Monitor Audio venner
  • Bjørn.H
    Mer info:
    Gold GX100 £1250
    The GX100 is a larger 2-way stand mount speaker featuring a 6.5” RST bass driver
    and C-CAM ribbon tweeter. Operating with the performance of a typical 8”
    driver, our proprietary 6.5” design provides higher overall efficiency with
    dynamic headroom to deliver impressive bass extension and control. The GX100’s
    uncomplicated 2-way configuration renders complex material with tonal accuracy
    and perfect timing. It may occupy the space of a stand-mount speaker, but the
    GX100 sounds like a reference floor-stander. Optional, dedicated floor stands
    are available.
    Gold GX200 £2300
    The first of the GX floor-standers is also the most compact. Amazing scale and
    impressive dynamic control are available from this slender three way design,
    comprising the GX ribbon and twin 5.5” bass drivers either side of a dedicated
    4” mid-range driver housed in a dedicated enclosure. With high overall
    efficiency, wide bandwidth and vanishingly low distortion, the GX200’s Platinum
    DNA is waiting to be experienced in a performance comparable with the very best
    and most expensive high end speaker systems.
    Gold GX300 £3000
    Standing at over a meter tall the GX300 is a majestic three-way floor-standing
    loudspeaker comprising twin 6.5” bass drivers, a single 4” mid-range driver and
    a high frequency ribbon transducer. With so impressive a complement of drivers,
    the GX300 has the power delivery and scale required to fill the largest rooms
    with jaw-dropping dynamics as well as the finest musical detail. Extending from
    below 30Hz to over 60kHz, its frequency range is among the widest available
    from any speaker, irrespective of price.
    Sublime fidelity, peerless build quality and exquisite design distinguish the GX300
    as a future classic.
    Gold GXC 150 £650
    The ultra-compact GXC 150 centre speaker is small enough to fit into most AV racks
    and is designed to match the smaller GX speakers in a more bijou home theatre
    configuration. However because it shares its tonal characteristics with all GX
    models, its capabilities are also compatible with any GX system design. The GXC
    150’s lustrous sealed cabinet is home to twin 5.5” drivers and the GX ribbon in
    a two and half way orientation, providing superior dispersion across a range
    from 50Hz to 60kHz. The specialised high frequency ribbon offers exceptional
    detail and vocal intelligibility, enhancing communication with the listener.
    Gold GXC 350 £1000
    The GXC 350 centre speaker is a no-compromise centre channel solution for serious
    home theatre installations. Its three-way, four driver configuration mirrors
    that of the GX300, although the bass drivers are tuned to work in the GXC 350’s
    sealed cabinet. Unsurprisingly the GXC 350 is the perfect match for its
    floor-standing counterpart, producing frequencies from 40Hz to beyond 60 KHz. A
    neutral tonal balance and distortion-free sound gives the GXC 350 the ability
    to project crystal-clear dialogue and mid-range detail at any volume. A
    dedicated floor stand is available to ensure the most secure footing and ideal
    vertical orientation for the GXC 350.
    Gold GX-FX £1400
    Matching the extraordinary tonal accuracy of its GX range mates, the GX-FX design
    provides direct or ambient surround sound, which may be switched manually or
    automatically via a 12V signal from the processor to accommodate the
    functionality of high-end home or professional cinema applications. Amazing as
    it may seem, the GX-FX slim wall-hugging profile incorporates no fewer than six
    drivers.
    In monopole mode for discrete side or rear sound channels its front-firing 6 ½”
    RST® bass/mid driver and C-CAM ribbon transducer deliver accurate
    ultra-wideband sound to match the tonal balance of any GX speaker combination.
    In dipole mode the GX-FX uses two pairs of side firing 4” C-CAM bass/mid
    drivers and 25mm C-CAM® gold-dome tweeters, combined with the tailored output
    from the front-firing bass/mid driver to provide wonderfully diffuse yet tonally
    precise surround effects.
    The GX-FX can be flush-mounted on side or rear walls. Installation is made easy by
    the inclusion of a ‘sloppy fit’ pre-install bracket, which allows levelling and
    adjustment prior to fixing.
    GXW-15 £1750
    The GXW-15 is an example of state-of-the-art subwoofer design. In a gloriously
    glossy, rigid compact enclosure, we’ve installed an ultra-long throw 15” C-CAM
    bass driver, triple suspended for a full 38mm (1.5”) of linear excursion.
