Rouge med ny pre, RP-5!
[FONT=Verdana, Arial, Helvetica, sans-serif]
General Features:[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]
[back to top][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]
- Four tube mu-follower design
- Ten function remote control
- VFD display
- Home Theater bypass/Unity gain inputs
[FONT=Verdana, Arial, Helvetica, sans-serif]- Five pairs of inputs (Line1-4, Phono, or Line 1-5)
[/FONT]- Two pairs of variable outputs
- One pair of fixed outputs
- Processor loop
- Heavy duty gold plated RCA inputs
- Machined aluminum faceplate and knobs
- Tube based headphone amp
- Home Theater bypass input
- 40 - 60 dB gain phono stage
- RIAA equalization within 0.1 DB
- User adjustable cartridge loading
[FONT=Verdana, Arial, Helvetica, sans-serif]- Massive power supply
[/FONT][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]
[FONT=Verdana, Arial, Helvetica, sans-serif]- Slow start turn on sequencing
- Auto mute at turn on/turn off
[/FONT]- Detachable IEC power cord
- Fully tested, burned in and auditioned
- 3 year limited warranty (6 months on tubes)
- Proudly hand crafted in the USA!
[/FONT]
Specifications:[/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]
- Tube complement: 4 x 12AU7/ECC82 tubes
- Frequency response: 1Hz – 100KHz +/- 1 dB
- THD: <0.1%
- Gain line stage: 10 dB
- Rated output: 1V
- Maximum output: 27V RMS
- Output impedance: 500 Ohms
- Maximum output 27V
- Gain phono stage: 40dB, 50dB, 55dB, 60dB
- RIAA accuracy: +/- 0.1 dB
- Dimensions: 18.5 ”W X 4.5 ”H X 14.5” D
- Weight 30 pounds
- Shipping weight 45 pounds
- Power requirements 115/230V – 50/50Hz
[/FONT]
Någon som hört eller testat?
