Grace Design m903
  • CDWMcInSpots
    Bergensregionen
    Grace Design kommer snart med m903 (http://www.gracedesign.com/products/m903/m903.htm) som er etterfølgeren til m902.
    Nyhetsbrev desember 2010: http://www.gracedesign.com/newsletter/dec10/newsletter12_10.htm
    Ten years ago, we launched the model 901 headphone amplifier. 4 years later, the m902, which set the standard for a new category of compact, precision playback tools. Today, we proudly unveil the m903, which is simply the most refined and feature rich headphone amp, DAC and compact monitor controller available.
    The m903 keeps everything great about its predecessors, adds some useful new features, and ups the ante with even more breathtaking audio performance. A new volume control provides higher headroom and lower distortion and noise. New generation DAC's and ultra-low noise balanced current to voltage converter yields even more musical performance compared to the m902. Improved s-lock PLL circuitry delivers even lower phase noise and jitter. An improved power supply isolates headphone amplifiers, line amplifiers, DAC's and digital logic, resulting in lower noise and distortion.
    Perhaps the most exciting improvement is the all new high speed USB interface. This cutting edge technology provides a completely asynchronous data transfer mode which allows for bit-perfect USB playback with zero interface induced jitter. This new interface affords standard driverless USB Class 1 operation on Windows and Mac up to 24bit/96kHz and USB Class 2 audio for 24bit/192kHz operation on Windows and Mac (drivers needed for 192kHz operation under Windows). This is computer-based audiophile playback, perfected.
    New crossfeed circuitry is even more useful and includes a gentle compensation to eliminate the perceived loss of low frequency content. Both balanced and unbalanced line outputs are now standard, with individual volume controls for each. We have even included a mono mode for checking a mix for phase issues or simply monitoring in mono. These improvements cement the m903 as the perfect compact, audiophile grade monitor controller, even for larger scale production environments with more than one set on monitors.
    A full complement of analog and digital inputs are provided (balanced, unbalanced, AES3, S/PDIF, TOSLINK and USB), which are selectable via a precision rotary front panel switch. And we offer an updated optional infrared remote control, which provides essential control for anyone working out of reach of their m903.
    Advancing the tradition of unmatched audio performance and functionality, the m903 is now the ultimate solution for high resolution audio playback. From the very top mastering engineers to the most discerning audiophiles – it is a must for anyone searching to discover new depths in music and sound.
    Available soon!
    Features
    • Balanced and unbalanced analog inputs
    • 24bit/192kHz digital stereo inputs- AES3, S/PDIF, TOSLINK and USB
    • High speed USB interface - completely asynchronous transfer mode allows for bit-perfect playback with zero interface induced jitter
    • Driverless operation on Windows & Mac up to 96kHz/24bit
    • Supports USB Class 2 audio specification for 192kHz/24bit operation on Windows & Mac (drivers needed for 192kHz operation under Windows)
    • New generation DAC's and ultra low noise balanced current to voltage converter yields more musical performance compared to the m902
    • Mono mode for checking mix phase issues (or listening to Pet Sounds)
    • s-Lock phase lock loop sample clock regeneration for ultra-low jitter and rock solid digital stability
    • High-current transimpedance headphone amplifier circuitry built to effortlessly drive low impedance headphones
    • Balanced and unbalanced variable level analog line outputs
    • Improved power supply architecture isolates headphone power amplifiers, line amplifiers, DAC's and digital logic
    • Precision level control with a 99.5dB range in 0.5 dB steps
    • Channel level matching accuracy of 0.05dB
    • Improved x-feed circuit eliminates perceived loss of low frequency content
    • Optional infrared remote control available
    • Internal linear power supply with custom wound toroidal transformer
    • Sealed gold contact relays used for all signal switching
    • Five year transferable warranty on parts and labor
    SPECIFICATIONS D/A CONVERTER
    • Input Sample Rate: 32, 44.1, 48, 88.2, 96, 176.4, 192kHz
    På Head-Fi har bruker mbgrace (Michael) gitt utdypende informasjon:
    • http://www.head-fi.org/forum/thread/521166/grace-design-m903-reference-headphone-amplifier-dac-monitor-controller/15#post_7045051
    • http://www.head-fi.org/forum/thread/521166/grace-design-m903-reference-headphone-amplifier-dac-monitor-controller/15#post_7064939
    Hi All,
    Just got back from AES in San Francisco and finally have a couple of minutes to myself. I thought I would tell a little about what is inside the m903. Basically there is no stone left unturned in the m903. Admittedly the specifications we published look a lot like the m902. I have yet to sit down at the Audio Precision and make official measurements for all of the performance parameters yet. The numbers you see are indicated as "preliminary" and are conservative. I will update them as we get closer to releasing production units.
