Finnes det noen "tweaks" som er så "over the top" at ingen går på de?
  • KJ
    Når du føler din audiofile switch blir i varmeste laget.
    Follow Your experience, I manage to put a large CPU heat sink and the sound improve surprisingly . Besudes,I do use Farad super3 with audio sensitivity signature silver dc cable on EtherREGEN switch. This further improve the quality with more dynamic sound and details. Good suggestions. Thanks. Now I am waiting for PHD SR7/T Power supply to come. Let see if any improvement for the switch.
    Bedre bilde på Netflix og/eller HFS? Kjøp en audiofil switch.
    Music via streaming services & NAS becomes 100% analog, natural & realistic.
    Even image quality via Netflix or other internet service improves drastically.
    Sound quality of this Dual OCXO Switch beats any other audiophile switch in the world so far.
    PS: For best resultat anbefales 2 switcher koblet i serie...
    Hmm, lurer egentlig hva poenget med OCXO klokke har å si for lyden.
    Finner ikke bedre ordlyd enn denne: Lærdom som alle bør få med seg.
    Remember, ethernet is a packet-based communication system. As such, it's by nature asynchronous with start/stop flow control from server to the end-point typically. There is no time-locked steady stream of data being transmitted requiring time sensitive immediate conversion to analogue audio. The packets are buffered by each device whether it's the Server computer, ethernet switch or ultimately your streamer. Sometimes, packets can even arrive out of order if there are parallel routes of transmission. This is why it actually makes no sense to claim OCXO/TCXO clocks will benefit "audiophile" switches by making a difference to the output from your DAC! Even if the switch ran on a more robust, steady pico/femtosecond accurate clock, what difference does it make when the data will have to be reprocessed by the receiving device's ethernet interface, buffered, and then fed into the DAC? Ultimately, it is the DAC's clock that will determine the temporal resolution of the analogue output (where anomalies like picosecond jitter may be found). Whatever temporal precision an OCXO is adding to the switch will be minuscule and irrelevant when you think of the complete "system".
    mvno_subscriber
    Asker
    Hvordan er det egentlig med markedsføringsloven i tilfeller som dette? Kunne man klaget det inn til et passende organ? Såpass konkrete påstander må de vel kunne fremlegge dokumentasjon for?
    Aurora
    Ytterst i havgapet...
    I Norge er det leverandør/produsent som bærer ansvaret for korrekt markedsføring. I dette tilfellet blir Forbrukerrådet riktig instans for klage, og importør blir ansvarlig for sin egen markedsføring. Jeg vil tro at om norsk importør bruker markedsføringssvada, så vil dette kunne rammes. Problemet er jo bare at norsk forbrukerlovgivning ikke har noen jurisdiksjon i utlandet. Men - de fleste vestlige land har vel en lovgivning mot feilaktig reklame og markedsføring...
    FOr min egen de finner jeg det mest merkelig at ellers normalt oppgående personer (?) tror på all kvasiterorien og er totalt immune mot normale tekniske eller fysiske forklaringer...
    mvno_subscriber
    Asker
    De som går på limpinnen i slike tilfeller har ikke nok teknisk kompetanse til å kunne vite om markedsføringen holder vann eller ikke. De er forbrukere, ikke produsenter. Og hvis de ikke kan stole på det som blir fremlagt som fakta, hvordan skal de kunne ta en informert beslutning?
    Jeg vil si dette er ganske spekulativt, og @hestepare : det du linker til - hva tenker dere om at hifisentralen har slikt på forsiden?
    Om noen vil selge eller kjøpe slike produkter er opp til dem, men hvor går grensen for villedende markedsføring? Hvilket ansvar har hifisentralen og annonsørene når det kommer til påstander, språk og formuleringer i det de presenterer?
    Harry Stoteles
    Jeg sletta posten fordi jeg så at det var det samme produktet som @bambadoo linka til over. Grunnen til at jeg ville poste det var det samme som du er inne på, spørsmålet om dette er ok. Var fristende å spørre under selve posten, men det er vel sponsorene som betaler for sentralen, så det var noe med å bite hånda som fôrer en…
    mvno_subscriber
    Asker
    Ser du spurte, +1 for det 😁😁
    Å bite hånda som fôrer.. er det ikke også snakk om å ha et marked med like vilkår og tillit til forhandlerne? Alle er vel tjent med et sett spilleregler. Ta for eksempel helsekostbransjen. Noe for alle, enten det er velkjent og dokumentert, eller eksotisk og sært. Og helt greit. Men i det man sier noe kurerer kreft, er grensen tråkket over, og det kan reageres mot. De aller fleste i bransjen vet hvor de har lov å manøvrere, og i sum er det noe alle tjener på.
    Markedsføringslovens §3 er ganske enkel og tydelig:
    § 3.Presentasjon og dokumentasjon av markedsføring
    Markedsføring skal utformes og presenteres slik at den tydelig framstår som markedsføring.
