Devialet vennetråd
  • ragwo
    Mud-fi freak
    El-returen
    Firmwareoppdatering til Dialog og Phantom samt oppdatering til Spark er sluppet i dag. 1.4.0.5 er siste FW. Fortsetter det med en oppdatering i måneden blir dette veldig bra!
    Release note sakset fra DevialetChat:
    New features Dialog only:
    - Added support for Favorites on Tidal, Deezer and Qobuz
    - Bluetooth Phantom only: Information about the playing track over bluetooth is now displayed on Spark
    Fixes
    - Fixed an issue leading to vanished play queue
    - Fixed an issue leading to optical input not playing
    - Fixed an issue leading to setup failing
    - Fixed an issue leading to multiple entries for the same optical or bluetooth source in the playqueue
    - Fixed an issue leading to lost volume control capability from the remote control
    - Fixed access to album information for Qobuz track in the play queue
    - Fixed an issue preventing playback Qobuz track when Hi-Res option was selected
    - Fixed an issue leading to the loss of Tidal, Deezer or Qobuz sessions and a few other bug fixes and improvements
    ragwo
    Mud-fi freak
    El-returen
    Litt info om Spark 1.3
    Release note Spark 1.3:
    New features
    Mobile only ( iOS / Android )
    - Added onboarding screens
    - Added feedback gathering in Spark
    - Added autoscroll when dragging items in the play queue
    - Added autoscroll when dragging group in other bouquet
    Improvement
    - Added current rooms indication on all panes Windows and Mac
    Desktop only
    - Removed splash screen to improve startup time
    Windows Desktop only
    - Disable sleep when local content is streamed Fixes
    iOS only
    - Fixed crash when streaming some track from iOS devices
    - Fixed an issue disabling the ability to switch between online music services account
    - Desktop/Laptop only ( Mac / Windows )
    - Fixed an issue preventing playback of local tracks
    - Fixed an issue leading to floating album artwork and a few other bug fixes and improvements
    fry
    Noen her inne som kjører Sonus Faber med sin Devialet? Har et par Cremona M på vei og er nysgjerrig på erfaringer med kombinasjonen. Har per i dag Harbeth M30.1, som er fantastiske fra 100 hz og opp, men de er ikke fullfrekvente, selv med SAM og det merker man. I søken etter det perfekte har jeg dog havnet på ønsket om å prøve nevnte Sonus Faber. SF har også en varm siganturlyd så håper det funker noenlunde bra.
    ragwo
    Mud-fi freak
    El-returen
    Firmware 1.4.0.5 har visst gitt en del Phantomeiere uventede problemer og oppgraderingen er derfor trukket tilbake til Devialet har rettet feilene. Ingen downgrade er tilgjengelig for dem som har fått problemer så vi får håpe at Devialet kommer med en oppdatering kjapt.
    janfrt
    Pt. Høvik
    Har fortsatt 7.1.3-versjonen med SF Olympica III. Fungerer utmerket. Cremona M kan jeg intet om, så jeg burde vel ikke svart på dette innlegget. :) Dessuten er det perfekte uoppnåelig fry!
    Ellers: Er det på tide å oppgradere, trygt for min 400-kombinasjon?
    grammofon
    Jeg har vel tidligere nevnt Steve Huffs anmeldelse av Sf Amati Futura:
    ? The Sonus Faber Amati Futura Speaker Review
    Lykke til. Bare å prøve.
    Academic_South
    Jeg hadde 7.1.3-versjonen på D120 og synes den var kjempebra. Så var jeg dum nok til å oppgradere til Ver.8 for å benytte meg av SAM. Da gikk lyden fra å være "musikalsk" til å bli et kjedelig "analyseverktøy". Før kunne jeg spille "svinehøyt" med full trøkk på 80-talls rocke-innspillinger, nå ble lyden temmelig pågående med fokus på øvre frekvens og kjedelig. For meg var den nye softwaren en stor nedtur - men det er sikkert smak og behag (for meg er høy boggie-Woogie-faktor viktig, med bra rytmisk driv i mellombassen).
    Da jeg henvente meg til Deivalet for å få tilsendt tidligere software, så var svaret nei. Så jeg solgte likegodt forsterkeren. Jeg er utrolig skuffet - jeg kan ikke ha en forsterker som endrer klangkarakter etter Devialets forgodtbefinnende.
    E.I.A.
    Tror du finner tidligere versjoner av firmware på nettet, evntl fått den tilsendt av en bruker her.
    Selv hadde jeg alle firmware versjonene i egen mappe på harddisken de tar jo ikke plass.
    Academic_South
    Ja, jeg kunne nok ha fått tak i de tidligere versjonen via andre brukere. Men når produsenten ikke ønsket å bidra til dette, så synes jeg at supporten er for dårlig for et slikt dyrt produkt. Så da ble det farvel til Devialet.