    Anyway, here is a list of some of the circuit changes from the m902 design. Sorry if some if this gets too technical.
    DAC.
    We are using the PCM1798 as the DA converter. I think this is a brilliantly musical DAC. It may not have the same noise numbers as the 1792/4 but it doesn't draw 350mW either. This is important in the m903 since the DAC analog power supply is in the form of a shunt regulator.
    Following the PCM1798 is a new current to voltage (I/V) converter based on an unlikely suspect: THAT1570. This is actually a low noise front end amplifier for microphones and utilizes a current feedback architecture. While the I/V converter in the m902 was a current feedback amplifier the THAT1570 has substantially lower noise and lower distortion.
    The high pass filter section is now based on the OPA1612. Finally a low noise bipolar amplifier that sounds really good!
    The DAC audio power supplies and the line input/output supplies have now been separated from the headphone amplifier power supplies. This reduces dynamic interaction between the headphone power amp and the DAC analog circuits when driving difficult headphone loads.
    Clocks
    For bi-phase encoded digital inputs (toslink, spdif, and AES3) the m903 employs the same clocking architecture as the m902 with some significant improvements. (I'll get to the USB section in a minute).
    The s-Lock PLL contains new lower phase noise (jitter) VCXOs. As well, the phase comparator in the PLL has been upgraded to a low noise charge pump type circuit. (The HC9046 datasheet gives a nice treatment of this type of phase comparator). The overall PLL jitter rejection performance has been increased with a higher order loop filter which is now 18dB/octave.
    This all boils down to lower jitter at the DAC compared to the m902.
    Volume control
    The m903 volume control is based on the Cirrus CS3318. This is a really advanced volume control! It has 7dB lower noise than the PGA4311 and it runs on +/-9V power supplies. The channel matching is really tight (within several hundredths of a dB).
    Headphone amplifier
    This is, after all, the core of the m903. The headphone amplifier is the same basic topology as the m902 but the output short circuit protection circuit has been moved out of the signal path and into the power supply lines. As mentioned above, the headphone amp now has it's own set of dedicated power supply regulators.
    The crossfeed curcuit, which is licensed from Jan Meier, is a more sophisticated design than the one in the m902. It has some passive compensation that reduces the perception of loss of bass in some program material while maintaining the excellent upper register tonal transparency of the original circuit.
    Line outputs
    The m903 has both balanced and unbalanced outputs. (the m902 had one or the other) Each ouput has independent level control so you can hook up multiple speaker systems or you can use one set of outputs to feed a sub and the other for the main speakers. These outputs have a firmware setting for +/- 9.5dB output level trim for matching speaker efficiencies. There are also individual balance adjustments for each line output and power on preset level settings.
    USB
    the m903 now uses a completely galvanically isolated, asynchronous data transfer high speed USB interface. There is simply no PLL like *no* PLL.
    Clocking data out of a buffer with a low noise fixed oscillator is the ideal digital audio playback architecture.
    General
    One thing we didn't do is change how the m903 looks for the most part. However, the white 7-segment leds are nice and clear and much easier to focus on from across the room. Oh, and the input selector switch is now a really nice Swiss made EAO rotary switch that has a very solid feel and will last for ever.
    ...one more thing, there is now a mono mode. This is probably a more practical feature in a music production environment but it will be fun for listening to Pet Sounds!
    Cheers,
    Michael
    The crossfeed circuit is switched in and out of the signal path with a relay. When it is engaged a white LED illuminates on the front panel. The crossfeed can be turned on and off directly from the optional IR remote control or from the parameter edit menu at the front panel of the unit.
    The m903 was not designed with an architecture to support minimum phase filter options.
    The m903 uses the Wavelength Audio asynchronous technology.
