers—working in active partnership the Chicago Department of Public Health (CDPH)—required either proof of vaccination or a negative COVID-19 test within 72 hours prior to attendance, and 90 percent of attendees were fully vaccinated. Moreover, masks were required in indoor spaces for the last two days of the event (once more, under the advisement of the CDPH).
    Unlike Lollapalooza, which was guided by health officials in enacting and enforcing a multi-layered COVID-19 safety protocol, the Sturgis Motorcycle Rally took place in a state where government has been largely apathetic in its pandemic response. In late July, mere weeks prior to the rally she attended herself, Gov. Kristi Noem went so far as to say that she had “no plans” to encourage vaccination among her constituents.
    Får håpe de har mye kumedisin på lager, det er visst greia.
    ptb
    At Sturgis Ralley ville være en smittedigel burde ikke overraske noen. I hvertfall ikke for de som har vært der tidligere.
    erato
    Pussig nok står det ingenting om han var vaksinert i artikkelen. Men det gir seg vel trolig selv.
    Som jeg så en amerikaner skrive: Jeg har gitt opp de uvaksinerte, og trøster meg med at de i det minste ikke fikk innvollsparasitter.
    kasol
    Døde pga mangel på ICU i Texas - ikke av Covid
    "CBS This Morning" lead national correspondent David Begnaud reports on a tragic case: A U.S. veteran in Bellville, Texas, who couldn't get the medical attention he needed because of a lack of space.
    weld77
    Belville, Texas er ca 1 times kjøring unna Houston hvor faktisk verdens største sykehuskompleks, Texas Medical Center, ligger.
    Som et lite fun fact har dette sykehuskomplekset med over 106.000 ansatte ca samme BNP som Island.
    Da er det fullt.
    lars_erik
    Hades
    35000 studenter skal testes i Trondheim. Situasjonen er jo svært alvorlig der, og som nevnt før bes studenter avstå fra sosial omgang. Hvor dette alvoret ligger, er ikke helt lett å se. Tallet på innlagte i Trøndelag er fortsatt 4, noe det har vært lenge. Hvem som smittes viser seg igjen å ha langt større betydning enn hvor mange. Det som er forandret denne gangen, er at kommunene rundt Trondheim sitter stille i båten. Ingen av de har hverken munnbindpåbud eller hiver hele klasser og skoler i karantene. Ingen anbefaler heller å unngå reiser til trøndehovedstaden. De evne å holde hodet kaldt, noe som tilsier at alvoret nok finnes mest i hodene til kommuneledelse og helsetopper i Trondheim, mens det i det virkelige liv ikke anses som spesielt truende.
    Når jeg åpnet mailen i dag så lå det en update fra Japan der og jeg klippet ut dette:
    Japan is now under 5th wave of COVID-19 (this time with Delta variant), and we are having about 25,000 new infection cases per day.
    About 50% of adult over 12 years old got vaccinated but we do not see any lights at end of tunnel.
    ......... så det var kanskje ikke så oppløftende som man kunne håpet på.
    Om 50 % av Japans befolkning på 126 millioner er vaksinert, så er det fortsatt en uvaksinert befolkning på 63 millioner klemt sammen på de små øyene. Det har jo et visst potensiale.
    K
    Khanate
    Når vil vi begynne å se en positiv effekt av alle vaksinene? Snipp fra NRK under
    morbid
    Hvis du ser på antall smittede og sykehusinnleggelser/dødsfall og sammenligner med før vaksine. Så kan det tenkes at en med din IQ vil se et mønster
    Harry Stoteles
    Se hvor tett antall smittede og antall innlagte følger hverandre helt frem til ca. juni i år, da det begynte å bli fart på vaksineringa:
    Skjermbilde 2021-08-30 kl. 12.12.51.png Skjermbilde 2021-08-30 kl. 12.12.56.png
    Usikker på hvorfor X-aksen ikke har like intervaller, men tidsrommet er i alle fall det samme.
    Vi bør også ha i mente at det er et par-tre uker forsinkelse mellom smitte og innleggelse, så antall innlagte kan fortsatt stige fremover. Men som vi har snakka om før er det hovedsakelig eldre som blir innlagt sjøl om de har fått vaksine. De unge ser ut til å klare seg bedre.
    Det er bare å kjøre på med vaksineringa. Ingen grunn til å vente.
