Norsk RØR forening
  • kjoenik
    kjoenik skrev:
    Noen som kjenner et 5687 rør som heter "National"?
    Noen som har tips til gode 5687 rør?
    Søkte på nettet. Her er et svar fra Tube Asylum.
    Om National 5687:
    "National is atrocious sounding and unreliable. Try RCA or even JAN"
    Nå må jeg visst skifte alikevel... ::)
    kjoenik
    ELEL6200 skrev:
    Tung Sol er bra, men min klare favoritt er Bendix 6900.
    Lf
    Supert, mage takk Ellef!
    Solemnhour, er det Amperex 5687 på bildet. Er de gode, mulig å få tak i?
    ELEL6200
    Ingen ting å takke for, kjoenik. Her finner du Amperex rørene til salgs:
    http://search.ebay.com/search/searc...&ftrv=1&saprclo=&saprchi=&fsop=1&fsoo=1&fgtp=
    Litt, info stjålet fra audioasylum fra selveste Peter Qvortrup om 5687:
    Posted by Peter Qvortrup (M) on June 14, 2005 at 06:58:44
    In Reply to: 5687 substitute recommendations posted by Srajan Ebaen (R) on June 12, 2005 at 15:21:12:
    Dear Srajan,
    The 5687 was designed in 1948/49 by Tungsol (I have 4 of the original factory test samples with dates!), the very early versions are by far the best sounding but extremely hard to find in good working order, otherwise the equivalents are,
    7044, too bright and forward for my liking, although good in other applications, as driver or second stage line stage in transformer coupled circuits for example.
    E182CC, best versions by Philips in Holland and Telefunken (off course), the Mullard UK was normally the US-made 7119 rebranded. The French RTF is a Philips tooled version, but sounds slightly less pure. The E182CC is my favourite sounding equivalent.
    7119, the Amperex is the same as the E182CC Philips Holland above and sometimes cheaper as a result.
    6900, I know this is a popular tube with many, but I have to say I find it quite poor sounding, heavy and bright at the same time.
    All brands of 5687, my favourites are the Tungsol and Raytheon, but the five star GE and Japanese Toshiba is not bad either, generally the 5687 is slight dark in character, exemplified by the Philips/ECG version which is very common.
    Hope this is of use.
    Lf
    SAL
    Hei! Har 2 stk matchede NOS. 6H30P-DR gått ca. 1200 tim. Kjøpt hos Motron. Org. emb. merket: 35 35/18 18 og 35 36/175 18 Trenger de ikke lenger da jeg bygger om spilleren og vil da bruke EEC99. Høystb.
    kjoenik
    kjoenik skrev:
    Lf
    Da er Tung Sol 5687 fra 1953 på vei fra USA. :)
    Solemnhour
    kjoenik
    Takk,
    Nå er det på vei noen Tesla PCC88 fra Sverige også :D
    Dr.Evil
    Er det snart på tide å utnevne æresmedlemmer kjoenik?? Du ligger godt an :D
    Hilsen
    Dr.Evil
    kjoenik
    Vel, når man først setter i gang... ;)
    soa
    Hilsen
    Dr.Evil
    For ikke å si Æresdoktor ;D ;D
    kjoenik
    Rolig nå folkens! Jeg har da ikke bestilt mer enn en håndfull eller to med rør :)
    Er sikker på at det er flust med mennesker her inne som bestiller like mye, hver dag! ;D
    Men iom at mine nåværende jobber neppe fører meg til noen Nobelpris, burde jeg kanskje krafse til meg de titlene jeg kan.
    "Æresdoktor af HiFi-Sentralen" låter som musikk i mine ører ihvertfall ;D
    Men, man får nok ingen titler for simple off-topic skriblerier som dette. Tilbake til rørene!!
    Noen som har en link til den tråden som garantert er skrevet med 6992 anbefalinger?
    (Kan ikke finne den)
    kjoenik
    Hvor bør jeg prioritere å putte de beste 6922 rørene?
    I pre eller i effekt?
    Dr.Evil
    Hva med disse vakre lys....! Intet mindre enn en AN Ongaku!! Befinner seg i min hjemkommune. :D
    Hilsen
    Dr.Evil
    kjoenik
    Hilsen
    Dr.Evil
    Det høres/ser ut som en bra hjemkommune!!
    Steike, hva brukes av utstyr ellers?
    Høytalere?