    Men kan Sugden A21Al være et godt alternativ til Devialet D120 (ser du eier en A21SE)?
    Lostx9
    Hvis en logger seg inn på hjemmesiden, så er det en eldre versjon 7.11 der
    ragwo
    Mud-fi freak
    El-returen
    Lyd og bilde nr 10, der de har testet Phantom, er nå å få kjøpt. Full pott på alt unntatt kvalitetsinntrykk som fikk 4 eller 4,5 stjerner. Eneste negative lydmessig var at bassen flatet ut på høyt volum, ellers bare lovord.
    fry
    Jeg tror dette er den mest positive testen jeg har lest, noensinne. Kjenner at jeg bør ta en lytt ved anledning, selv om det ikke er noe jeg har behov for.
    E.I.A.
    Sugden spiller knallbra(les morsomt og musikalsk), men har begrenset effekt så avhenger litt av hvor stort rom du har og hvor tungdrevne høyttalere du har.
    S. Lieng
    Ettersom Phantom er så vellykket men flater ut i bassen på høye volum så bør de lage en større modell! Den er jo veldig liten og ikke alt for dyr, så det bør være marked for noe større med samme kvaliteter.
    MusicBear
    Er den så god som folk og media snakker om, kan jo resten av verden legge ned sin høyttaler produksjon...
    Nei, jeg nekter at den virkelig kan være så god som det sies. Men, kun en måte å finne ut av det på.
    lovemusikk
    Ja de kan legge ned. :)
    Tenk en dobbel så stor slik? Hadde revet ned huset. :p
    Få deg en lytt, godlyd.
    fry
    Litt tilbake til 200 og 400; noen som har testet versjon 8.1.2? Eller har jeg gått glipp av noe?
    Strålende kritikker:
    Devialet D400 | Lyd & Bilde
    Mulig det er mine ører, eller innstilling, men etter min mening er det svært liten forskjell på de forskjellige versjonene lydmessig, med unntak for SAM, som jeg føler (håper) ble endret mellom 7.x.x og 8.x.x. Og i mitt system til det bedre.
    Jeg tar gladelig i mot de ekstra funksjonene som kom i hvert fall.
    Sober
    NAT har SAM-lab på besøk på torsdag 12-20. Jeg er selvsagt borte så får ikke tatt mine :(
    Academic_South
    For meg er det litt vanskelig å forstå at man ikke høre forskjell mellom ver.7 og 8 , for hos meg er det "himmelvid" forskjell (til V7 sin fordel). Dette kan riktignok skyldes at jeg har noen ganske åpne rocke-høyttalere (JBL) og er veldig sensitiv for pågående lyd i "presensområdet", men likevel......
    Det jeg derimot er helt enig i, er at SAM tilfører noe positivt med lyden. Det er bare synd at siste SAM versjon kun er tilgjengelig i de siste software-versjonen.
    fry
    Ja det har muligens noe med høyttalerne å gjøre. Har kun sammenlignet 7 vs 8 på Harbethene som er ekstremt lite krevende når det kommer til forsterkeri. De er heller ikke pågående i presensområdet i utgangspunktet slik at en liten endring der ikke får det til å bikke over heller.
    Jeg har ikke sammenlignet versjoner med Sonus Faber Cremona M jeg har koblet opp akkurat nå, men lyden er helt strålende med versjon 8.1.3 og ikke minst SAM.
    Det er helt utrolig for et grep den lille boksen har på disse høyttalerne og man får den deilige fullfrekvente og uanstrengte lyden som ofte kjennetegner mye større høyttalere.
    ragwo
    Mud-fi freak
    El-returen
    En bruker på Devialetchat fikk for et par dager siden mail fra teknisk support hos Devialet med informasjon om at neste firmware er på testbenken hos Devialet. Hvis alt gikk etter planen ville ny mykvare bli sluppet i løpet av uka. Siden det nå er fredag og support stenger for helga tipper jeg at oppdateringen kommer tidligst i neste uke. Ikke lurt å slippe oppdatering med helgestengt support.
    Edit: Kontaktet support selv og fikk beskjed om at 1.4.1 slippes i løpet av de neste ukene. Ikke noe konkret dato altså.
    Just4Fun
    Sauda
    Hva er det den nye firmwaren tilfører/fikser?
    Ser heller at de setter inn krefter på å fikse Spark, GUI'en er begredelig, det positive er at responsen er rask.
    Navigering i Tidal er tungvint og irriterende at du må klikke legg til for hver sang/album istedet for at den bare legges til hvis du klikker den.