    Cheers,
    Michael
    Det ser ut som om ProLyd er norsk importør:
    Informasjon fra Hifisentralen:
    vredensgnag skrev:
    Det viktigste, ved bruk av en headphone-amp i slik forbindelse, er hvordan den simulerer crossfeed fra L>R øret og R<L øret. Det gjør en Grace m902 (0g nå m903) så det er til å applaudere.
    vredensgnag skrev:
    Og så er det en god del DACer som ikke har asynkron USB, og disse bør man unngå. Av den grunn ville jeg f.eks. ikke kjøpt en Grace m902 i dag, dersom det var utsikter til bruk av USB-tilkoblingen - Grace har implementert asynkron USB i m903. Men da m902 ble lansert var det ingen som reflekterte over behovet i forhold til USB.
    I tillegg bør man vurdere om man vil ha galvanisk skille mellom datamaskin som potensiell støykilde og DAC. USB er mer sannsynlig overfører av f.eks. PSU-indusert støy - og det har selvsagt ingen ting med protokollen å gjøre, men med at det er fast kontakt.
    totte skrev:
    ceroxol skrev:
    Leser at Grace m903 har lisensiert Wavelenght (Gordon Rankin) sin Streamlenght HS kode, samme som Ayre, Halide Design, Aesthetix.. Regner med det dukker opp en test på Computeraudiophile om ikke lenge.
    Den har også galvanisk skille på usb-inngangen.
    De første kommer til Prolyd ila 2 uker.
    Man skrev:
    M903 har balansert ut. Jack.
    totte skrev:
    Artig dette. Jeg har den helt nye Grace m903 hodetelefonforsterker/dac i bestilling (kommer kanskje før jul...). Denne har ulike digitalinnganger, inkludert s/pdif og asynkron og galvanisk isolert (i motsetning til på m902) usb-inngang. Jeg skal jammen få meg en slik kabel for å sammenligne mellom inngangene. Artig ja.
    totte skrev:
    Hjemme i leiligheten har jeg nyinnkjøpte Sennheiser HD800 og Grace m903 i bestilling. Disse skal kobles sammen og drives av laptop med J.River og ikke utsettes for tweaking eller noe annet, men kun brukes til å lytte til.
    CDWMcInSpots
    Bergensregionen
    Hodetelefonuttakseffektspesifikasjoner
    CDWMcInSpots skrev:
    Jeg har lett etter, men ikke funnet, hodetelefonuttakseffektspesifikasjoner ("headphone power spec") for Grace m903 (og m902). Kan noen hjelpe?
    Jeg tenker altså på data á la det jeg f.eks. fant for:
    NuForce Icon HDP på http://nuforce.com/hp/products/iconhdp/index.php:
    Headphone power spec:
    288mW rms @ 30 Ohm
    210mW rms @ 120 Ohm
    152mW rms @ 300 Ohm
    123mW rms @ 500 Ohm
    96mW rms @ 600 Ohm
    59mW rms @ 1200 Ohm
    43mW rms @ 1700 Ohm
    35mW rms @ 2000 Ohm
    SPL Phonitor på http://www.spl.info/index.php?id=358&L=1 og http://www.spl.info/fileadmin/user_upload/anleitungen/english/Phonitor_2730_BA_E.pdf:
    Max. Output Performance:
    1,7 W (+32,2 dBm) @ 1 kHz and 600 ? connection
    360 mW (+25,6 dBm) @ 1 kHz and 30 ? connection
    Jeg har funnet tilsvarende tabeller/oversikter for andre hodetelefonforsterkere, men altså ikke for Grace m903 (og m902).
    Svar fra Neal Thompson ved Grace Design Technical Services:
    To answer your question, the m902 has a maximum output of +9.11Vrms.
    Output at 30 ohms is 2.77 watts and at 300 ohms 276 milliwatts.
    We don't have the final specs on the m903 yet, but they will be very close to the m902.
    Tillegg:
    600 ohms = 138 milliwatts.
    Tillegg 2:
    As headphones are an active impedance load that changes with frequency, ohm's law is not perfect, but the relative levels with different loads will be correct. The m902/903 provide plenty of power to drive any headphone to very loud levels.
    CDWMcInSpots
    Bergensregionen
    Salgsstart i Europa
    Svar fra Neal Thompson ved Grace Design Technical Services 18.01.2011. Jeg spurte ham om når Grace Design m903 er klar for salg i Europa under korrespondansen ang. hodetelefonuttakseffektspesifikasjoner.
    The m903s should be shipping to Europe within the next 60 days.
    totte
    Salgsstart i Europa
    Hmmm...