    Påstander i markedsføring om faktiske forhold, herunder om ytelsers egenskaper eller virkning, skal kunne dokumenteres. Dokumentasjonen skal foreligge på annonsørens hånd når markedsføringen skjer.
    https://lovdata.no/dokument/NL/lov/2009-01-09-2#KAPITTEL_1
    EDIT for hifisentralen gjelder det vel ikke noe mer enn et litt «løst» redaktøransvar for de annonsene som publiseres her. For forhandlere/forretninger/importører/agenter eller hva det skal være, som «ukritisk» videreformidler bullshiten fra produsentene er det ingen «beskyttelse» eller formildende omstendigheter, kan du ikke dokumentere påstandene som fremsettes så bør du la vær.
    Denne tråden har kanskje til hensikt å ha en "oppdragende" effekt? Poeng blir gjentatt, gjentatt, og gjentatt.. Ikke noe galt i det, her er det bare å bøye nakken og ta til seg lærdommen som så generøst deles ut ... :)
    mvno_subscriber
    Asker
    Så du tenker hifitweaksomikkeharnoeforsegbransjen er unik på dette området?
    Unik hvordan da? Jeg brukte eksempelet med helsekostbransjen fordi jeg synes det har mange likheter - et (tilsynelatende) håndgripelig emne som inneholder et univers av ulike metoder og tolkninger, og hvor den rent tekniske målestokken ikke alltid er den viktigste.
    Hva som eventuelt er unikt for hifibransjen er vel egentlig ikke så interessant? Poenget er at det må da være til alles beste å ha noen kjøreregler som sikrer et trygt marked, både for forhandlere og forbruker.
    P
    parafinoksen
    Vis vedlegget 665506
    6600,- pr stk. :eek: Sikkert meget effektive. Sortere blir det ikke.
    KONKURRANSE: GJETT HVEM PRODUSENTEN ER? (IKKE LOV Å GOOGLE!)
    Fra produsentens sider:
    PRODUSENT Sort Lift® is the preeminent cable support in the consumer electronics industry, and is the latest addition to our Sort System. By utilizing a patent pending floating spring design, the Sort Lift® enhances the sonic performance of loudspeaker cables, power cords, and interconnects, by minimizing the points of contact that cables make with the ground and reducing boundary effects, without negatively affecting the resonant properties of the cables themselves.
    The Sort Lift® is composed of two integral components: the base and the springs. The base is a stable, anodized, aluminum disk, designed to inhibit any transference of electrical charge from the floor to the cable and eliminate static build-up on the dielectric itself. This base supports the proprietary Floating Spring System. The Floating Spring System uses a flexible, titanium alloy spring-wire, which makes up both the support wings and tension wire supports. In both elements, the alloy wire is coated in FEP, mirroring the design of PRODUSENT cables and making the supports an extension of the cable jacket, eliminating any electrical interference, while allowing the cables to maintain their natural resonance properties.
    Sort Lifts® are provided in packs of two. They are intended to be spaced between 0.5 and 1 meter apart in distance, so that the cable does not come in contact with the floor. The spacing may depend on the weight and flexibility of the cable being supported. While designed to be used primarily with PRODUSENT cables, any audio cable will benefit from using the Sort Lift®. Noticeable effects include an elevated sound stage, improved dynamic range, increased detail in low frequency reproductions and more natural timbre to the sound.
    • Proprietary Floating Spring System uses titanium alloy and FEP coating
    • Anodized aluminum base
    • Reduces boundary effects and electrical interference
    • Inhibits transference of electrical charge and rids the
    dielectric of static build-up
    • Elevates sound stage, improves dynamic range, and
    increases detail in low frequency reproductions
    Total height: 84mm
    Diameter: 100mm
    Cable height off of floor: 24mm
    Må ikke le av kabelløftere. Sjekk hva troverdige positive feedback skriver om Audioquest sine.
    We've all got foggy conditions in the form of vagueness and smearing. Ambient RFI is a principle cause of low visibility compromising soundstage transparency. The AudioQuest Fog Lifters, a surprisingly effective, very affordable RFI remedy, act like focusing lenses and ratchet up definition. It's like affixing a girdle to the system's middle tire and containing the bloat. Not surprisingly, they work especially well with AudioQuest's own cables.
    There's no question that the Fog Lifters impact your sound—all of the cable supports in my inventory do—but why these in particular are so powerful I'm at a loss to explain. Use them sparingly, because the effect compounds. You don't need to lift up the entire cable or every cable. A single Fog Lifter under each Dragon PC (for a total of four) moved my sound firmly in the direction of expressive and refined. The temptation to pile them on should be avoided… you don't want to remove all the fog. I'm gonna add a couple to my spice rack.
    On the other hand, the Fog Lifters won't be much help if mechanical vibrations are your principle issue. Similarly, if you already have good transparency, they could be overkill.
