Tråden for oss med Auralic Aries Streamer
  • Streamer'n
    Stabekk
    Wang skriver på forumet:
    Thanks everyone for the comment. I think most major record companies today have no problem releasing music high-res format. Most of the revenue of music industry now come from online streaming rather than download. For some record companies, like DG, if you buy a physical CD or DVD, you will also receive a download code that you can use it to download digital files in MP3, CD or high-res FLAC at their online store.
    The claim that MQA is equal to DRM is based on a recent change of TIDAL development policy. TIDAL now will not deliver MQA content to a software or device that it is not MQA certified, even the device does not process the file rather than pass it through to the next device. For example:
    TIDAL server > User interface software (need to be MQA certified) > Streamer with bit-perfect digital output (need MQA certified) > DAC (need MQA certified).
    In this playback chain, user interface software and streamer with digital output do not process the file but TIDAL is forcing those software and hardware to pay MQA to do the what is called first unfolding. If you want to get MQA content from TIDAL server then passthrough it to MQA DAC, sorry about that, TIDAL will not let it happen in the near feature. If a manufacturer does not pay MQA and get their software or hardware certified, TIDAL will not deliver content to the end customer. This is a perfect example of DRM.
    My other feelings is there are so many old recordings originally in 48k format, TIDAL claims those tracks were remastered by MQA and will deliver superior sound. The fact is those tracks are nothing special and better then if there is a remaster using today’s other technology. However, both MQA and TIDAL are afraid that people will know that, so they try every single way to avoid people getting the original MQA file before some sort of processing. In this case, nobody can analysis and see if their claim is true or false.
    Luckly, we do have more choices, Qobuz offers a large collection of music in real high-res and Amazon Music HD will come to more streaming devices and platforms soon.
    oyvjorge
    Akershus,Vestby
    Hva med rettighetene til plateselskapene? Har de ingen? Kan de virkelig forandre på formatet uten videre? Som det sies her vil jo dette styre hvem som kan få tilgangen til musikken.
    Plateselskapene? CEO i MQA kommer fra Warner og Warner konverterer hele greia si.
    MQA er til kun for plateselskapene og MQA selv.
    oyvjorge
    Akershus,Vestby
    Så forbrukerne blir lurt, igjen? De må betale ekstra for maskinvare og trolig dyrere abb hos strimingselskapene. For å ende opp med datapakker som er unødvendig modifisert.
    32bit
    Hei, noen som har prøvd den nye cd rippe og spiller funksjonen på Aries?
    Streamer'n
    Stabekk
    Jeg har med Aries femto. Funker greit, leser cd med opp til 8x speed synes jeg å huske, og buffrer i minnet på Aries’n. Tagger med Musicbrainz. Henter strøm fra usb, men det ligger en Amp begrensning på porten. Jeg kjøpte en lineær kinatrafo med usb power + hub, men oppdaget at jeg kunne slå av
    sbooster’n og aries’n spilte fremdeles :). Og med cd-driven + powersupply hengende på ble lyden betydelig dårligere. EAC på pc er nok å foretrekke for ripping, langt bedre feilkorreksjon. Men som decent cd-spiller til 300 spenn er den en artig sak, haha.
    32bit
    Stilig oppsett Streameren, godt å se at det er flere enn meg som er opptatt av å fjerne vibrasjoner - sjelden jeg hører anlegg uten vibrasjons fjernede tiltak spille spesielt bra....
    Men nok om det - så kjekk ekstra funksjon det der da. Tenkte å bruke mest til ripping til NAS. Så da er det kanskje best å rippe på en vanlig PC med blu-ray drev og EAC da?
    Streamer'n
    Stabekk
    Ja, da har du mer kontroll og bedre feilretting, og kan skreddersy tags. For de som ikke kan/vil rippe via pc er Aries funksjonen helt grei. Aries’en sliter også med non-red book cd’er.
    Den gamle Aries femto’n med sbooster, anti-vib, skikkelig kabling, ethernet via audio-grade switch låter knallbra. Den gamle Vega’n er også grei, men kunne vært morro å teste G2.1.