    K
    Khanate
    Greit nok, men nå var den innledende fortellingen at vaksinene var det som skulle gi oss kontroll over smitten. Før i verden snakket man om sykdom, nå snakker man om smitte. Og det er altså ikke jeg som lager så mye fuss om denne smitten. Og smittetallene er det eneste elementet som bidrar til å holde pandemien levende i befolkningen. Hvilket grep skal vi ty til nå som smitten øker? Munnbind? Enda flere vaksiner? Enda større avstand mellom folk? Eller skal vi gjøre som danskene og bare runde av hele greia?
    morbid
    Planen er jo ganske åpenbar, det skal åpnes når vaksinasjonsgraden blir tilstrekkelig, så hvis du vil bidra til hurtigere gjenåpning, ta vaksine.
    Danskene leder ganske klart enda, 72% av befolkningen fullvaksinert, mot noen og 50% i Norge
    R
    rr30629
    Når alle har fått tilbud om vaksine så er det på tide å ta en danske. Da må det bli slik at er du litt uggen hold deg hjemme, er du ekstra uggen ring legen. Akkurat slik det alltid har vært ellers i livet.
    Reaksjoner: MML
    lars_erik
    Hades
    Begynner å lure på om vi kommer dit igjen. Nå har jo argumentene dreid mot at siden "så mange" er uvaksinerte, vil man likevel kunne få et for stort press på helsevesenet. Det er jo selvsagt et vikarierende argument, da grunnen i virkeligheten er at man rett og slett ikke tør eller vil tilbake til et normalt liv- så lenge covid-19 eksisterer.
    R
    rr30629
    Spørsmålet blir jo om det argumentet fortsatt vil brukes den dagen det ikke er flere som vil/kan vaksinere seg og vi står der med ca.90% dekning og ny regjering.
    K
    Khanate
    At formålet skulle være full vaksinering forsto jeg tidlig. Er bare litt usikker på motivasjonen bak dette. 60 mann på sykehus i dag, jeg antar at brorparten er godt over barndom, ungdom og studier. Da er det sikkert på høy tid med vaskinering av de minste.
    lars_erik
    Hades
    Støre har uttrykt bekymring for det "høye" antall uvaksinerte, som vil kunne føre til press på helsevesenet. Regnestykket blir jo selvsagt helt feil; 500 tusen uvaksinerte skal altså medføre høyere antall innlagte enn da over 5 millioner var uvaksinerte. Men frykten rår grunnen. "Man vet jo aldri."
    Politikeres, helsemyndigheters òg folks evne til å tenke klart og logisk har jeg for lengst gitt opp.
    morbid
    Motivasjonen er vel de som enda ikke har fått en dose, de som ikke er fullvaksinerte og ikke minst de 50-100 tusen som av ulike grunner har redusert immunforsvar.
    Harry Stoteles
    Det er riktig det. Det var et håp om at vaksinering skulle føre til flokkimmunitet og dermed holde smitten i sjakk. Men så viste det seg å være litt overoptimistisk, for fordi Delta-varianten er så mye mer smittsom enn de andre variantene, og fordi det fortsatt er en del folk som ikke vil vaksinere seg. Jo flere som ville vaksinert seg, jo større ville sjansen vært for å få dette til.
    Som vanlig er i forskning og politikk må man nesten endre kartet når man oppdager at kart og terreng ikke stemmer overens. Det er ikke så mye annet man kan gjøre. Og som de fleste her inne er enig i er smitte ikke lenger den viktigste målestokken for å vurdere åssen denne pandemien går nå.
    I min verden (personlig og i min omgangskrets) er smittetallene stadig mindre relevante. Det er hva smitten fører til, eller ikke fører til, som er det viktige.
    Å begrense smitte og øke folks motstandsdyktighet mot sykdommen.
    K
    Khanate
    Så det Høie & Co holder på med nå er en kampanje for å motivere de siste etternølerne til å ta vaksinen? Genialt
    Jeg vet ikke hvilken «fortelling» du har hørt, men den jeg hørte fra starten av var at vaksinene er designet for å beskytte mot alvorlig sykdom og at man var usikre på i hvor stor grad de ville beskytte mot smitte. Derfor var det litt usikkert i hvilken grad vaksinerte fortsatt måtte etterleve smittevernstiltak. Det ble også diskutert i denne tråden om du gidder å bla tilbake.