    Så kan vi lese litt om utstyret til fyren som tester...
    CABLES
    Full suite of Kubala-Sosna Elation! and CH Precision Reference. Stage III Proteus, Kraken and Triton power cords, Argento FMR power cords. Argento FMR Phono. STEALTH Helios Phono, Sakra & Indra interconnects.
    ACCESSORIES
    TAOC Rack and Finite Elemente amplifier stands, Vibraplane ELpF Isolation Platforms, Acoustic System Resonators, Argent Room Lenses, GIK acoustic panels, Nordost QBASE and HB PowerStar Horizon Power Distributors. Furutech NCF Booster under the Stage III Proteus power cord. Nordost QKORE Ground Products.
    Voff
    Rart at disse dyre kablene er så dårlige at man må kjøpe tweaks for å få til å yte maksimalt.....
    Mener det var en produsent som laget så bra kabler at du faktisk klarte deg uten løftere.. Mener det er linket til i denne tråden.
    X
    X186841
    Disse påstandene om switcher er helt ute på tundraen.
    Så lenge de bruker påstander om opplevelser så går det sikkert greit,. Mange som hører litt av hvert der kona jobber. Men der får de i det minste hjelp til å bli kvitt opplevelsene i hodet som ikke samsvarer med virkeligheten i den dimensjonene de fleste lever i på denne planeten.
    Neida, du har ikke en god switch før du faktisk får en egen dedikert audiofil RJ45 jordkabel til formålet.
    Alle som ikke hører en klar degradering av lyd dersom en bruker normal og ikke audiofil switch med tilhørende tweaks har får dårlig anlegg og/eller dårlige ører.
    X
    X186841
    Husk å bruke tynne jordingskabler så du får fjernet de høye frekvensene som lager støy!
    Finnes det noen form for kabelsenkere, i tilfelle kablene yter for bra?
    Som noen skrev om den gamle Oldsmobile diesel V8-motoren: Only suitable for marine use, but not for propulsion purposes.
    Det var Siltech (som forøvrig har sluppet et par "natta" nettverkskabler nylig).
    Så lenge geometrien er riktig så er det ikke nødvendig med kabelløftere.
    Ellers så står det svart på hvitt i PF at ikke bruk for mange for da kan systemet ditt bli litt for avslørende. Da trenger vi å grave dem ned tenker jeg som nevnt tidligere her.
    Handsoer
    Sortland
    Om kablene skiller lag innenfor eller utenfor kabinettet spiller vel ingen rolle?
    Burde virke like godt som normal bi-wiring?
    Sertifikat og 2D-label er bare med på å øke eiergleden - og dermed effekten - av remediet.
    Voff
    For å spore av litt: Hva er egentlig fordelen med biwiring?
    Aurora
    Skjønner ikke helt den dingsen.... en magisk boks for å splitte HT-kabelen til bass-mellom/diskant ved høyttaleren? Istedet for magiske linkkabler??
    Aha! Nå skjønner jeg... magisk sand og ferritringer...... Det burde jeg jo ha skjønt..... pris med fire nuller???
    Aurora
    Nå er det vel teorien om at bassignalene intermodulerer og forstyrrer mellom/diskantsignalene i samme kabel som er opphav til denne biwiringtanken.....
    at øyeblikksverdien av ethvert signal er summen av alle delsignaler virker lite forstått... :cool:
    Snickers-is
    Ja, det er vel mange som tror at samtidige signaler betyr at det må gå strøm flere veier samtidig i kabelen. Et av de spørsmålene jeg trolig har fått flest ganger (som ikke omhandler valg av komponenter) er vel hvordan en membran kan gjengi flere frekvenser samtidig. Straks man får grep om ideen om å summere amplitude blir liksom dette (og biwiring) overflødig.
    Harry Stoteles
    Dette er veldig vanskelig å forstå. Hvordan kan elementet bevege seg langt og kort, langsomt og raskt samtidig? Sjøl har jeg en slags forståelse av det, men enkelt er det jo ikke for en uten ingeniør-/fysikk-bakgrunn.
    En grublis på nivå med at LP-plata beveger seg raskere ytterst enn innerst, selv om alt går like fort rundt.
    Får en jo til å tenke på hvor viktig visualisering og metaforer er for hvordan vi oppfatter verden, med fare for å bli for filosofisk.
    P
    parafinoksen
    Hadde mye moro med det som liten på karuseller på lekeplassen. Når du gikk helt inn til sentrum av karusellen, snurret det noe sykt fort i forhold til ved ytterkanten. Fenomenet var viktigere enn fysikkteorien :) Kan ennå kjenne kvalmefornemmelser når jeg tenker tilbake.
    Harry Stoteles
    Ja, det går vel like raskt innerst som ytterst (like fort rundt), men likevel beveger den ene seg lengre enn den andre… Til å bli svimmel av, absolutt!