    32bit
    Jeg bruker G1, med vekt og plante for akustikk ;) Låter en god klasse opp med G1, hadde femton før. Synes det låter best trådløst til Aries jeg..... Har en ny og bedre switch nå da - men virker til å være veldig med støy fra ethernet..... ? Har ikke prøvd kablet med nye switchen.....
    Ripper dere med 1x i EAC ? og er det lydmessig best med WAV kontra FLAC - vet jo at det teoretisk ikke skal være noen forskjell, men reglene er jo annerledes her i hifi....
    32bit
    En ting til, jeg synes det låter bedre via TIDAL Hifi enn hvis jeg streamer fra min Synology NAS i Lightning DS ? Kommentarer?
    haraldo
    Endor
    Ripper dere med 1x i EAC ? og er det lydmessig best med WAV kontra FLAC - vet jo at det teoretisk ikke skal være noen forskjell, men reglene er jo annerledes her i hifi.... Vis vedlegget 697102
    Jeg kjører også Aries G1, og jeg har re-rippet alt jeg har, i ukomprimert FLAC, fordel med FLAC er da bedre metadatahåndtering enn WAV og når det er helt ukomprimert så skal det vel teoretisk heller ikke være noen forskjell.
    Jeg har ikke fått EAC til å rippe FLAC ukomprimert men DBPowerAmp ripper støtter det .... jeg har ikke gjort noe særlig A/B testing av FLAC komprimert vs FLAC ukomprimert .... men jeg mener Stereophile har testet og funnet at FLAC ukomprimert låter bedre.... (husker ikke vem det var som gjorde dette og kan i farten ikke finne)
    Jeg foretrekker CD spiller, Studer A727 fremfor streamer ....
    Ivaols
    Flekkerøy
    Poenget med FLAC er at det tar ca 50% av plassen men all informasjonen er inntakt. Dvs en tapsfri komprimering. Det er ingen teoretiske eller hørbare forskjeller på dette og WAV.
    haraldo
    Endor
    Det er vel delte meninger om dette, om lossless komprimering gir hørbare forskjeller ... det koster prosessorkraft å dekomprimere lossless og det skal kunne gi hørbare effekter, derfor er det noen som sverger til ukomprimert flac, uansett, diskplass er særdeles billig :)
    Dekompriering kan teoretisk såvidt jeg forstår gi timing problematikk som gir jitter; som igjen gir hørbare problemer .... avhengig av hvordan dette håndteres i spiller
    Forøvrig har flac ganske mange grader av komprimering, alt fra relativt høy til ukomprimert ....
    Her er sakset fra docs på flac.exe (men har ikke funnet ut hvordan flac.exe gjør ukomprimert flac):
    -0 .. -8 Fastest compression .. highest compression. The default is -5.
    -0, --compression-level-0 Synonymous with -l 0 -b 1152 -r 3
    -1, --compression-level-1 Synonymous with -l 0 -b 1152 -M -r 3
    -2, --compression-level-2 Synonymous with -l 0 -b 1152 -m -r 3
    -3, --compression-level-3 Synonymous with -l 6 -b 4096 -r 4
    -4, --compression-level-4 Synonymous with -l 8 -b 4096 -M -r 4
    -5, --compression-level-5 Synonymous with -l 8 -b 4096 -m -r 5
    -6, --compression-level-6 Synonymous with -l 8 -b 4096 -m -r 6 -A tukey(0.5);partial_tukey(2)
    -7, --compression-level-7 Synonymous with -l 12 -b 4096 -m -r 6 -A tukey(0.5);partial_tukey(2)
    -8, --compression-level-8 Synonymous with -l 12 -b 4096 -m -r 6 -A tukey(0.5);partial_tukey(2);punchout_tukey(3)
    --fast Fastest compression. Currently synonymous with -0
    --best Highest compression. Currently synonymous with -8
    Kalle Klovn
    Sandnes
    Hei, jeg har et praktisk problem med min Auralic Aries når den er koblet med USB kabel til Anthem STR Pre. Når jeg starter opp forsterkerne og spiller av første sang fra Aries så kommer den en liten, men veldig hørbar utladning. Det virker som om det enten er et dc offset eller en opplagret ladning i en av enhentene som utlignes når første sang «slippes». Noen som har erfaringer, tips og råd?