    Det er også min oppfatning at Høie, Stoltenberg, Guldvog, Nakstad etc snakket mye om smittetall for et år siden, mens nå er de tallene mindre viktige. Det er kanskje riktigere å si at nå snakker man ikke så mye om smittetall lenger.
    Harry Stoteles
    Det er riktig, men på et tidspunkt ble det også spekulert på om det kunne gå mot flokkimmunitet eller ikke. Nakstad helte mot et forsiktig "det kan vi håpe på", som viste seg å være å ta litt hardt i.
    R
    rr30629
    Sentralt snakker man ikke så mye om smittetall men i noen kommuner og i media så er man fortsatt veldig opptatt av dette tallet. Er mitt inntrykk.
    K
    Khanate
    Minner om tallet ARR (absolutt risiko reduskjon) som ligger i området 1-1,3% for de ulike vaksinene. Alle som befinner seg i risikosonen har garantert fått tilbud om vaksine nå. De som står igjen nå befinner seg langt unna noen som helst risiko. Kanskje på tide å slutte å forsvare tiltak som ikke gir mening?
    Det viser seg at det å ha gjennomgått covid gir betraktelig bedre beskyttelse enn vaksinene (ref en nylig studie fra Israel som dere sikkert har fått med dere). Dermed burde dette være fokuset for unge og friske og andre som ikke er i risikosonen. Se til helvete å få de smittet før vinterkulda setter inn. Men nei, Høie ønsker kontroll over smitten, og han gir seg ikke på tørre møkka.
    R
    rr30629
    Akkurat dette kan jeg være litt enig i, nå driver vi med selvpining og skyver det foran oss. Det er bare å få fart på vaksineringen av de yngre.
    morbid
    Men det er jo ganske naturlig, når fhi og direktorat har gitt føringer for at elever og studenter skal testes ut av karantene, så er man avhengig av å ikke få for mange smitta samtidig slik at dette faktisk er praktisk mulig. Samtidig vaksinerer man jo for fullt, begge deler krever helsepersonell som man pre corona ikke hadde gående å slenge. De må hentes fra en plass uten at dette nevneverdig går ut over andre oppgaver.
    R
    rr30629
    Det var derfor de fikk en prioriteringsliste før helga.
    morbid
    Hjemmetesting av elever et par ganger i uken som både Oslo og Trondheim har tatt til orde for vil nok lette presset på kommunene betydelig, da vil smittetall bli mindre vesentlig.
    K
    Khanate
    Det er ikke mange dager siden Høie holdt frem at han ønsket å få kontroll over smitten. Det var vel i samme pressekonferansen hvor han ga rom for lettelser i smittesporingen
    lars_erik
    Hades
    Nettopp. Tvetydige signaler, som medførte at alle fikk "sitt". Følgen er jo selvsagt anarki.
    lars_erik
    Hades
    Nå har antall innlagte økt til 79. Det vil nok meføre alvorlige ansikt og dyp bekymring fra politikere og helsetopper. At antall på respirator er stabilt på 12, vil neppe ha noen betydning. Samme med at innleggelsestiden er bortimot halvert fra tidligere. Åpningen blir utsatt, og stadig flere kommuner vil innføre inngripende tiltak. At veien ut av dette er vaksiner er jo selvsagt åpenbart, men like åpenbart er det at det bør kombineres med å la ungdom smittes raskest mulig. Resmitte er svært sjelden, så da vil vi være ferdige med "smitte" i løpet av kort tid. Siden det er så åpenbart, vil det selvsagt aldri bli offisiell politikk; mye bedre å tvære det ut, slik at toppen kommer til vinteren. Da vil vi jo få langt flere innlagte og økning i dødsfall, som jo er mye bedre.
    Øhhh, på hvilken måte mener du det er bedre å bli smittet med et virus som vi vet kan være dødelig for sårbare individer fremfor å bli vaksinert med en dokumentert trygg vaksine? For meg virker det litt snodig å bli «beskyttet» ved å gjennomgå sykdommen man skal «beskyttes» mot.
    K
    Khanate
    Til de som mener at vaksineringen går alt for seint. 70,2% prosent av alle over 18 år er fullvaksinert (to doser), og 90% har fått minst en dose.
    Jeg tror vi vil oppleve at en del bare ønsker en dose av den grunn at første dose ikke gav mersmak. Så om vi skal øke vaksinedekningen i nevneverdig grad så må vi nok gå løs på de unge. Jeg antar dette går lett. En sykesøster dukker opp på skolen, og vips alle er vaksinert.
