Dynaudio's venner
  • Sober
    Heisann,
    Er det noen av dere som har erfaring med sub i tillegg til focus-140? Spiller mest musikk, og kunne tenkt meg litt mer trykk på rock/metal :)
    Er det vanskelig å få det til å harmonere?
    Ser Dynaudio har noen sub-woofere, erfaringer?
    SOB
    C
    Cappuccino
    Her noen glimt av de nye Dynaudio Consequence Ultimate Edition "opp-ned" høyttalerne ($70,000/pair, 17 Hz to 30 kHz +/- 3 dB) sammen med Wadia Reference Serie 9 transport og Decoding Computer system samt Octave forsterkeri.
    C
    Cappuccino
    Sitat fra produktblad for Consequence Ultimate Edition:
    "The distinctive driver array on the Consequence baffle is quite conspicuous. The loudspeaker appears to be standing upside down: The tweeters are integrated at the bottom, and the woofers are mounted above at the top. This positioning is important for achieving correct acoustical timing and coherence: There is a scientific purpose to this, as sound waves from different drivers propagate differently depending on their respective frequencies. Every subtle musical detail, from the highest to lowest frequency is made to reach the listener at exactly the same time in the Consequence Ultimate Edition.
    Normally, loudspeakers attempt to compensate for frequency-dependent delays through the properties of their crossovers. This is not sufficient for the Consequence Ultimate Edition. Hence, Dynaudio takes the next step in development to achieve a perfect sound reproduction by adjusting and optimizing all complex parameters relative to driver dispersion and time-domain coherence. The “inverted” driver array on the baffle is one part of this concept, for each driver position factors in the respective frequency’s propagation and time-arrival properties relative to the listening position.
    This time-delay correction with the five drivers is unique – but for a true loudspeaker specialist as Dynaudio, this is only the first step in the detailed optimization: The Chrome- or gold-plated tweeter and midrange driver front plates have been precisely shaped in countless development stages, accurate to a micrometer, to achieve an optimum measurement value and, most importantly, to enable optimal dispersion and sonic performance. They also serve to dampen possible vibrations and thus further reduce distortion. All high-grade crossover components have also been painstakingly selected for their individual sonic properties and matched to the tightest tolerances, thereby enabling the drivers to perform at their highest level."
    emokid
    Sober skrev:
    Heisann,
    SOB
    Har hatt Sub 300 med Contour 1.4, det var en god kombinasjon. Sub'ene til dynaudio er gode, har mange justeringsmuligheter og ikke minst fjernkontroll, som gjør integreringen til HT MYE enklere.
    Brasse
    For de som ikke har kjøpt Fidelity #43, det er demo på Consequence på Soundgarden Vika 9. mars.
    Send mail til solliplass@soundgarden.no for påmelding, begrenset antall plasser. Jeg har ikke tenkt å la sjansen gå fra meg og har fått plass ;D (sannsynligvis eneste mulighet til å høre Consequence i Norge).
    Freako
    Hej alle Dynaudio venner!
    Dejlig tråd den her!
    Håber jeg kan få lov at være med i denne hyggelige klub, da jeg om et par dage får den næstmindste af de små tassene i hus (DM2/7), som afløsning for mine Audio Pro Black Pearl. Jeg er ved at tilspille et sæt Supra Ply 3.4/S som skal fodre de kære små, og en Audio Pro sub står parat til at hjælpe med de dybe toner.... Er også spændt på om min Thule IA150b har kræfter nok til at få det bedste frem i Dyn'erne.
    Vender tilbage om et par dage (+250 timer!)
    ;D
    mikefish
    i den andre delen av skala'en kommer en interessant liten stativhøyttaler som prismessig er overkommelig for de fleste (5 flak) : DM 2/6 :
    sakset fra Soundgarden.denne skal sjekkes ut !
    mvh. s,
    Freako
    Har nu spillet en uges tid på mine DM 2/7'ere. De åbner stadigt mere og mere op, og lyder ganske dejligt - meget neutrale, men detaljerede og hurtige. Et røverkøb for pengene. Jeg benytter Supra Ply 3.4S som højttalerkabel, a match made in heaven! Begge kan anbefales ;D
    hifiguru
    Porsgrunn
    Grrr, consequence-demo i Oslo til tirsdagen, kjøre 2x160km for dette? tja...... ;D ;D
    slagget
    Hei!
