SME's venner
  • Lancaster
    Takk for tipset, jeg sjekket gummiforingen i armrøret, og den er både hel og tight, så den skal få være foreløpig uten at jeg klusser noe mer med den. Sender en mail til analogtubeaudio og hører hva de tenker om ny og gjennomgående armkabel, kan hende jeg sender armen til dem hvis det blir aktuelt å bytte ut hele kablingen.
    Balle Clorin
    Frequency Response Test Records | Audio Science Review (ASR) Forum
    From the graphs in all of the above measurement there is evident rather low channel separation below 1 kHz. In this frequency range, provided the cartridge is reasonable quality ( VM Silver should be - although I do not have personal experience with it ), the separation is mostly governed by the tonearm. It is here where very rigid tonearms, like SME V, show beyond any shadow of a doubt their superiority. The very same cart measured with the very same sample of the test record can have up to 15-20 dB better channel separation ( the lower the frequency, the more pronounced the improvement is ) when mounted to SME V instead to an "average" arm. Please do note I am quoting SME V solely because I have been myself astounded by such difference in measurements back in the day I briefly worked at Benz Micro Switzerland - as the same SME V as back in the day is still used for the listening test of each and every cart produced.
    There may be by now arms even better than SME V in this regard - but I no longer have the access to the "plotting/graphs" - and certainly not the Bruel & Kjaer setup still in use at BMS.
    torem
    Det ser ut som SME vil selge tonearmer igjen. :)
    Iverfall Classic serien. Det er da noe.
    Du har antageligvis tatt litt for mange fag på BI, evt. ikke de riktige fagene(!), hvis du klarer å regne deg fram til at en tonearmprodusent tjener penger på å slutte og selge tonearmer! Så her får vi håpe SME kommer til fornuft igjen. De har tross alt en tradisjon å ta hensyn til.
    TomVen
    Jar
    Kan kanskje skyldes dårlige marginer og gamle produksjonsmetoder, og nye eiere som er i ferd med å rasjonalisere produksjonen. De kommer nok tilbake for fullt hvis lønnsomheten blir OK.
    ottone
    Min nye SME 312S, ubrukt bruktkjøp, har et ekstra hodeskall på vei fra SME direkte.
    De er meget proffe og hyggelige med sin kundekontakt, både på epost og telefon.
    De liker faktisk at vi ringer og snakker. Hadde en hyggelig prat med Elaine der idag, for å få bekreftet en bankoverføring.
    Produktene er bra, det vet vi jo, men fint firma også.
    J. Brünnhilde
    Har akkurat byttet ut originalkontakten på en 3009 Series II med en nedoverpekende RCA fra Analogtubeaudio. Enkel jobb, men jeg stusser over at de legger armjord til venstre minus. Er ikke det litt vel Rega? Dog: Enkelt å gjøre annerledes om man ønsker det. Merk at den originale ovale skjermen ikke kan brukes med denne modifikasjonen. Armledningene blir uskjermet i basen.
    J. Brünnhilde
    #645 Skjønner over hodet ikke hvorfor SME skriver om Pivot to Stylus dimension. It makes no sense at all.
    Det eneste de skal kunne skrive er Overhang dimension.
    Pivot to Stylus (og Pivot to Spindle) er med SMEs tonearmshoder fullstendig avhengig av avstanden mellom pickupens monteringshull og nål.
    THD
    Tusen takk for at jeg får lov til å være venn med dere her!
    Det er Thomas Sørlie hos Elektronisk Bureau som har laget plattformen til armen, anbefaler han på det varmeste!
    tjensen
    Da har jeg koblet balansert fra min SME 3009 IIIs (titan) med vdh pickup og videre via Sanders RIAA til Cary forforsterker. Stor forbedring (luft, stemmer, instrumnetnyanser, dybde). Dette har vel med kabling og jording i armen på gjøre, så jeg ville bare rapportere.
    tjensen
    Liten armoppdatering på nattmorgenen.
    En rolig nattevakt kan likevel være produktiv. I min kjedsomhet gikk jeg gjennom lagrede annonser på finn.no, og skulle dere ha sett, der dukket det opp en noe over ett år gammel annonse for blant annet en SME V-klone laget i Malaysia. Jeg vet at han som solgte meg armen har kjøpt den hos personen som la ut annonsen jeg hadde lagret, det har han tidligere bekreftet. Selger, altså han jeg kjøpt armen hos, burde vel strengt tatt opplyst om at det var en klone i sin annonse? Det gjorde han ikke. Nå er jeg over middels irritert og har planer om å sørge for at han får en alt annet enn fredelig jul hvis han ikke order opp. Sure nordlendinger kan være skikkelig slitsomme å ha med å gjøre, og det skal han få kjenne til gangs.
    Men vet vi at den er helt falsk ? Jeg hørte en historie om et parti V-armer som kom fra SME i en eller annen form/tilsand og så endte som solgt via Malaysia, kanskje et parti B-varer ? Men du burde vært informert, uansett.
    J. Brünnhilde
    Salgsbilde av det som var min 3009 Series II Improved.