    Ken-Nor
    Larkollen
    Opplever akkurat det samme hos meg. Var sånn med den integrerte og det er sånn med pre+effekt. Lurer også på hvorfor det er sånn. Et lite "popp" som kommer ved avspilling av første låt etter oppstart.
    erlingmm
    Kan noen forklare meg funksjonen til de 3 runde knappene over sangtittelen i Tidal på Auralic?
    Takk,
    - Erling
    Haakonsunden
    Norge
    Hei, jeg har problemer med Tidal connect fra android til Auralic Aries den gode gamle. Når jeg velger auralicen i tidal så stopper bare musikken. Noen som har opplevd det samme og har tips?
    Musico
    Jeg har en bass-hump på 32-35 Hz. Streamer fra Tidal til Auralic Aeries G1. Lurer på om noen kan guide meg på om denne siden i appen kan få ned bassen i dette området? Har forsøkt Peak/Dip under parametric equalizer, men får det ikke til å fungere noe særlig.
    Kalle Klovn
    Sandnes
    Vis vedlegget 910014
    Prøvde du å legge inn en dip på samme frekvens? I så fall med hvilken Q verdi og antall dB i demping?
    Musico
    Prøvde center frequency på 34 Hz, gain fra minus 3-6 db og q fra 3-10 (sånn omtrent). Var jeg for forsiktig? Eller må man restarte Auralic'en for at det skal virke? Musikken stoppet et par sekunder etter at jeg trykket save, og grafen oppdaterte seg.
    Kalle Klovn
    Sandnes
    Ok, jeg har ikke prøvd dette på min Auralic selv. Mulig du hadde litt høy q verdi, men uansett rart om det ikke har hørbar effekt med -6dB. Prøvde du å måle før og etter?
    Musico
    Da ser det ut til at jeg har funnet noe som funker. Jeg måtte helt opp til - 12 db og q-faktor på 2, på 32 Hz, og - 9 db og q-faktor på 2 på hhv 28 og 36 Hz. Herfra og ut blir det bare å leke seg og fintune resultatet. Resultatet var forøvrig både målbart og hørbart (rød linje).
    Testlåt: "Queen Mary" med Francine Thirteen. Takk til deg, Kalle Klovn for tips om smalere q-faktor. Det var avgjørende for å få til et brukbart resultat 🎵🎶
    Kalle Klovn
    Sandnes
    Har du prøvd UMik-1 og REW? Det er en kostnadseffektiv kombinasjon for å få gode målinger. Det kan være verdt å prøve.
    Kalle Klovn
    Sandnes
    Her ser du forskjellen på korreksjoner med lav Q, som gir bred korreksjon, og høy Q, som gir smal korreksjon. Grafen kan være litt misvisende da kurvene som vises har forskjellig peak nivå.
    Bat78
    Noen som har tips?
    1. Får ikke koblet meg på i dag. Har forsøkt å installere inn på nytt (setup New device). Når jeg skal gå på innstillinger og velge Auralic som nettverk ser her det stå usikret nettverk og så går det noen sekunder og det kommer beskjed om at det mangler internett forbindelse. Aldri hatt dette problemet tidligere.
    2. Regner med dette har sammenheng med hverandre, men alt fra Tidal er heller ikke mulig å få opp (tomme lister).
    Ubrukelig på data- så mulig det er selvsagte løsninger her for de fleste andre🙄😉
    atletico
    Jeg har til nå brukt Auralic Aries i 8 år. Først Aries femto clock /oppgradert strømforsyning versjonen. Etter dette 5 år med Aries G2. Disse komponentene er brukt med 6 forskjellige DAC'er i disse 8 årene. Jeg har vært veldig fornøyd med disse produktene og overgangen til Aries G2 i samme DAC som Aries femto viste meg at en streamer ikke bare er "en streamer". Aries G2 spilte med et større lydbilde med større tyngde nedover i frekvensene.
    Jeg har nå fått min tredje Auralic. En Altair G2.1 som er en streamer/DAC/analog preamp. Jeg bruker nå den innebygde dac'en i denne og den er virkelig god! Steaming fra Altair G2.1, analog XLR ut til integrert forsterker gir meg den beste lyden jeg har hatt i min stue. Bare helt rått! CD drivverk (coax) og TV lyd (optisk) fikk også det klart løft i lyden via de digitale innganger på Altair og det ble også moro med CD igjen...