    De er ikke så flinke til å informere forhandlerne sine. Jeg snakket med Prolyd for en 1/2-time siden og det siste de har hørt var at de skulle sendes forrige fredag. De første som kommer til Prolyd er så vidt jeg vet bestilt allerede, så til de kommer "i hyllene" går det nok enda mer tid.
    V
    vredensgnag
    Salgsstart i Europa
    Hmmm...
    Det kan godt være at ProLyd er inne i en U.S. batch som skal ut.
    CDWMcInSpots
    Bergensregionen
    DAC-delens kvalitet/ytelse
    Kan noen med god DAC-kompetanse gi oss en vurdering av/formening om DAC-delens kvalitet/ytelse?
    Tillegg:
    Jeg er klar over at neppe noen har hørt Grace Design m903 ennå. "Vurdering av/formening om" må baseres på bl.a. oppgitte komponenter inkl. DAC-brikke, andre produkter med samme komponenter, Grace Design m902s DAC-del o.l.
    totte
    Omsider bekreftet shipping-dato fra Grace: Fredag om en uke, i.e. 4. februar. ProLyd har dem dermed på lager den 11. ProLyd har bestilt noen ekstra, så de vil ha et par på lager som ikke er forhåndsbestilt.
    trex
    Forrige modell M902 er ihvertfall meget høyt ansett i profflyd-miljøer, skal man dømme etter innlegg på forum og reviews i fagblader.
    Har den en høy stjerne hos proffene, kan man påregne god support, rimelig god lyd og solid og pålitelig byggekvalitet. Nå hender det vel at studioer har andre krav/preferanser til lyd enn konsumermarkedet, men denne har vel vært en suksess i begge leire.
    En prestasjon i seg selv.
    De vil sikkert følge opp suksessen, og dermed være forsikitge med de store endringene.
    V
    vredensgnag
    I 2007 lånte jeg hjem en rekke DACer, bl.a. Grace m902. Det var ikke noe å stusse på, etter at jeg hadde prøvelyttet samtlige. Grace m902 var simpelthen "riktigere" i lyden enn de øvrige jeg hadde til prøving.
    Det var også walk-over i "topplokk av" konkurransen. Ser at 903 skal by på forbedringer, og det er bare å gratulere. Bruker den også mye med headphones, og kunne ikke sagt at noe savnes fra denne enheten. Har vært i bruk daglig i over tre år, og har vært påslått ihvertfall i 2,5 av de årene.
    CDWMcInSpots
    Bergensregionen
    Hvilke DACer sammenlignet du med?
    CDWMcInSpots
    Bergensregionen
    Grace Design m903 + Bang & Olufsen BeoLab 3
    Jeg antar at du har forsøkt Grace Design m903 som (kilde og) forforsterker med Bang & Olufsen BeoLab 3? Er dette en god kombinasjon generelt, og spesielt for et rom på ca. 10 kvadratmeter?
    CDWMcInSpots
    Bergensregionen
    På forespørsel fra Bx i hodetelefontråden, redegjorde totte og jeg for (noen) av våre overveininger og grunner for å bestille Grace Design m903.
    Opptakten var:
    CDWMcInSpots skrev:
    Grace Design m903 virket så interessant basert på det jeg kunne lese om den og Grace Design m902, at jeg bestilte den. Jeg skal bruke alle tre delene: Hodetelefonforsterker, DAC og forforsterker:
    CDWMcInSpots skrev:
    Andre prioriterte oppgaver
    Innspilling av nytt utstyr: [...] Grace Design m903 (ankommer forhåpentlig Oslo 04.02.2011 og Bergen neste uke).
    Så skal jeg finne passende høyttalere til Grace Design m903 for et rom på ca. 10 kvadratmeter. Jeg lurer på om Bang & Olufsen BeoLab 3 kan være et godt valg? Dette er vel evt. tema for en egen tråd:
    _________________________________________________
    Så svarte vi Bx:
    totte skrev:
    Bx skrev:
    CDW etc... ;D
    Da går jeg ut fra at du har vurdert Benchmark også. Hva var utslagsgivende for at valget falt på Grace?
    Og hva slags hodetelefoner du tenkt å benytte?
    Jeg har også bestilt Grace m903 (og har ventet lenge nå, men til uken...). Fordi:
    -asynkron usb-inngang med galvanisk skille (nytt i forhold til m902)
    -crossfeed (som er beskrytt på m902, og angivelig noe forbedret på m903)
    -en fornemmelse av at Grace m902/903 er headamper med dac og at Benchmark er mer dac med headamp.