    Hvorfor kan de ikke kikke på Tidal/Spotify og implementere noe av de grafiske elementene derfra (eller Squeezebox remote apper)
    Spesielt på nettbrett er det komisk hvor dårlig utnyttelsen av skjerm arealet er.
    ragwo
    Mud-fi freak
    El-returen
    Tror den i hovedsak retter feil som ble introdusert med mykvare 1.4.0.5, som at høyre og venstre kanal bytter side under avspilling, støy og hakking under avspilling, nettverksproblemer osv. Har heldigvis ikke opplevd slike problemer selv.
    ragwo
    Mud-fi freak
    El-returen
    Mens vi venter på Branch med skikkelig feste til Phantom.
    Bare så innmari irriterende at den norske krona er så svak og at Devialet tar seg fryktelig godt betalt for tilbehør til Phantom. 7400 kr for et par høyttalerstativer er absurd. Ikke er de spesielt pene heller.
    K2
    Skedsmokorset
    Så er jeg tilbake på Devialet.. Med SAM på PMC MB2 SE er det meget overbevisende :) Vis vedlegget 343951
    Gratulerer med nye høyttalere!
    :). de spiller himmelsk eller hva?
    Mvh Jan Ove.
    Himmelsk, ja noe i den retning! Om det er Devialet eller PMC som er himlen er ikke helt sikkert da alt ble byttet på en gang. Med helt sikkert er de sammen er det beste jeg har lagt øre til.
    K2
    Skedsmokorset
    Opp på veggen mens jeg går å teller på knappene om jeg vil oppgradere til 400. Som dere ser har jeg ca 3 cm avstand til veggen samt alu
    folie, dette for å få refleksjon til Wifi og fjernkontrollen ellers går det ikke i et tømmer hus.
    K2
    Skedsmokorset
    Da er neste trinn på plass. Starter ut med en 250 på veien til 800. Stor lydforskjell fra 120, men 120 blir dog helten til prisen. Det rarere er at med 250 trenger jeg ikke lengere folien for å skape refleksjon til WIFI og fjernkontroll. Fjernkontrollen til 250 er bare såååå lekker, en tung gedigen sak som må koste betydelig mer enn 120/200 kontrollen. 120 er satt på pensjon inn til videre.
    K2
    Skedsmokorset
    Gratulerer!
    Stor forskjell?
    Ja! Ikke noe vanskelig å hører forskjell her. Morten NAT hadde nokk rett i at 120 ble for liten på MB2. Nå det er sagt så synes jeg fortsatt at 120 spiller intet mindre enn imponerende til prisen, en 250 koster tross alt nesten det 3 dobbelte! Men for prisen på 250 får mann rett og slett mer av det hele; kontroll, oppløsning og kraft i tillegg til finish og funksjon. Har ikke lengre noen problemer med rekkevidde på fjernkontroll og Wifi. Fjernkontrollen på 250/800 er en helt annen divisjon og burde vært inkludert til alle Devialet modeller. Så for øvrig at listepris på denne kontroll er £ 680! Eller en 7-8000 om man får lyst.
    MusicBear
    Gratulerer!
    Stor forskjell?
    Kan tenke meg akustikken er bra med de veggene du har. Norsk økse-hogd & fransk lyd-eleganse, sikkert fin match det :)
    K2
    Skedsmokorset
    Ja! Det er en meget fint room med jevn demping over frekvens og ingen stående bølger. Lett å få bra lyd i rommet, eller helt fantastisk med det rette utstyr.
    MusicBear
    Høyttalerne dine, jeg mener når du har sååååååååååååååååå bra høyttalere! Ja, så antar jeg du (også!) har forsøkt med mykt underlag til gulvet fremfor hardt. Jeg aner jo ikke om du har flytende furugulv med eller uten mykt underlag, spikret eller spiret og limt til bjelkelaget - eller annet. Men jaggu skal man være mildt sagt heldig dersom underlaget kobles riktig til høyttalerens iboende konstruksjon hva "behandling" av sine egne resonanser. Tenker jeg :)
    plinius
    Drammen
    Etter å ha lest om erfaringer med versjon 8.1.3 kontra 7.1.1 måtte jeg teste dette ut selv.
    jeg har nå spilt på 7.1.1 i over en uke og det har spilt utrolig bra. Byttet tilbake til 8.1.3 nå i kveld og fikk en gedigen nedtur. Låter helt flatt i forhold. Skiftet tilbake til 7.1.1 og godlyden kom tilbake.
    Merkelig at det skal være så store forskjeller. 7.1.1 er mye mer musikalsk. Spiller musikk, kontra 8.1.3 som er mer hifi.
    Hvorfor er det bare 7.1.1 som ligger ute av de gamle versjonene? Skulle tru at 7.1.3 som er den siste av 7 versjonene skulle ligge på hjemmesiden. Er det noen som har en forklaring?