    Featuring a massive magnet structure and under the DSP control of a 650W
    D2AUDIO® DSP controlled amplifier, this extraordinary deep bass generator
    brings a new dimension to bass and reference results for SPL, dynamic control
    and headroom.
    It may deliver taut gut-churning bass all the way down to a seismic 18Hz, but the
    GXW-15 is also an intelligent design, featuring an advanced automatic room
    correction system called LEO™ (Listening Environment Optimizer). LEO simply and
    automatically eliminates the detrimental bass boost of boundaries and corners
    through the use of a microphone and test tones. The GXW-15’s sealed enclosure
    and front firing driver make it easy to install and calibration from the
    front-mounted controls and dimmable LED display is simple, even from a distant
    position. It’s equipped with a 12V trigger and remote control with four user EQ pre-sets.
    Clare Newsome is Editor-in-Chief of What Hi-fi? Sound and Vision
    http://community.whathifi.com/forums/post/554207.aspx
    Bjørn.H
    Making it debut here at CES 2011 is the new Monitor Audio GX speaker range. Available from April, prices range from £650 to £3000.
    Monitor Audio says its in-house design team was charged with "finding a blend of materials and geometry that would complement the GX's exceptional sound". Main attributes of the design include:
    • New C-CAM Ribbon transducer design – providing extension to 60KHz
    • New 6.5in bass driver with RST profile C-CAM cone
    • Die-cast alloy driver chassis design
    • HiVe port technology for better transient response and tighter bass
    • Single bolt through driver fixings for improved bracing, rigidity and driver/baffle de-coupling
    • Die-cast alloy terminal panel arrangement with high quality bi-wire terminals and high end spade type link cables
    • Pureflow Silver internal cabling
    • High-quality crossovers with premium grade polypropylene film capacitors used throughout
    • Large radius cabinet edges to provide low diffraction and smoother overall frequency response
    • Curved cabinet profile for increased rigidity and reduced internal standing waves
    • Selected premium quality wood veneers or high gloss piano finishes.
    • Rigid 20mm MDF construction throughout, employing radial and cross-bracing techniques for high rigidity resulting in low cabinet colouration
    • Invisible magnetic grille fixing provides clean visual styling when used with the grille off
    • Metal mesh grille design to give low diffraction, resulting in improved off-axis dispersion
    http://www.whathifi.com/News/CES-2011-Monitor-Audio-unveils-GX-speaker-range/
    torem
    Ja, MA kan dette med stilige brosjyrer. Bånddiskant er tydeligvis tingen (hentet fra PL-serien?).
    Doc.G
    Steinkjer, Nord Trøndelag
    SOEDAL skrev:
    Doc.G skrev:
    Ja, enorm oppgradering fra dome diskanten.
    Betyr det at du har hørt dem?
    Har nettopp oppgradert fra GS20 til PL200, og hvis PX tar mye fra PL så vil diskanten være en av de største forbedringene.
    Nuth1986
    Slemmestad
    Jeg får vel melde meg inn her jeg også da, har hatt br6 som gamle far har tatt over. Etter dette gikk jeg til innkjøp av rx8 som jeg var meget fornøyd med. Disse byttet jeg ut i noen nye fine gs20 i pianolakk. Disse står nå til innspilling, men har akkurat solgt vincent forsterkeri og venter på xindak 6950 som kommer i posten om noen dager;) håper dette er en bedre match;)
    slotdriver
    Da må vel jeg også melde meg inn. Har et par GS20, en Xindak XA6950, en Hegel HD10 dac og en MacBook Pro som lydkilde. Alt unntatt macen er kjøpt brukt. Har startet med Nordost-kabler og er fornøyd med det. Men så er jeg novise i denne sammenhengen. CD-samlingen er forøvrig rippet i Apple lossless og alle CD-ene har fått nytt liv.
    Nuth1986
    Slemmestad
    hei er du fornøyd med machen din? spent på hvordan det vil låte i forhold til vincenten;)
    M1
    M1 skrev:
    Hei, noen som har erfaring med PL 200?
    M1
    Da ble det PL 300 på meg etter å ha testet både PL 200 og 300. De har nå spilt ca 350 timer sammen med JR Mono blokker, benytter Chord ht kabel. Godt fornøyd med disse fra topp til tå.
    M1
    Nuth1986
    Slemmestad
    Hei er det noen her inne som kunne lånt meg noen din kabler? Og som bor i oslo området. Send pm.
