SLUK-O-RAMA - parental guidance strongly advised
  • Status
    Stengt for ytterligere svar.
    2xJ
    constrainedlayerkinetictransformationheatdissipatingalufoamtaperedhybridcardioidclosedvariableslottuningquadriaxialcarbontaperedlowpassreversedexpansiontitanstaticdynamicoptimizedT700T300SaertexvinylesterPolynGluetecconstrainedlayerkinetictransformationheatdissipatingalufoamtaperedhybridcardioidclosedvariableslottuningquadriaxialcarbontaperedlowpassreversedexpansiontitanstaticdynamicoptimizedT700T300SaertexvinylesterPolynGluetecconstrainedlayerkinetictransformationheatdissipatingalufoamtaperedhybridcardioidclosedvariableslottuningquadriaxialcarbontaperedlowpassreversedexpansiontitanstaticdynamicoptimizedT700T300SaertexvinylesterPolynGluetecconstrainedlayerkinetictransformationheatdissipatingalufoamtaperedhybridcardioidclosedvariableslottuningquadriaxialcarbontaperedlowpassreversedexpansiontitanstaticdynamicoptimizedT700T300SaertexvinylesterPolynGluetecconstrainedlayerkinetictransformationheatdissipatingalufoamtaperedhybridcardioidclosedvariableslottuningquadriaxialcarbontaperedlowpassreversedexpansiontitanstaticdynamicoptimizedT700T300SaertexvinylesterPolynGluetecconstrainedlayerkinetictransformationheatdissipatingalufoamtaperedhybridcardioidclosedvariableslottuningquadriaxialcarbontaperedlowpassreversedexpansiontitanstaticdynamicoptimizedT700T300SaertexvinylesterPolynGluetecconstrainedlayerkinetictransformationheatdissipatingalufoamtaperedhybridcardioidclosedvariableslottuningquadriaxialcarbontaperedlowpassreversedexpansiontitanstaticdynamicoptimizedT700T300SaertexvinylesterPolynGluetecconstrainedlayerkinetictransformationheatdissipatingalufoamtaperedhybridcardioidclosedvariableslottuningquadriaxialcarbontaperedlowpassreversedexpansiontitanstaticdynamicoptimizedT700T300SaertexvinylesterPolynGluetecconstrainedlayerkinetictransformationheatdissipatingalufoamtaperedhybridcardioidclosedvariableslottuningquadriaxialcarbontaperedlowpassreversedexpansiontitanstaticdynamicoptimizedT700T300SaertexvinylesterPolynGluetecconstrainedlayerkinetictransformationheatdissipatingalufoamtaperedhybridcardioidclosedvariableslottuningquadriaxialcarbontaperedlowpassreversedexpansiontitanstaticdynamicoptimizedT700T300SaertexvinylesterPolynGluetecconstrainedlayerkinetictransformationheatdissipatingalufoamtaperedhybridcardioidclosedvariableslottuningquadriaxialcarbontaperedlowpassreversedexpansiontitanstaticdynamicoptimizedT700T300SaertexvinylesterPolynGluetecconstrainedlayerkinetictransformationheatdissipatingalufoamtaperedhybridcardioidclosedvariableslottuningquadriaxialcarbontaperedlowpassreversedexpansiontitanstaticdynamicoptimizedT700T300SaertexvinylesterPolynGluetecconstrainedlayerkinetictransformationheatdissipatingalufoamtaperedhybridcardioidclosedvariableslottuningquadriaxialcarbontaperedlowpassreversedexpansiontitanstaticdynamicoptimizedT700T300SaertexvinylesterPolynGluetec
    Ok, men hva slags skruer har du tenkt til og bruke ? :rolleyes: ;)
    Noen av de løse du har!
    Da er påsken her.... blir litt annerledes i år med alle restriksjoner etc.
    Dinner party er avlyst, alternativet er ikke lystig men mat må en jo ha....
    En tur hjemom er også satt på vent, fattern ble sur men det får gå!
    Ikke mye å finne på, best å bare henge litt rundt, fortrinnsvis i eget selskap!
    Uansett - vi får gjøre det beste utav det! PLAY LOUD!
    Påskehilsen til D. Trump!!