    Har et par nydelige Contour 1.4S som jeg er storfornøyd med. Bruker Primare pre og effekt (PRE30+A31.2) på disse. Er litt i bytte-modus. Leser at DA trenger litt muskler for å levere. Har ikke prøvd noe annet enn A31.2 (strømsterk 120 watter) Blir det en åpenbaring med feks en A32 på 2x250 W? Forslag til annen god elektronikk som yter disse rettferdighet? Erfaringer med digital-forsterkere? (Lyngdorf/Stello)
    mvh Frank
    emokid
    Min erfaring er at Contour-serien er merkant varmere i lyden enn Confidence og dermed trives bedre med transistoramper som du nevner. Jeg brukte Bladelius Thor og var ganske fornøyd, ble dog litt lei Bladelius i lengden.
    Om du ikke har merkante kraftmangler når du drar på tror jeg ikke du skulle trenge stort mer krefter enn du har. Om du finner/har råd til røramper som klarer å dra DA er du fort i audionirvana. Noe med fornuftig strømforsyning på 80-150W er nok i massevis.
    slagget
    Takk for tilbakemelding emokid :) Ble litt nysgjerrig nå, du nevner rør-amp, forslag?
    Frank
    btw: Noen som erfaring med EC på DA, og da helst på 1.4S?
    emokid
    Jeg hadde Sonic Frontiers Power2 på C1 og C3, veldig bra saker. Power i massehvis, men er stor og veier 50kg. Hifiguru hadde en sak med 211-rør, tror jeg, som låt veldig bra på Contour 3.4.
    Jeg ville ikke kjørt noe som er utpreget varmt og slapt med Contour-serien, heller noe med futt og farge. Litt eldre naim var en stor glede på Focus 140 husker jeg.
    hifiguru
    Porsgrunn
    Og da var det transistor igjen emo....Men, jeg hadde også Tube Technology integrert rørpower med 6xel34-rør pr kanal, det funket også bra på 5,4! 1,4 burde vel funke fint med 2xKT88 pr kanal vel? Skikkelig strømforsyning i samme rennet så kan man vri ut 50w good power og det burde vel funke såfremt man ikke har veeeldig stort rom....men med 4 rør pr kanal (Som f.eks sonic frontier som emo nevner) er du godt innenfor og det liker vi! ;D
    Destiny
    Da har denne tassen rusla ca 243t ;D og nå begynner det å skje saker, bassen begynner å bli mer tørr og stram, mellomtonen begynner å blomstre!
    Litt slepphendt i toppen ennå, men den helt klart på vei til å bli klar. Morten mener at Dynaudio 110 trenger 500t, så da er jeg jo straks halveis ;D
    X12 fikk forresten en fantastisk omtale i stereophile!
    Destiny.. :)
    Spyd
    Har akkurat tatt i bruk mine Dynaudio 2/8 (kjøpt hos Norsk Audio teknikk). Så langt er jeg kjempefornøyd. Har et litt problematisk lytterom som utelukker bruk av gulvstående høytalere. Med 2/8 får jeg likevel nok bass uten hjelp av sub. Resten av anlegg: Tonewin hybrid rør/transistor forsterker, Consonance cd spiller, Silversonic kabling.
    Mvh Spyd
    H
    hawenger
    Hei.
    Jeg lurer litt på om jeg skal bli medlem av klubben deres. Jeg har en Bladelius Thor MkII forsterker og Bladelius Syn cd-spiller. Disse spiller i dag sammen med B&W cm7. Har lekt med tanken om å oppgradere høyttalere og har sett litt bl a på Contour s3.4. Har noen spørsmål til dere som har erfaring med denne høyttaleren og evt forsterkeren:
    Krefter:
    Er Thor mkII(2*165 w med 1800w trafo) sterk nok til å dra contour s3.4 skikkelig? Ønsker et balansert anlegg hvor komponentene får ut det meste av hverandre. Skal helst ikke være sånn at det fungerer "ok" til jeg får kjøpt en ny effektforsterker liksom. Da kjøper jeg heller noen andre høyttalere som er lettere å drive.
    Plassering:
    Rommet jeg har er på ca 4*7 meter. Har anlegget langs kortveggen. Hvordan er deres erfaring mht plassering av contour s3.4? Er den vanskelig til å få til lydmessig i rommet?
    Høyttalerne vil stå ca 65cm fra sidevegger og en drøy meter fra bakvegg.
    Ønsker å ha et annlegg som låter bra på de fleste typer musikk.
    Takker for innspill.
    Harald
    hifiguru
    Porsgrunn
    Har hatt Thor (mk.1) og 3,4. Var veldig tilfreds med dette, spiller sømløst og vakkert men kanskje en tanke "kjønnsløst"? Kan hende det var første utgaven av Thor som gjorde dette, puttet på et sett større rørmonoblokker siden og det låt jo mer kjøtt og blod. Prøv deg frem, så veldig galt tror jeg ikke det går!
    http://www.hifisentralen.no/forum/index.php/topic,14384.msg296421.html#msg296421
    H
    hawenger
    Takk for svar.