    -kompakt og solid bygget.
    Jeg har ikke/knapt hørt noen av dem, og heller ikke satt meg inn i sakene, så valget er tatt på sedvanlig sviktende grunnlag.
    Jeg skal drive Sennheiser HD800 og driverdelen i Stax SRM272-II (som igjen driver lukkede Stax 4070)
    CDWMcInSpots skrev:
    Bx skrev:
    CDW etc... ;D
    Jeg har lest om Benchmark DAC1-familien tidligere, men den falt litt ut etterhvert av flere mer eller mindre gode grunner. En av dem var Svenske HiFi & Musiks testomtale av Hegel HD10 og sammenligningen med nettopp Benchmark DAC1 (http://www.hegel.com/HD10_HifiMusik_Nov2009.pdf).
    Noen grunner for å velge Grace Design m903 (uten å ha hørt den):
    • Asynkron USB-DAC-inngang med galvanisk skille
    • Meget god hodetelefonforsterker
    • Crossfeed for sikkerhets skyld og snurrige opptak (se crossfeedinnlegg i T 1-tråden)
    • (Meget) god DAC
    • Reklokkende DAC med låsing (robust mot jitter fra kilde)
    • DAC støtter 88,2 og 176,4 kHz (dette er dessverre langtfra selvsagt)
    • (Meget) god forforsterker
    • Nok innganger: 2 analoge, 4 digitale
    • Nok utganger: 2 variable analoge
    • En del ekstra funksjonalitet som balansekontroll og gaininnstilling
    • Solid, liten og (rimelig) pen
    • Styrbar med fjernkontroll
    • Meget positiv omtale av Grace Design m902
    • Samplingfrekvensindikator for innkommende digitalsignal (bonusgrunn)
    Selv Benchmark DAC1 HDR mangler en del av dette. Prisen er visst omtrent lik.
    Peachtree Audio Nova og iNova ble forlatt etter et besøk hos Oslo Hi-Fi Center, og det nye bekjentskapet Wadia 151PowerDAC mini hadde dessverre ikke på langt nær alle mulighetene jeg ønsker (http://www.hifisentralen.no/forum/index.php/topic,55399.msg1060133.html#msg1060133).
    Til å begynne med tenkte jeg på et mer tradisjonelt oppsett rundt f.eks. NAD C375BEE eller Cambridge Audio Azur 840A (Version 2). Jeg hadde tenkt å la en forsterker med A/B-høyttalerutganger drive høyttalere i 2 rom, men da kjøkkenløsningen ble Logitech Squeezebox Touch + Audio Pro LV2 (http://www.hifisentralen.no/forum/index.php/topic,50462.msg962965.html#msg962965) åpnet det seg nye muligheter, og jeg falt etterhvert for ideen om et (rimelig) kompakt anlegg. Jeg er forøvrig enig med Stereophiles Sam Tellig om at NAD C375BEE er en (lydmessig og funksjonelt) attraktiv forsterker. Jeg er også enig med What Hi-Fi i at Cambridge Audio Azur 840A (Version 2) kan bli litt for ivrig slik at reggae ikke får den rette "husken". Her var NAD klart bedre. Ellers er de vel rimelig jevnbyrdige, men forskjellige. Begge har god funksjonalitet og høy effekt.
    Jeg kunne også ha startet med min NuForce Icon HDP, men den har f.eks. ikke fjernkontroll og kun USB, én annen digital og én analog inngang som er valgbar uten omkobling.
    Mye annet har også vært innom i tankene en eller flere ganger.
    Og hva slags hodetelefoner har du tenkt å benytte?
    Det meste av samlingen:
    • beyerdynamic T 1
    • Sennheiser HD 800
    • Denon AH-D7000
    • AKG K 701
    • Sennheiser HD 380 Pro
    De tre første får formodentlig det meste av tiden.
    Den vil også bli benyttet med headset (Hodetelefon med mikrofon) når jeg kommer så langt (http://www.hifisentralen.no/forum/index.php/topic,54710.0.html). Jeg venter på å få prøve en AKG K 272 som forarbeid for valget.
    Staxene har selvsagt egne forsterkere (http://www.hifisentralen.no/forum/index.php/topic,54457.msg1039032.html#msg1039032).
    Bose QuietComfort 15 benyttes normalt bare til Apple iPod.