    Reaksjoner: Jon
    SannaX
    Ca. 70 cm. høy, enten 80 eller 90 cm. dyp, avhengig av tuningfrekvens - klarer ikke å bestemme meg..
    constrained layer kinetic transformation heat dissipating alufoam tapered hybrid cardioid closed variable slot tuning quadriaxial carbon tapered lowpass reversed expansion titan staticdynamic optimized T700 T300 Saertex vinylester Polyn Gluetec constrained layer kinetic transformation heat dissipating alufoam tapered hybrid cardioid closed variable slot tuning quadriaxial carbon tapered lowpass reversed expansion titan staticdynamic optimized T700 T300 Saertex vinylester Polyn Gluetec constrained layer kinetic transformation heat dissipating alufoam tapered hybrid cardioid closed variable slot tuning quadriaxial carbon tapered lowpass reversed expansion titan staticdynamic optimized T700 T300 Saertex vinylester Polyn Gluetec constrained layer kinetic transformation heat dissipating alufoam tapered hybrid cardioid closed variable slot tuning quadriaxial carbon tapered lowpass reversed expansion titan staticdynamic optimized T700 T300 Saertex vinylester Polyn Gluetec constrained layer kinetic transformation heat dissipating alufoam tapered hybrid cardioid closed variable slot tuning quadriaxial carbon tapered lowpass reversed expansion titan staticdynamic optimized T700 T300 Saertex vinylester Polyn Gluetec constrained layer kinetic transformation heat dissipating alufoam tapered hybrid cardioid closed variable slot tuning quadriaxial carbon tapered lowpass reversed expansion titan staticdynamic optimized T700 T300 Saertex vinylester Polyn Gluetec constrained layer kinetic transformation heat dissipating alufoam tapered hybrid cardioid closed variable slot tuning quadriaxial carbon tapered lowpass reversed expansion titan staticdynamic optimized T700 T300 Saertex vinylester Polyn Gluetec constrained layer kinetic transformation heat dissipating alufoam tapered hybrid cardioid closed variable slot tuning quadriaxial carbon tapered lowpass reversed expansion titan staticdynamic optimized T700 T300 Saertex vinylester Polyn Gluetec constrained layer kinetic transformation heat dissipating alufoam tapered hybrid cardioid closed variable slot tuning quadriaxial carbon tapered lowpass reversed expansion titan staticdynamic optimized T700 T300 Saertex vinylester Polyn Gluetec constrained layer kinetic transformation heat dissipating alufoam tapered hybrid cardioid closed variable slot tuning quadriaxial carbon tapered lowpass reversed expansion titan staticdynamic optimized T700 T300 Saertex vinylester Polyn Gluetec constrained layer kinetic transformation heat dissipating alufoam tapered hybrid cardioid closed variable slot tuning quadriaxial carbon tapered lowpass reversed expansion titan staticdynamic optimized T700 T300 Saertex vinylester Polyn Gluetec constrained layer kinetic transformation heat​
    Aha, da ble alt mye klarere!
    Ja de skulle jeg tro, du som er gammal hornælj turde være kjent med slike ting! En del av prinsippene/materialene som benyttes i den nye mellombassløsningen.
    vipa
    Høyttalerhviskeren
    Fra Fredrikstad, kommet meg helt til Halden
    Vis vedlegget 578348
    Vis vedlegget 578349
    Vis vedlegget 578350
    Vis vedlegget 578351
    Som Jesus sa da Peter spurte om han hadde noen planer i påska: ingenting er spikra, Kanskje henge litt i Golgata...
    Josef's Trevarefabrikk lå i Golgata 13.:cool:
    Ble senere kjøpt opp av JoHoo
    Påskemoro for den sekulære språkmektige intelligentsiaen her inne
    Når coverlåter blir bedre enn originalen...
    Tidtrøyte for kranglefanter
    Her er fin tidtrøyte for alle kranglefantene her inne! Benytt en slakk påske til sårt tiltrengt etterutdanning og kompetanseoppbygging!!
    TrompeteN
    Her er det som vanlig ikke lett å henge med, med mindre man er «limt fast» til skjermen. :)
    Bare innom en svipp for å ønske Kul Påske tilbake! :) Måtte du stå opp igjen tredje dag i år også....
    RAI UNO?