    Lurte også på om noen har erfaring med naim nait5 den litt eldre modellen. Kontra den nye? Naiti5. Og må jeg ha kilde fra naim? Har GS20
    slotdriver
    Vasnkelig å si. Har aldri hatt et stereoanlegg som er så bra. Er ny innen hifi, men bra låter det i hvert fall! ;D
    Nuth1986
    Slemmestad
    slotdriver skrev:
    Nuth1986 skrev:
    det er flott å høre håper du blir en venn lenge :)
    Nuth1986
    Slemmestad
    hei har fått gs 20 i hus og har spillt på de en stund nå. så tenkte jeg at jeg skulle teste de skikkelig en dag. og satt på infected mushroom, men i den ene sangen så skrudde jeg skukkelig opp og der er det et stille spor med bare bass, til min fortvilelse hørte det ut som høytaleren skurret, men etter nøyere granskning så viste det seg at det er luften som kommer ut av bassporten bak på høytaleren som lager denne lyden, det høres nesten ut som om at det er et tørt løvsom blåser inni høytaler porten. andre som har dette problemet?? og skal det være slik?? har strammet skruer og det jeg kan men fortsatt samme lyd.
    relløm
    Jeg kunne også høre en ulyd på enkelte spor på mine pl 200.
    Strammet det jeg kunne på bassportene , det er også skruer for kabinettresonans .
    Ht elementene strammet jeg også til , ble kvitt ulyden og de spiller veldig bra .
    Hilsen Tore .
    Bjørn.H
    Har aldri hatt samme problemet.
    Nuth1986
    Slemmestad
    Ringte hifi huset og de sa at dette kunne være et problem på enkelte spor med infected. siden det er lang slag lengde på elementene og det skal flyttes nye luft.
    Nuth1986
    Slemmestad
    NAIM VS ABRAHAMSEN
    Hei er det noen med god erfaring her inne som kan fortelle meg for og imot abrahamsen kontra naim.?
    Monitor audio GS20
    jeg har disse valgene:
    Naim Nait 5 (den eldre versonen)
    Abrahamsen: V2 integrert.
    Vurderer lyd kilde fra samme produsenter.
    selvfølgelig kan jeg ta med å teste men det er litt vanskelig, når man skal kjøpe brukt. Derfor fint med innspill som noen har hatt begge eller det ene alternativet som kan gi meg litt input på hva som kansje vil være best.
    Hører på Mark Knophler og mye lounge musikk. samt at jeg tar meg en fest og hører på hous musikk. men medt de to første.
    på forhånd takk;)
    alfd
    Heisan
    Jeg har Monitor Audio GS 20, Abrahamsen V1.0 og V2.0, og er veldig godt fornøyd. Men nå har ikke jeg alfor mye erfaring med annet, og spranget fra 80-talls anlegget mitt ble uansett stort:)
    Etter å ha lest flere tester endte jeg opp med å vurdere Abrahamsen og Hegel. Det var den litt varme lyden til Abrahamsen som avgjorde valget for meg. Mark Knopfler låter bra - men jeg er ikke like overbevist om at house vil gjøre det. Jeg hører selv mest på rock (The Black Keys, Bigbang mm.).
    Abrahamsen-produktene selges med ca. 40% avslag på Elkjøp sine nettsider om dagen (ikke Upgrade-versjonen). De har jo 30-dagers returrett dersom du ikke er fornøyd.
    Fugazi
    Da har jeg reservert 1 par GX 200 i white Gloss. HiFihuset har ikke prissatt GX serien enda men Andre mente de vil komme på rundt 25.000,-.
    Levering i April. Gleder meg
    Cash 63
    Oslo/Grebbestad
    Hørte idag igen på PL 300 sammen med Chapter ref 400 og Meridian 808.1. Det spiller så ortoligt godt sammen! fantastisk punch
    og smekk i basen med stål kontroll på konerne, og dypt spiller det med. Og oppøver med banddiskanten låter det veldigt behagligt
    og oppløst.
    Dette blir nog min neste HT, har på kjenn den gjør seg veldigt bra på vinyl også.
    Kirk
    Spilte han noe med Media Core 200 der i dag?
    Hørte på det oppsettet du hørte på i dag for ikke så mange dagene siden, å sitter med samme inntrykk som deg.
    Da fikk vi desverre ikke hørt på MC 200, da de hadde noe prob med nettet da.
    Men fett oppsett, å fy for en kontroll 400S har.