    Den har også to analoge innganger og en påkostet analog volumkontroll som ikke er testet ennå. Målet på sikt er å kjøre denne som( hoved) preamp i anlegget til en god sluttforsterker. Auralic Altair G2.1 er et fabelaktig, vellydende produkt !
    Distinctive@ Kanskje denne tråden burde skifte navn til " Tråden for oss med Auralic streamere "
    M.B.S
    Hei. Noen som vet om Auralic aries mini er kapabel som ren streamer? Hvordan står den seg mot fks wiim pro og bluesound node? Aries mini har vel litt potensiale med å kjøpe til den originale psu’en
    OlaR
    Noen som har tips?
    Jeg har opplevd det samme under forsøk på å hjelpe en kamerat. Har kjørt reset, men får rett og sett ikke kontakt med Aries (femto) i det hele tatt via Lightning DS. Har prøvd både fra iPad og iPhone, begge av nyere dato og fullt oppdatert.
    Men går vi inn fra Windows-pc får vi kontakt når Aries er på kablet nett. Vi ser at Aries har gjeldende firmware (9.6).
    Takknemlig for tips!
    OlaR
    Det er ingen Tidal-tilknytning hos kameraten min. Vi har kjørt full reset på Aries, men får altså ikke kontakt med den fra Lightning DS.
    atletico
    Hvis Aries Femto er reset til fabrikkinnstillinger skal det vise et wifi symbol i display. Søk så med iPhone/iPad etter "Auralic-Lightning” wi-fi network som Aries´n setter opp og koble til dette. Åpne så Lightning DS på telefon eller iPad og da skal en ha kontakt med Aries. Velg så nytt hjem-nettverk i innstillinger for Aries og avslutt "Auralic-Lightning” network tilkoblingen. Da skal Aries være oppe på hjemme nettverk.
    OlaR
    Hvis Aries Femto er reset til fabrikkinnstillinger skal det vise et wifi symbol i display. Søk så med iPhone/iPad etter "Auralic-Lightning” wi-fi network som Aries´n setter opp og koble til dette. Åpne så Lightning DS på telefon eller iPad og da skal en h kontakt med Aries. Velg så nytt hjem-nettverk for Aries og avslutt "Auralic-Lightning” network tilkoblingen. Da skal Aries være oppe på hjemme nettverk.
    Problemet er at når man kobler til Auralic-Lightning-nettet, så får vi allikevel ikke kontakt med Aries. Lightning DS søker, men den timer ut og iPad går så tilbake til det vanlige nettet.
    atletico
    Setter den opp "Auralic-Lightning” network for tilkobling ?
    Calmati
    Hvis dette er første generasjon Aries, så er det en stor mulighet for at det er wifi-kortet som er gåent. Kjent feil på denne modellen, men heldigvis lett å fikse. Må kjøpe nytt wifi-kort, men veldig lett å bytte selv. Forklaringer på hvordan finnes på nettet, mener jeg så en video på YouTube :)
    atletico
    Dette var også mitt neste forslag...sannsynligvis feil på wi-fi kortet.
    Litt historie: Jeg brukte Aries Femto fra 2015 til 2019 med 3 forskjellige usb dac..Ingen problemer eller feil i det hele tatt.
    Derfor ble jeg veldig overrasket når jeg fikk en av de 2-3 første Aries G2 levert i Norge med feil på usb tilkoblingen. Etter et ½ år fikk jeg en ny Aries G2 av Duet. Denne virket med usb uten problemer men dessverre gikk den i frys nesten hver dag. Auralic skyldte dette på mitt nettverk men dette skjedde aldri med Aries Femto eller den først Aries G2 med usb feil. Etter nye 6 mnd. fikk jeg da min tredje Aries G2 av Duet...og heldigvis ingen problemer med denne. Bruker nå forøvrig en Altair G2.1 som har oppført seg eksemplarisk. :)
    Calmati
    Jeg måtte bytte wifi-kort på Aries Femto. Hadde akkurat samme symptomer som OlaR beskriver. Og ble 100% frisk med nytt kort :)
