Jeg har skivaJa, men hvis du ikke har den skiva......så blir det litt vanskelig ?
Hvis du har skiva så er det enkel manøver og det kan være forskjellen er ubetydelig......eller i stor favør til vinylriggen din?![]()
lewm 12,287 posts 03-04-2024 at 02:40am Terry, I and someone else were talking about zenith, not azimuth. I actually ruined my Koetsu Urushi by adjusting azimuth for equal crosstalk using a Signet Cartridge Analyzer and its test LP. It was canted over by at least 2 degrees which eventually wore out the stylus on one edge. Also, as in your case, it never sounded good really. I’ve had it retipped by Expert Stylus, and I now run it at 90 degrees where it sounds wonderful. Azimuth adjustment is dangerous for most of us. I’m definitely NOT in the equal crosstalk/Fozgometer school. But read about zenith. And no, I don’t fear magnetic pulses. |
terry9 2,191 posts 03-04-2024 at 02:02am @lewm As for adjusting azimuth, I think that the only reliable way is to do it by ear. Peter Ledermann of Soundsmith has a piece on it, which seems very convincing to me. He points out that his best cartridge, the Hyperion, often has large crosstalk differences between the channels - like 6dB or more !!! That is, the left channel might have 44dB of separation and the right channel 50dB of separation. Therefore, he says, setting for equal channel separation is a serious error. When I read this, some years ago, I knew why I had been unable to get equal channel separation on my Koetsu, even though it was canted over by a degree or more! And sounded awful, although I was trying to convince myself that it sounded good because, well, it measured better that way. So, now I listen for smoothness. |
Atter en gang viser det seg at Korf og jeg ser det likt.Jeg vatrer headshellet og håper at resten er i orden.![]()
Tja, gidder ikke å kjøpe dyre headshell til billige pickuper.Hvorfor skal headshell være billige egentlig?
LH-200 er litt for tung for min arm/vekt.Jeg har et Ortofon LH-2000. Det er ikke så dyrt og jeg mener å huske at jeg satte azimuth på det.
På den annen side har ikke mitt svindyre Korf-skall azimuth-justering. Jeg brukte det til å sette azimuth på armkontakten. Master headshell.![]()
Nei, det gir ingen mening for oss som kun ønsker høy kvalitet til fornuftig prisHvorfor skal headshell være billige egentlig?
Jeg har sådan et headshell. Den er iriterende at arbjde med. I hvert fald hvis man bruger audio technica pick up.Nei, det gir ingen mening for oss som kun ønsker høy kvalitet til fornuftig pris
Vis vedlegget 1002714
hvilket minivater (og hvor kan en evt kjøpe et slikt) brukes til dette?Korf har en serie blogginnlegg om de greiene der, og om jeg husker riktig er han ikke uenig med terry9:
Azimuth Adjustment Myths and Reality, Part I
korfaudio.com
Azimuth Adjustment Myths and Reality, Part II
korfaudio.com
Azimuth Adjustment Myths and Reality, Part III
korfaudio.com
Fordi at møtrikkerne skrues ned i et spor i stedet for en plan flade. Jeg bruger den sammen med min AT 740 MLHvorfor er det irriterende å bruke sammen med AT-pickuper, @Sigma62?
Den pickupen fortjener et AT-LH13/OCC synes jeg.Jeg bruger den sammen med min AT 740 ML
Nei, ikke noen økning i brum når arm berøres, skal sjekke kontaktpunktene.@ Einstein.
Har du tjekket, evt renset, kontakt punkterne på armen/headshell?
Forøges brummet når armen berøres?
Har du plutselig plassert en annen strømforsyning i nærheten av spilleren eller ledningene........eller koblet til en ny dings på samme kursen?Nå har plutselig denne begynt å avgi «trafodur» ut i høyttalerne. Svakt i standby, men sterkere når den settes i drift. Har prøvd å gå over alt av leninger inkl jording, men finner ikke synderen. Noen tips?
Lenge siden den fikk byttet kondesatorer i motorstyring?Nå har plutselig denne begynt å avgi «trafodur» ut i høyttalerne. Svakt i standby, men sterkere når den settes i drift. Har prøvd å gå over alt av leninger inkl jording, men finner ikke synderen. Noen tips?
Ikke byttet rundt på noe, @quad. Ingen aning om kondensatorer, @PeriodeLytter, da den er kjøpt brukt. RIAA er innebygd i forsterker og funket uten brum før, @MotorhomeHar du plutselig plassert en annen strømforsyning i nærheten av spilleren eller ledningene........eller koblet til en ny dings på samme kursen?
Ja, basert på dine anbefalinger så er det flere grønne fra AT i samlingen her.......Bruker du elliptisk nål? Ikke sikkert at det er så lurt:
Modern day high elliptical tracking forces concern..
After seeing an elliptical retip recommendation on a thread for a cart that tracks at 2.5g and seeing some of the really very high modern carts with elliptical stylus tracking at 2g and avove I felt to speak out and though it was discussion worth. Back in the old days of vinyl conical was king...audiokarma.org
Her er både blå og rød og ellers alle varianter av farger, menBytt til blå eller rød.
Jeg må indrømme, at jeg ikke hører den store forskelDen pickupen fortjener et AT-LH13/OCC synes jeg.
Her går det i Microline og SAS-B til musikk. Det er så teknisk overlegent at det er tryggest.Bruker du elliptisk nål? Ikke sikkert at det er så lurt:
