BT
- Ble medlem
- 13.10.2005
- Innlegg
- 21.457
- Antall liker
- 6.881
Kineserne vet å smi mens russerene har det varmt.
Jupp. Den siste karoliner ble tydeligvis igjen ved Poltava og er klar for oppdrag.^sånn skal det være; egen og landets motivasjon kan gjøre underverker og personellet finner frem egenskaper de antagelig ikke selv visste da hadde.
Det kommer til å bli mange filmer av dette, samt doktorgradsavhandlinger fra alle holde
Swedish military doctrine of the Carolean era was distinguished by its emphasis on aggressive action and shock tactics, the so-called gå-på (literally "go-on") method. This attitude stood in contrast to other European armies of the period, which were coming to rely increasingly on musketry, delivered in the form of volley fire by line infantry, to win battles.
Det man mangler i antall får man kompensere i aggressivitet. Inte med en utredning från ett genusperspektiv.Gå-på tactics enabled the Caroleans to repeatedly overcome much larger enemy armies, as the psychological impact of their rapid approach and their steely discipline under fire, combined with their fearsome reputation, often served to unsettle the opposing troops even before physical contact was made. Moreover, if some enemy troops lost their nerve and fled then panic could quite easily spread through the rest of the enemy force, so a quick success against even a relatively small enemy unit was often enough to trigger a general rout.[19] The preference for aggressive action also served, perhaps counterintuitively, as a way to reduce losses, as it ensured that battles would be resolved quickly rather than degenerating into bloody attritional struggles, as often happened when two armies using volley tactics clashed. This was especially important for the Swedish army as it lacked the manpower reserves of larger neighbours like Poland-Lithuania and Russia, and thus could not replenish its ranks after heavy defeats.
Ad Hollywood så er vel noe slikt på film allerede.
Du ville vera overraska over kor mykje interessant slike kan avdekkja. Helsing ein som driv med det til dagleg.Inte med en utredning från ett genusperspektiv.
Rekk opp hånda dem som leser dette og si at dem har guts nok til å kravle flere kilometer fremover på magen, i et terreng som er minelagt med 6 miner pr kvadratmeter, i kampen for å frigjøre fedrelandet.
Hvis en skal ta utgangspunkt i ratioen antall norske krigsfilmer og offer, ligger vi an til en ukrainsk bølge. Og de som mente at ukrainerne ikke hadde en sjanse bør pålegges å se hver eneste en.Det kommer til å bli mange filmer av dette, samt doktorgradsavhandlinger fra alle holde
….hadde nå enda denne filmen fått en lykkelig slutt ala hollywood, så kunne vi alle hyle av begeistring. Men det er langt fra gitt.Hvis en skal ta utgangspunkt i ratioen antall norske krigsfilmer og offer, ligger vi an til en ukrainsk bølge. Og de som mente at ukrainerne ikke hadde en sjanse bør pålegges å se hver eneste en.
Fullt forståelig, men dersom du oppfatter at du er i en eksistensiell krig for deg, dine og ditt land er det slett ikke sikkert du tenker så mye på det når situasjonen kaller.Rekk opp hånda dem som leser dette og si at dem har guts nok til å kravle flere kilometer fremover på magen, i et terreng som er minelagt med 6 miner pr kvadratmeter, i kampen for å frigjøre fedrelandet.
Skal være ærlig på at min hånd ikke er i været nå.
Gleder meg til tragedie/komedie musikalenHvis en skal ta utgangspunkt i ratioen antall norske krigsfilmer og offer, ligger vi an til en ukrainsk bølge. Og de som mente at ukrainerne ikke hadde en sjanse bør pålegges å se hver eneste en.
Det er sant at når situasjonen tilsier at du må være tøff og fryktløs, så kan du bli tøff og fryktløs.Fullt forståelig, men dersom du oppfatter at du er i en eksistensiell krig for deg, dine og ditt land er det slett ikke sikkert du tenker så mye på det når situasjonen kaller.
Hørte nettopp at en tysker ved navn Scholz også ønsket å prøvespille for en rolle. Det var egentlig ikke så nøye hvilken rolle, any role will do Omså kun en liten birolleGleder meg til tragedie/komedie musikalen
"Fred i vår tid"
Basert på Chamberlain's etterlatte skrifter
Starring:
Macron og Merkel og Moxnes
Ting endrer seg fortere enn selv eksperter forutser.Expert: Inget större genombrott – ryska försvarslinjerna intakta
Ukraina har brutit igenom de första ryska försvarsställningarna och tagit kontroll över orten Robotyne på sydfronten. Nu väntar en betydligt svårare uppgift: Surovikinlinjerna. – De har tagit sig förbi den inledande buffertzonen men har inte brutit igenom de så kallade Surovikinlinjerna, säger...www.svt.se
Efter SVT Nyheters intervju med Emil Kastehelmi kommer uppgifter om att ukrainska soldater synts till på andra sidan av den första Surovikinlinjen.
En av svært mange, fra dag en.
Som sagt, det begynner å ligne på noe.Ukraine Update: Ukraine breaches Russia's main defensive line while it barrages Russia with drones
Ukraine has delivered two headline stories today, both of major significance. First of all, it appears that Ukraine has already breached Russia’s main “Surovikin lines” near Verbove just a ...www.dailykos.com
Det ser ut til at de første ukrainske styrkene allerede er kommet seg forbi/gjennom surovikinlinja og kan rulle opp fra flanken. Antakelig kun lette infanteristyrker foreløpig, men det borger for raskere progresjon enn mange har antatt. Bra gjennomgang av dronekrigen og evolusjonen vi ser mot lettere og stadig billigere droner. De australske pappdronene er flatpakket og kan lett smugles rundt for angrep på militære mål overalt i Russland, i prinsippet.
Vi får håpe, og bidra der vi kan.….hadde nå enda denne filmen fått en lykkelig slutt ala hollywood, så kunne vi alle hyle av begeistring. Men det er langt fra gitt.
Sjakk, og boksing: Det verste er den endelause pirkinga og prøvinga som tappar energi, og som må ta slutt, men der du garantert tapar om du kastar deg inn i eit angrep for tidleg.Dette ligner på et sjakkparti der det begynner å rakne for den ene parten.