    • http://www.hifisentralen.no/forum/index.php/topic,54313.msg1039527.html#msg1039527
    • http://www.hifisentralen.no/forum/index.php/topic,54313.msg1039718.html#msg1039718
    Koss Porta Pro er høyst sjelden i bruk.
    Apple originale iPod-ørepropper teller vel ikke?
    Har jeg glemt noe?
    CDWMcInSpots skrev:
    Jeg har (vel) også fått det inntrykket. Jeg fikk samtidig inntrykk av at Stereophile mente at m902s DAC var på samme nivå som Benchmark. Ikke lik, men likeverdig. Forforsterkeren var visst også bra. (Se http://www.stereophile.com/headphones/406grace/)
    totte
    Den lar vente på seg.
    Den bekreftede shippingdatoen er passert, men i går lovte de å sende den i dag, så i neste uke skal den være i Oslo.
    totte
    Men neida...
    Men neste uke er levering bekreftet! :-\
    ErosLoveking
    Men neida...
    en farse.
    Er vel snart like greit å svi av 15 lapper på platemessa på Mono i morra.
    Moiz Audio
    bare å ringe grace design...husk gratis via skype spør etter jeff eller michael
    CDWMcInSpots
    Bergensregionen
    Salgsstart i Europa
    Det kan se ut som om denne informasjonen kan stemme ganske bra - hvis den da ikke viser seg å være for optimistisk.
    CDWMcInSpots
    Bergensregionen
    Det ser ut til at distribusjonen av Grace Design m903 startet i USA 09.02.2011. Noen kunder har mottatt sitt eksemplar jfr. innlegg i Head-Fi-tråden "Grace Design m903, reference headphone amplifier, DAC, monitor controller" (http://www.head-fi.org/forum/thread...headphone-amplifier-dac-monitor-controller/30):
    paulchiu 2/14/11 at 1:39pm
    http://www.head-fi.org/forum/thread...lifier-dac-monitor-controller/30#post_7276627
    just got a call from my dealer
    they got the first shipment from grace of the m903
    neil at grace design said that they shipped to a number of dealers on feb 9th
    paul
    Tråden inneholder noen få, tidlige brukererfaringer og henvisning til en testomtale (http://www.head-fi.org/products/grace-design-m903-reference-headphone-amplifier-dac)
    totte
    ErosLoveking skrev:
    Hva sier Prolyd denne uka? Noe på gang?
    De venter også. Jeg er dog mer optimistisk enn noen gang og er ganske sikker på at jeg har min hjemme innen helgen.
    totte
    ##Breaking News##
    -ankommet Prolyd!
    V
    vredensgnag
    totte skrev:
    ##Breaking News##
    -ankommet Prolyd!
    Ser frem til rapport - skal du bruke hodetelefoner må du melde hva du syns om den Xfeed algortimen de bruker. Jeg lar være å si noe, så jeg ikke farger ditt inntrykk!
    CDWMcInSpots
    Bergensregionen
    Crossfeeddelen er oppdatert fra Grace Design m902 til m903. Utdrag fra tidligere i tråden:
    CDWMcInSpots
    Bergensregionen
    totte skrev:
    ##Breaking News##
    -ankommet Prolyd!
    Musik Magazinet ringte nettopp og fortalte at min er klar til avhenting i Bergen. Jeg hadde trodd at jeg måtte vente til (tidlig) neste uke.
    Fjernkontrollen kommer i separat sending, forhåpentlig om 1-2 dager.
    ErosLoveking
    NEVATON skrev:
    totte skrev:
    ##Breaking News##
    -ankommet Prolyd!
    stemmer...så det var kø utenfor møllaparken idag ;D
    Særlig! Telefonkø i såfall. Ikke mange som fikk sin 903 idag.........
    Det var det jeg visste, kunne brukt langt mer på vinyl på platemessa sist helg, og hatt det langt mer moro.
    Grace er ei luremus.
    V
    vredensgnag
    Klar over den justeringen. Nå er jeg såpass rar at jeg kjører lyd ut gjennom høyttalerne for å få bass mot kroppen, mens jeg lytter gjennom hodetelefoner ... så jeg har ikke savnet noe.
    Men jeg er imponert over hvor godt den algoritmen lager realistisk rompersepsjon med og uten.
    CDWMcInSpots
    Bergensregionen
    Jeg hadde egentlig en mistanke om det fordi du pleier å være godt orientert.