    Cash 63
    Oslo/Grebbestad
    Nej, blev bare spillt cd'er.Begynte med ett spor från Gabarek, og lytte på smekket i skinnene på trommerne og det krevende
    blåset, vilken kontroll!!! ellers er Andre glad i og fleske på med mye bas tunga spår ::) men saken er att det gjør det så jækla
    bra att det bare er en frøyd og høre på, og neste stund høre ett følsomt jazz spor som har en herlig nærhet.
    Bjørn.H
    PL300 er veldig gode høyttalere.
    Vidar P
    Kristiansund
    Enig, noen av de beste jeg har hørt. Krever sitt av eieren, men har et voldsomt potensiale. Gleder meg stort dersom de relanserer Studio-seriens konsept igjen, de har alltid vært mine favoritter blant MA's sortiment.
    Bjørn.H
    Den av Platinum seriens kanskje mest "monitor-aktige" lyd, må vel sies å være PL200.
    niha
    Hei! Jeg har et lite rom på ca. 12 m2 og i sammen med Chapter Precis er dette veldig bra. Jeg kan derfor godt tenke meg at PL300 må være helt magisk, men det krever vel et noe større rom. Heldig er dere som ikke har disse begrensningene på tilpasning i rommet.
    Bjørn.H
    cash 63 skrev:
    Og det vil si?!!!
    Rettelse: PL100..!! -dvs. at de er nøkterne i forhold til bass. De har en tørrhet nedover der som nok har medført den kritikken de fikk fra noen anerkjente magasiner innen Hi-Fi.
    Bjørn.H
    Hadde jeg vært deg ville jeg kikket litt på PL200 i stedet. PL300 kan bli litt voldsomme i bassen i så små rom.
    Kirk
    det samme som vi hørte på når vi var der det da. Husker det navnet du skrev der, så hørte vi noe dire straits, eldre disco mener jeg det var, pluss annet jeg ikke husker. Og noe av det vi hadde med sjøl å.
    Men fy å det trøkker der med det oppsettet ja.
    Fare for at det blir PL300 som blir mine neste høyt ja.
    Rommet der har sikkert mye å sinå, men de høyt pluss chapter effekt, låter meget bra.
    Cash 63
    Oslo/Grebbestad
    Det sies det skall komme en referens mod neste år i forbindelse med nått slags jubileum, så tilsvidere får vi lytte på
    PL serien :)
    niha: ute hos Hifihuset står alle mod, og Andre vil gjerne att man prøver hjemme først :)
    niha
    Hei! Glemte vel å si at jeg har PL100 i dag, så neste hopp blir vel kanskje til PL200, hvis rommet ikke er for lite. Jeg har vært litt forsiktig med gulvstående.
    Kirk
    Er det ikke snakk om en ny toppmodell, med 4x12" i hver da?
    Men prisen vil vel sikkert bli hyggelig å.
    Bare en kompis som mente han hadde hørt noe om det.
    Noen som veit når nye 2/3/5 kanalene til Chapter kommer?
    blindlemon
    Hakadal
    Ulyder, angst og beven!
    Merkelige skurrelyder fra mine elskede GS60 i går kveld. Hva f...!
    Løsning: Frem med unbrakonøkkelen og stramme til skruer. Dette skal nå bli fast rutine her i huset et par ganger i året.
    M1
    Hei, jeg et rom på 12m2 og det går fint å benytte PL 300 til et lite rom. Ht står ca 1m fra bakvegg og 60 cm fra sidevegger, noen bokhyller og et teppe hjelper også til.
    niha
    Hei!
    Ja da forstår jeg at jeg ikke er "låst" til stativhøyttalere i all fremtid. Det kunne jo være spennende å prøve noe større. Men når det er sagt så spiller PL100 fenomenalt bra med Chapter Precis og Meridian G08.2.
    Jeg får vel vente til oppgraderingsspøkelse dukker opp igjen, for det gjør det jo.
    Focalius
    Arendal
    Noen med PL 200 eller med erfaring av disse som har elektronikk anbefalinger til disse ?
    Har kjørt hjemmekino med GS 60 og GS LCR.Blir stereo en stund nå/kanskje for evig for å finasiere PL 200.
    Har Yamaha RX 3067 som pre nå og Parasound NC 2250 som effekt.En glimrende match på GS 60 etter å ha prøvd div forsterkere og integrerte.Mer spent på hva den matchen klarer på PL 200.De kommer i løpet av neste uke.
