Blindtest av flac vs. wav
U
Utgattmedlem 762
Ser at 6moons linker til rapporten, har sendt følgende mail:
Dear Srajan,
I have been made aware that an excerpt from a document of mine is reprinted in a 6moons review written by you:
http://www.6moons.com/audioreviews/esoteric2/g25u_3.html
Normally I would just see it as a compliment to have my writings republished and thus acknowledged by a hifi magazine such as yours, however in this case one of the reprinted statements is erroneous.
The statement of concern is the following: "CD discs even have physical jitter, often referred to as landscape-jitter and pit-jitter. All these are secondary distortion sources; they can lead to sampling jitter, which will again lead to distortion."
This statement is factually wrong, as there is no link between a CD's physical landscape-/pit-jitter and clock-jitter whatsoever. These are two terms descibing completely different effects; the landscape- and pit-jitter on a CD only affects its yield, it has no relation to sampling jitter as the (sampling) clock is not something that is stored on the disc, but rather a signal generated during conversion. Thus, the above sentence should probably be removed from the site.
The document, that you also link to, was written as a report in a PhD-course and it contants a few errors like this one, since it was never peer-reviewed or intended to be a scientific publication. You should probably note this when linking to the document. If you want to, you are also free to provide a link to my final thesis found here.
Thanks and regards,
Ivar Løkken.
Ift drivverk og transmisjon har klokke og PLL i DAC omtrent tusen ganger mer å si for endelig ytelse mtp. samplingsjitter. Og det å komme under Dunns hørbarhetsterskel som ofte blir gjengitt og referert til, er ikke spesielt vanskelig. Og koster ikke mye penger.
Sorzy
Akershus
Dette er interessante resultater, selv om jeg foreløpig har et nullresultat ved å prøve det samme hos meg. Håper derfor du vil poste oppdateringer. Jeg foreslår heller at du ber en moderator om å rydde ut alt som er off-topic, slik at tråden kommer tilbake på sporet. Jeg har forøvrig slettet et par av mine innlegg som nok var off-topic i denne tråden.
Bjørn ("Orso")
Hehe. Håper du husker hva du skrev Asbjørn, for jeg spøkte. ;D
Men jeg har tatt en liten pause. Kommer sterkere tilbake. Har lyst til å blindteste MP3 i 320 kbps mot WAV/Flac også.
Jeg skrev nok ingen ting som jeg ikke har skrevet mange ganger før, og da kan støy/signal-forholdet bare bli bedre av å slette det. Spent på hva du kommer frem til. Jeg har ingen problemer med å høre når guttungen har smuglet inn en MP3-fil på serveren, men det er neppe 320 kb oppløsning i de filene.