    Du har vel ikke mulighet for å lage en liten "hjemme hos"-reportasje? :D
    Dr.Evil
    kjoenik
    Prøv deg fram :)
    /jan
    Jeg har testet en del i det siste. Endte til slutt opp med de 5687 som stod i fra før, og noen russiske 6N1P-EV (6922 ekv.) istedenfor Sovtek 6922. Dette ble bedre!
    Har i dag byttet ut Golden Dragon i pre med NOS Tesla PCC88. Byttet samtidig ut Siemens i cd-spiller med GE 5-star.
    Dette byttet gav en fyldigere lyd. Men det er jo umulig å si om det kommer fra Tesla eller GE.
    Hadde desverre ikke tålmodighet til å bytte i en komponent av gangen... ::)
    Skal sette tilbake Siemens ila. helgen og høre hva som skjer :)
    Er forøvrig fornøyd med både "før" og "etter" lyden...
    Dr.Evil
    Har noen av rør folket prøvd ut diverse 845 rør den senere tid? Noen som vil meddele erfaringer?? :D
    Hilsen
    Dr.Evil
    Audiomix
    Hilsen
    Dr.Evil
    Satte inn 4 x 845 Premium fra Golden Dragon i går. Byttet drivere og inngangsrør med det samme. For tidlig å komme med detaljer, men det virker lovende :)
    Pengvim
    Nå er det 17 rør her hos meg.. ;D
    8 i preampen, og 9 i den integrerte (som forresten er til salgs)..
    Kabeldragern
    Kristiansund
    Hei!
    Melder meg herved inn med ca. 1000 rør på loftet og 10 som er "oppe og går" ;D
    RIAA: ECC83 Telefunken
    Linje: ECC83 Telefunken
    Amp: VT229 (RCA) - VT231 (Sylvania) - 845 (Electron Tube)
    Kabeldragern
    Rune_pedersen
    Har kjøpt meg er Cary SLP 2002 rør pre. Noen her som har forslag til rør til denne da de som står i piper å skriker i ht når jeg slår den på.
    Dunker jeg på den blir det borte men kommer igjen når jeg spiller høyt.
    Mvh Rune
    kjoenik
    Du kan jo prøve med rørdemper. Høres ut som mikrofoni.
    kjoenik
    Synes uansett det høres ut som mikrofoni. Har hatt samme problemet med mine forsterkere, men det forsvant da jeg skiftet rør. Det hjelper ikke å manipulere litt på røret for å få det til å sitte bedre i sokkelen?
    Jeg er ikke noen ekspert på det her, så vi får håpe noen andre har forslag.
    Rune_pedersen
    Skal skru den opp i morgen å se om røra sitter ordentlig i sokkelen.
    Takker får gode råd.
    Thumper
    Langt til skogs i Innlandet(Hedmarken)
    Norsk RØR forening
    Men de fleste andre driver og eksperimenterer med div rør, så har jeg brukt de siste ukene på å eksperimentere med rørforsterkere...
    Har hatt disse på besøk
    Almarro A318B
    AudioNote OTO SE
    Leben CS300
    MAE SET-1
    Audio Innovations S1000 pre, og 2A3 "One of a Kind"
    Mye moro, og go' lyd her!
    kjoenik
    Hadde vært morro om du skrev noen ord om lyden til de forskjellige forsterkerne! :)
    Pengvim
    Man bør vel nesten begynne med å eksprimentere med forsterkere, og så eksprimentere med dyre rør? ;D
    Thumper
    Kan jo det vettu!
    Audio Innovation S1000 og 2A3.
    En snill kombo med en flott mellomtone og luftig diskant. En tørr, men ikke så veldig dyp, bass. En kombo som jeg syntes spillte vakkert på akustisk musikk. Den klarte også å spille annet, men det ble litt lite "trøkk" totalt sett... Spesielt på blues og bluesrock.
    Fortsettelse følger...
    Thumper
    Norsk RØR forening
    Neste amp ut var denne...
    Audi Note OTO SE
    Her var de trøkk og liv så det holdt! En utrolig engasjerende amp. Denne spillte blues og bluesrock med overbevisning! Nå var denne satt opp med ganske så fete rør... Den hadde en dyp og tørr bass. Kanskje litt i overkant på Klipsch Cornwall III, men jeg satt ofte å gliste når denne spillte. Diskanten var bra, og mellomtonen som forventet av et AN produkt... meget bra.
    Forts...