    Må eventuelt ta en sjans og kjøpe brukt. De har de ikke inne på soundgarden eller norsk audioteknikk så det er ikke så lett å få testet. Og nypris er i stiveste laget.
    Harald
    Medlem 1792
    hawenger skrev:
    Hei.
    Krefter:
    Plassering:
    Harald
    Hallo,
    Jeg har nå en Vincent SV-238MK integrert forsterker på mine Dynaudio Contour S3.4 høyttalere med Kimber 12TC høyttalerkabler, det spiller meget bra.
    Denne forsterkeren har krefter så det holder samt at den låter overraskende bra til prisen.
    Denne Vincent’n er en bedre ”match” enn Hegel H200 i mitt anlegg, Bladelius har jeg ikke hørt. Disse høyttalerne krever og fortjener stor og bra forsterker.
    (Ser det står avertert en brukt Vincent SV-238 forsterker til høyre på forsiden til bruktbørsen her).
    hifiguru
    Porsgrunn
    hawenger skrev:
    Takk for svar.
    Harald
    Jeg kjøpte senere Contour 5,4 for rundt 25000 minnes jeg. Ikke lett å få tak i men fy grisen for en klasseforskjell fra 3,4...
    http://www.hifisentralen.no/forum/index.php/topic,29216.0.html
    emokid
    Thor klarer fint å dra 3.4, men du burde belage deg på å stille 3.4 ganske fritt fra bakvegg for å få de til å spille optimalt. Jeg mener at 3.4 trolig er en bedre match til Thor enn 5.4, grunnet at Esotar er litt lysere enn Esotec.
    Plassering er enkelt så lenge du gir dem nok rom bak. De er ikke veldig følsomme for vinkling og gir god pinpoint selv ved lite toe-in. Hiv på et par akustikkplater ved førsterefleksjonspunkter om du sliter med disse. 3.4 har en relativt varm og koselig klang som fungerer på all musikk, sømløse og forsvinner virkelig i lydbildet.
    Anonym
    Som eier av Special 25 har jeg også blitt en Dynaudio venn. Pene og gode høyttalere som jeg regner med å ha en god stund.
    emokid
    Grattis. Savner (nesten) C3 litt innimellom.
    jabbalabba
    Hei,
    Vurderer å melde meg inn i klubben.
    Noen som kan gi en sammenligning av Focus 140, s1.4, C1 ?
    Vil alle disse passe godt inn på ca 20m2 ?
    Eller bør man gå opp til f.eks 220 mkII ?
    Anonym
    På generelt grunnlag er det enklere å integrere små høyttalere til et lite rom enn store høyttalere.
    hifiguru
    Porsgrunn
    jabbalabba skrev:
    Hei,
    Alle disse gir vanligvis meget godt resultat i 20kvm, kjenner ikke ditt "idealbilde" men tight og ryddig blir det uten at huset rister. Jo dyrere jobedre selvsagt men elektronikken skal jo stå i stil så C1 med "full pupp" kan jo fort bli 4-5ganger dyrere enn med Focus 140. Fikk god lyd med Focus 140 på et gammelt Naim-system, men C1 på litt kraftigere Naim var deiiiligere
    Anonym
    hifiguru skrev:
    jabbalabba skrev:
    Hei,
    Uten å ha hørt 220 mk2 så vil jeg si at med en gulvstående 3-veis høyttaler med -3dB på 32Hz i et rom på 20m2 må en være mer enn litt heldig for å oppnå et lydbilde som kan beskrives som tight og ryddig.
    hifiguru
    Porsgrunn
    Så jo den fort kunne misforstås, mente de stativmodellene som ble nevnt, enig med at 220 fort kan booooome i 20kvm, selv om jeg brukte Contour 5,4 i 20kvm uten store problemer men skråtak både bak høyttalere og bak lytteposisjon gjorde rommet rimelig asymmetrisk ;)
    jabbalabba
    Hei,
    Takk for tilbakemeldingene.
    Ang lytte ideal så liker jeg usminket og naturlig lyd, at artistene oppstår i rommet følelsen.
    Derfor frister og Dynaudio.
    Men ønsker og at det er litt sjel igjen i musikken, ikke over analytisk med andre ord.
    Har og Stax hodetelefoner, og disse er fantastiske etter min mening.
    Mangler kanskje litt i mellom bassen, mens ellers meget gode.