    Gleder meg til i morgen - direktesendt DDE konsert på NRK!! Fæst me skinnvæst!! Steinbønder som hopper opp og ned i lykkerus, klasker loffene taktfast sammen med Petterøe #3 pakka på vei opp av brystlomma på tømmerhoggerskjorta.... i ekstase over taktfast trekkspillmusikk og det genuine felleskapet med andre herjede karsk-tryner og velgjødde budeier med fake rosakinn :D RAI RAI!!!
    Eneste som kan nå opp til et slikt kulturhøydepunkt må være når den obskure midtnorske æljesporten inntar Granåsen for å frese rundt på noen giftsmurte kunststoffpinner i et vannviddstempo - selv om det faktisk finnes adekvat offentlig transport i området! Tør jeg i tillegg anbefale en veldedighetsmiddag - i beste amerikanske fundraiser stil - i Trondheim Rådhus, til ære for TrondheimSolisten Giske... Så ville den hellige treenighet blitt fullbyrdet!
    Riktig god påske til alle dere i Midtens Rike - blir det litt for kjedelig nå under mørkleggingen så kan dere jo sy munnbind av tennissokkene :D:D
    JENO
    Saksvik - Trøndelag
    Ai, ai ai! Kjenner på den kjipe følelsen av fremmedgjøring. Mitt Trøndelag består foruten karsk av Motorpsycho, Trondheim symfoniorkester, Dahls øl, Uffa, miljøet rundt jazzkonsen, svette øvingslokaler, studioer, et fantastisk kampsportmiljø, teknomiljø på Gløshaugen, Rallycross på Lånkebanen, joviale og kreative folk. Heldig vis er jeg så voksen at jeg kan velge hvilken del av trøndersk kultur jeg beriker meg med og identifiserer meg med. :)
    Her er en passende sang for anledningen:
    [video]https://www.google.com/url?sa=t&source=web&rct=j&url=https://m.youtube.com/watch%3Fv%3DaNevXQp1y9E&ved=2ahUKEwi6pdrX_tnoAhVQposKHYjSDGYQtwIwBHoECAoQA Q&usg=AOvVaw2kGv9PbxDgLC2j8xYwGf6q[/video]
    Namsos Skoilla Vorri Bomba Ætti Prudence.
    Lazarus
    Sømna
    He he he, spot on og fornøyelig skrevet. Som innflytter til Nidaros tar jeg sjansen på å humre i stedet for å sette kaffeheimerten i vrangstrupen ;D
    Når jeg tenker meg om har vel to av de tre kulturhøydepunktene bosatt seg i
    Kapitalen Christiania (Northug som giftpinnerepresentant). DDE sliter vi fortsatt med, men det finnes andre lyspunkter. God påske ja ;)
    JENO, det er "Underground" miljøet du beskriver der, ikke kommers... Noe ganske annet! Det EKTE. ;)
    Lazarus
    Sømna
    He he, du traff Midtens Rikes nerve ser de ut som Sluket. Tennissokkene er btw røyka for lengst, så koronatrusselen løses med søringkarantene :cool:
    JENO
    Saksvik - Trøndelag
    Og apropos Griske... han har jo vært berykta for å være klåfingra i mange år. Han var visst ivrig på "hybelnachspiel" på Samfunnet i sin tid. ?????? Har sikkert besudlet mang en studine sørfra. Har vel fått sitte hjemme og tenkt seg om noen uker han og nå. :D
    kjellben
    Ååå, hvor jeg plages!!! Nå har jeg kokt egga i tyve minutter, og enda er de like harde8)
    gormj
    Jeg ligger som vanlig minst et tema bak. Et innspill til den trønderdiskusjonen fra i går og natt. Hva om vi i Trøndelag innførte både søring- og nording-karantene? Da kunne vi kose oss med kulturen vår og Nobelprisen vår i fred og ro. Burde kanskje få Giske innenfor grensa først. "Trønderpian" takler den slags oppførsel ganske bra. "Ha dæ vækk ditt spøkels" er barnelærdom under den åpne himmelen her midt i landet.
    :):) Ikke ment som noen diskusjon eller forkleinelse... bare en oppsummering av fakta! Glad påsk! ;);)
    Meanwhile, blodårene slagger til og generell apati er i ferd med å få overtaket
    - best å få på noe musikk som røsker i ballerota og får fart på adrenalinet!!!
