JanR skrev:
Revolver Phono 2 spec's.
Freq. respons: 20-20000 +/- 0.5db
Audio dist: 0.06% max
Input sens: 3mV/1khz (MM) , 600uV/1khz (MC)
Input imp. MM: 47KOhms @ 200pF
Input imp. MC: 20/100Ohm (switch selectable)
Gain at 1khz: 38db (MM) , 58db (MC)
Max input MM: 28mV
Max output: 1.8V (MM) , 1.7V (MC) /1khz (level adjustable)
THD: <0.005%
Output imp: 200 Ohm
S/N ratio: >82db
Crosstalk: 40db at any freq.
Det som står i manualen.
Som sagt er de identiske å se på.
Åkkesom er det en knall riia til pengene,iaf her hos meg og hos jukes som vi testet den første gangen.
/jan
Er ikke veldig forskjellig fra denne manualen.
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
12 volt DC operation; will work anywhere in the world
Total harmonic distortion: <0.005%
RIAA freq response 20hz-20,000hz +/- 0.5dB
S/N ratio >82dB MM / >75dB MC ; gain MM 38dB / MC 58dB
Input sensitivity; MC 600uV / MM 3.0mV
selectable hi range (100 ohm) / lo range (20 ohm) MC input impedance
CE certified; nice packaging suitable for gifting
gold plated jacks and black anodized metal casing
Ground wire terminal; click HERE to see why you need this feature
power indicator; variable output level control
free RCA cable and miniplug adaptor included
Includes AC adaptor (110/120VAC or 220/240VAC; go HERE for details)
Dimensions 180mm x 73mm x 37mm
One year defective exchange warranty
