R
Roysen
Crystal Dreamlink - From Gabi van der Kley, this cable isn't a conventional signal cable but specialized ground connection. The Crystal Bridge "is 450 for one meter RCA or XLR set, the Crystal Bridge Dreamlink 1500. What is it? A revolutionary new patent-pending add-on cable for every audio and video system. What will it do for your sound system?
Lowers noise.
Improves dynamic range for sound and picture.
Improves micro dynamics.
Improves Bass, Midrange and Treble.
Lowers audible and measured distortion.
How to apply it? 1/ First connect the Crystal Bridge instead of the original cable. 2/ Plug the original cables into the Crystal Bridge connectors. The Crystal Bridge cable lowers distortion in an existing audio system without modifying the equipment. It has a built in ultra high speed filter (>20GHz), ensuring perfect phase even at extreme frequencies. The Crystal Dreamlink model contains a HPSR filter made of 99,9999999% silver-gold. The Crystal Bridge model uses a HPSR filter made of 99,9999% silver-gold."
Roysen
Lowers noise.
Roysen