    Pr idag har jeg SF Concerto Domus, disse har en meget flott og definert bass som går dypt, men jeg føler at vokal ikke føles riktig, noe farget over diskant/mellom tone.
    De fungerer veldig godt på lave volum, men kan bli litt mye bass ved høytspilling (boomy).
    Vil helst ikke miste den gode DYP bassen disse har (selv på lave/moderate volum), derfor lurte jeg litt på 220 mkII.
    Jeg har hørt litt på 140 ,S1.4 og C1, men lytterommet til Soundgarden er ikke 100% optimalt.
    Spesielt s1.4 ble veldig boomy selv på lave volum.
    Nå er dette ett rom med lite diskant og ekko i mellombassen, pluss at jeg vet ikke om noen av disse ht var helt innspilt heller.
    Derfor ville jeg gjerne høre litt med dere som har mye erfaring med de forskjellige modellene og hvordan det låter i vanlige rom.
    Jeg likte forsåvidt alle modellene på sine måter (vanskelig å definere s1.4 pga rom problematik/u-innspilt ht?).
    C1 var virkelig gode, men usikker på om de låter godt ved moderat/lave volum, manglet litt mellombass på lave volum? De virket uansett ikke over analytiske.
    Focus virket og veldig gode, selv på lave volum. Men kan de bli litt for mye oppmersomkrevende på lave volum? (til bakgrunnsmusik). Og det virket som de manglet litt pondus helt i bunn men dette kan igjen være pga rom de ble spilt i.
    Som nevnt fikk jeg ikke så veldig mye inntrykk av S1.4 pga ovenevnte.
    Ht skal "parres" med ASR Emitter I excl og Weiss Dac2.
    Hører mest på Jazz, viser og "gammel manns" rock ;) (pink floyd, dire straits o.l.)
    Litt mer tempo sterk rock blir det og, men dette er underordnet de andre sjangerne.
    emokid
    Jeg har ikke hørt focus 140 i eget rom, men har hatt både Contour 1.4 og C1 (samt C3, som jeg beholdt lengst).
    C1 er nok på langt vei en bedre haifihøyttaler enn 1.4. Kjappere, mer presis, luftigere etc. Opplever Esotek-diskanten i 1.4 som litt mindre "snerten" enn Esotar til C1. Dette gjør 1.4 litt hyggeligere å lytte til. Helt personlig ble C1 litt masete for meg, hvertfall når jeg sammenlignet direkte med C3.
    Det går nok litt på smak altså, om du vil like C1 eller 1.4 best. Begge høyttalerne trives best rimelig langt fra bakvegg, det kommer en del "mat" ut bassportene.
    Det burde vel være mulig å få lånt med hjem?
    jabbalabba
    Hvor langt mener du at de bør stå fra bakvegg for å låte optimalt?
    hifiguru
    Porsgrunn
    Når jeg hadde C1 menr jeg jeg det var ca halvmeteren, målt fra baksiden av kabinettet, brukte denne avstanden på stort sett alle DA jeg har hatt....
    2nd tought: De trives med ennå mer plass, låt veldig tight når jeg prøvde ennå større avstand, men ble nervøs om noen skulle komme inn døra ved siden av den ene.....
    tdbil
    Båtstø
    Hei!
    Er det noen som kan anbefale en forsterker som kan være en god match til C5?
    /Tommy
    Lieng
    Anonym skrev:
    hifiguru skrev:
    jabbalabba skrev:
    Hei,
    kjenner ikke denne høyttalern, men har to lytterom, hvorav det ene er ca 12m2 og har aldri hatt bedre lyd i det rommet enn med Magnepan 3.6 som er en forholdvis stor høyttaler om enn noe forskjellig fra Dynaudio, så har jeg ikke hatt noe problem med store høyttalere i små rom. I samme rommet bruker jeg nå normale treveis med 2*6.5 i bassen + to subber med 2*10 Peerless XlSS i hver sub. Skulle gjerne hatt mer memban i bassen både under og over 80Hz. Jo mer membran, jo mindre forvrengning og mer kontroll og stramhet, så sant forsterkern er god nok.
    emokid
    tdbil skrev:
    Hei!
    /Tommy
    Store gamle DP, Pass, Krell etc. Strømsterkt er ordet. Og FOR en høyttaler! ;D
    tdbil
    Båtstø
    emokid skrev:
    tdbil skrev:
    Hei!
    /Tommy
    Takker for svar emokid :)
    Jeg har også tro på pass eller krell.
    Ser det ligger en pass 250.5 på brukten tror du jeg må ha mere krefter en den?
    Tommy