    Har du noen gang hørt SPL Phonitor, enn si sammenlignet crossfeed på den og Grace Design m902?
    Loevhagen var interessert i same konsept, og jeg svarte ham ved å sitere deg. Du kan jo gjerne fylle på med mere informasjon til Loevhagen i hodetelefontråden:
    CDWMcInSpots skrev:
    • Loevhagen skrev:
      Er det noen som har koblet en subwoofer til head-fi-anlegget sånn bare for å øke morrofaktoren?
      Loevhagen skrev:
      Det var seriøst ment fra min side. Ikke at man savner bass i ørene med hodetelefoner, men man får ikke basstrykk i resten av kroppen. En subwoofer integrert riktig kan gi den fysiske følelsen i tillegg.
      Vredensgnag har nesten gjort det, og beskrevet og berømmet det relativt nylig i et par innlegg. Han benyttet vel Bang & Olufsen BeoLab 5 istedenfor subwoofer, men hensikten var den samme som du beskriver.
      Etter en del leting fant jeg innleggene:
      CDWMcInSpots skrev:
      vredensgnag skrev:
      Noen andre som har eksperimentert med å lytte til klokker, mens man også kjører musikk gjennom anlegget?
      På den måten får jeg klarheten i gjengivelsen gjennom klokkene, og musikk mot kroppen fra bassen.
      Very nice.
      Jeg har vel bare gjort det som hendelige uhell som jeg raskt har rettet.
      Mer eller mindre veloverveide spørsmål:
      • Åpne hodetelefoner (formoder jeg)?
      • Delefilter slik at høyttalerne bare spiller bass eller alt?
      • Ingen problemer med blanding av mellomtone og diskant fra hodetelefon og høyttalere hvis hodetelefonene er klarere?
      • Ingen problemer med tidsforskjell?
      JA
      NEI - har prøvd, men fungerer uten å dele.
      NEI
      NEI
    vredensgnag skrev:
    Tidsforskjellen, i den grad den er der, syns å skape en åpnere lyd.
    Det som kommer fra klokkene dominerer såpass at smittelyd utenfra ikke sjenerer i det hele tatt.
    Og det gir en god følelse å kjenne bassen mot kroppen.
    CDWMcInSpots
    Bergensregionen
    Selv er jeg en novise når det gjelder (behovet for) crossfeed (og speaker angle), men jeg har skrevet litt om mine erfaringer og tanker så langt:
    • http://www.hifisentralen.no/forum/index.php/topic,55346.msg1059168.html#msg1059168
    • http://www.hifisentralen.no/forum/index.php/topic,55346.msg1062778.html#msg1062778
    Anonym
    Håper en av dere med ny Grace føler dere såpass misfornøyde at dere legger den ut på bruktbørsen til halv pris, jeg har lyst på en sånn.
    totte
    Da er vidunderet koblet opp. Den er liten, tung, virker skuddsikker og lyser pent opp. Volumkontrollen synes til og med å være en step-attenuator. Det eneste lille skår i gleden er at det ikke kommer lyd ut når jeg bruker ASIO fra JRiver, selv om det fungerte fint med HRT så sent som i går.
    Jeg har koblet den til med den medfølgende usb-kabelen. Jeg fikk en melding om at en eller annen driver ikke var funnet og installert. Jeg har selectoren på "usb" og det lyser orange på "s-lock usb" og grønt på 96.
    Noen tips?
    totte
    Nei, ingen bedring.
    Dessuten, når jeg kjører "direct souns" fra JRiver så hakker lyden en del.
    nma
    Kanskje den har en switch som lar en bruke USB Class 1.0 eller 2.0. For å bruke den i Windows uten driver så skal den isåfall stå i Class 1.0.
    Og windowsdriverne har innebygget asiodrivere. Du må avinstallere de eksisterende ASIOdriverne. (ASIO4ALL e.l)
    totte
    Den kan switches mellom usb 1.0 og 2.0, og jeg har ikke avinstallert ASIO-driverne. Takker, prøves snarest.
    totte
    Etter å ha installert også den ekstra >96 driveren og så avinstallert asio4all så får jeg opp en feilmelding når jeg prøver å spille med ASIO.
    nma
    og da står switchen på class 2.0 ?? veldig rart! Men jeg har ikke personlig erfaring med den enda, så alt utover dette blir bare spekulasjon fra min side ;)
