Litt om den brukte SMPS denne gang som ikkje holder mål... og ein som er brukt tidligere i samme setting med PeeCeeBee V4H.
Assembled 1500W LLC Soft Switching Power Supply Board ±50V 60V 70V 80V For Amp
Vis vedlegget 823227
Spec:
Input voltage: AC200-240V ( not support AC100-AC120V input )
Output voltage: ±45V,±50V,±55V,±60V,±65V,±70V,±75V,±80V for choose
Independent 12V/0.5A
Auxiliary +-12V/0.5A
Voltage regulation accuracy: ±10% for main no-load, ±3% for load; ±15% for independent no-load (for AC220V input)
Continuous power: 600W (continuous operation at 25°C ambient temperature)
Rated power: 1000W (25 °C ambient temperature can work continuously for about 5 minutes, long-term work plus fan cooling)
Instantaneous power: 1500W (power generated during dynamic signal impact, less than 100 megaseconds)
Conversion efficiency: Max 98%
Net weight: 430g
800W DC+-55V LLC Soft Switching Power Supply High quality HIFI Amp PSU Board DIY
Vis vedlegget 823226
Spec:
Product Details:
- This product uses the LLC resonant half-bridge topology, with high conversion efficiency, lowinterference, fast dynamic response, stable output voltage, etc., as well as integrated overcurrent,overvoltage, overtemperature, output short circuit protection,Is the best collocation of high-end power amplifier products. 200-800W power amplifier can be used, the 25-degree temperature continuous power500W, peak power up to 1200W
Specifications:
- Input voltage: AC220V
- Output voltage: Main voltage: DC+-55V, auxiliary voltage: DC+-12V, independent voltage: DC+-12V
- When without load. the output voltage may be will be a littler higher than 55V. this is normal.
- Regulation accuracy: Main voltage no load + 10%, with load ± 3%; Auxiliary voltage/independent no load± 15% with load ± 15% (at AC220V input, 400W load)
- Continuous power: 400W-500W (at 25 ℃ ambient temperature of continuous work)
- Maximum power: 800W (at 25 ℃ ambient temperature can work for about 5 minutes)
- Instantaneous power: 1200W (dynamic signal generated when the impact of power, time of less than 100milliseconds)
- Conversion efficiency: Max 95%
- Use of the environment: -10 ~ 40 ℃
- Storage temperature: -30 ~ 85 ℃
- Dimensions (L*H*W): 145MM*43MM*80MM
- Net weight: 0.34KG
Tja, så utifra de erfaringer som nå er opparbeidet er den første SMPS'en som her nevnes ikkje brukanes, mao holder ikkje lovet belastning - har testet begge for henholdsvis venstre og høgre kanal. Som før nevnt hold dei ved belastning strøm på ca 2,75A i ca 6-8min og spenninga var ±55V heilt fram til SMPS'en slår seg av (shutdown). Er oppe å går igjen etter slått V 230V oog den sette på igjen. Men med strømtrekk på 2,75A og 55V gir det kontinuerlig effekt for mindre enn 8 min på 151W og det er langt under spec. Som sagt gjelder dette for begge SMPS'ene med samme verdier og resultat
Men den andre SMPS'en ein her viser til er ikkje kjørt belastningstest, kun normal drifttest.
Den har mindre kontinuerlig belasningseffekt, 400-500W ref til spec.
Den er i drift i ein PeeCeeBee V4H som er bygget tidligere, vises lenger oppe i denne tråd. Og under første oppkjøring kjørte ein med 4ohms last i ca 30 min og effekt ble avlest til 251W (ein kanal om gangen), men dei er bygget som dual mono.
Ja så kvifor den fyrste her ikkje holder må blir vel helst bare spekulasjoner, men kan vel sei da såleisna at handel frå Kina kan vera ett sjangsespel. Og dar er nok ein del fake komponentar ute å går og sikkert dårlege produkter med. Men detta gir meg eit svar kvifor eg var uheldig og brente opp ein V4H - var Mosfetane + ein del omkringliggande komponentar og PCB som brant opp i filler
Må også nevnas at den fyrste som her er vist til er rimeligare enn denne siste som har levert i oppsettet som er bygd. Diff ca 250kr/enhet.
Så mange tenker sikkert nå kvifor har ein ikkje kjørt belasningstest først før ein tar produktet i bruk... Ligg vel i oss at me trur godt om alle
Ha ei God Pinse folkens
Helge
