EOS 5 Specifications:
• Type:3-way, Linear phase, floor stander.
• Tweeter:1 Pcs.1.14” / 29mm, Beryllium Dome
• Midrange:1 Pcs.6.5” / 165mm, TPCD-Cone (With Gryphon proprietary impulse optimizer ring)
• Woofer:2 Pcs.9.5” / 240mm, TPCD-Cone (With Gryphon proprietary impulse optimizer ring)
• Principle: Ported. (Line-dampened, Linear Impulse)
• Frequency response:20 - 40.000 Hz (+/-2dB)
• Sensitivity: 90dB @2.83V
• Impedance:4 Ω (2.9 Ω min. @ 80Hz)
• Crossover:500 Hz / 2.5 KHz (2nd order / 4th order, Progressive rising slope
• Adjustments:>12KHz - Switch: 0dB, +2dB, +3dB (off-axis dispersion)
• Feet:Adjustable spikes with integrated dampers (Removable)