    Så først etterpå at manualen skulle ha vært plassert lenger mot høyre for en perfekt bue. Lyskassen er en IKEA Bestå. Gennialt, Egon!
    THD
    SME 3012 R til hjemmebruk, spilleren er en: Acoustic Solid Machine Small R, pick up: Shure V15V-MR,
    med Jico VN5MR HG SAS/S stylus og "Little Fwend" armløfter, slik at man sparer nålen litt og slipper å høre for mye på "lock groove" , hørte om en som hadde dratt på ferie og hadde glemt å skru av platespilleren når han dro, med stiften på platen, han kom hjem etter et par måneder og da hadde nålen visstnok kuttet seg igjennom vinylplaten mens spilleren fortsatt stod å snurret rundt.... Huff da....
    Hønndjevelen
    Vis vedlegget 1029705 Vis vedlegget 1029706 Vis vedlegget 1029707 Vis vedlegget 1029708 Vis vedlegget 1029709 Vis vedlegget 1029710
    Er det SME originalt headshell du bruker?
    På min 3009R kjørte jeg først Orto SPU, med andre pu's bytta jeg til et Orsonic, mye bedre
    Jeg bytta også plastlageret i armen til et i bronse, likte det også.
    Reaksjoner: THD
    THD
    Ja, det er et orginalt SME R headshell, R har løfte pinnen montert på yttersiden av headshell, de tidligere typene er dette festet mellom headshell og pickup.
    SME R headshell har også to styrepinner som går inn i armen, de tidligere hadde bare en
    THD
    Bruker for tiden en metall "knife edge bearing", men synes det låter litt for CD-aktig, så har tenkt å prøve en av messing, leste at det skal klinge bedre, er det noen her som har erfaring med dette?
    Hønndjevelen
    Jeg byttet til en bronse/messing knife edge, og syntes det rydda litt i lydbildet.
    PUer jeg brukte var Orto Rohmann og Benz Woody, begge kanskje litt varme/romantiske i klangen
    Reaksjoner: THD
    J. Brünnhilde
    Jeg vet ikke om @soundscape her prøvd andre knivlagre enn standard på sine to R-armer.
    SMEs headshell ser himla bra ut. Der er også velkonstruerte, men langt fra SOTA og ikke egnet til pickuper som avgir mye mekanisk energi (men det kan man ikke beskylde Shure-pickupen din for):
    Reaksjoner: THD
    soundscape
    Nordre Follo
    Har ikke prøvd andre lagere på R armene, men endel forskjellige headshell. Jeg faller som regel tilbake til det originale R shellet igjen da synergien er veldig god mellom AT33PTFG/II - 3012R med originalt hedshell. Foretrakk det på Benz LP også. Men på 3009R armen bruker jeg for tiden Denon DL-103R / The Cap i et Ortofon LH-9000 headshell. Den pickup'en trives med større masse og stivhet.
    Når det gjelder andre lagere ville jeg nok gått for bronse fremfor stål. Jeg har et bronselager liggende , men fant ut at skruehullene var litt små - så jeg gadd ikke teste noe videre på det. Det er delte meninger om hva som funker best , og jeg synes armene er så bra med originale lager at dette har blitt liggende i skuffen.
    THD
    Hei Soundscape, er du villig til å selge det knivlagret?
    Jeg er litt interessert i å sjekke ut forskjellen i lyden mellom disse forskjellige lagrene, det ble stor forskjell når jeg satte på stål lageret, men det ble for mye sibilanse, det høres ut som opptakene på platene trenger De-essing! Vinylen høres ut som om det er CD man spiller og personlig er jeg ikke så glad i den lyden. På bildet ligner det vel mer på messing, enn bronse? Bronse er vel gjerne litt mørkere i fargen? Er faktisk litt nysgjerrig på å sjekke ut forskjellen mellom disse to metallene også, siden det ene er litt mykere enn det andre...
    Forøvrig et helt nydelig oppsett du har!:)(y)
    soundscape
    Nordre Follo
    La meg gruble litt på om jeg selger det. Skal være bronse . En fyr i Tjekkia som laget disse - samme kar jeg kjøpte 10mm spacere til armbasene av.
    Spaceren er laget slik at de kan vendes opp/ned og brukes uten baseplaten på sme armen - slik det er gjort på 3012R pro armene (men man vil beholde glidefunksjonen). Dette har jeg ikke testet ut , og bruker de som vanlig spacer for å heve armen 10mm.(nederste bilde)
    THD
    Helt nydelig!
    Har du fått spesiallaget denne plinten?
    ottone
    Mye fint å se fra DAS Acoustics. Jeg vurderer å spørre om de kan lage et til Technics SP10ii der min SME 312S kan peke rett fram i hvileposisjon, og med plass til arm nr 2 på andre siden.
    soundscape
    Nordre Follo
    @soundscape - den spilleren er en ren studie i fornuft, stil og god smak!
    Takk for det . Når man ser hva disse tingene koster når det settes i produksjon i dag så våger jeg påstå at det er veldig mye spiller for pengene. Den er ikke best på alle parametere , men jeg liker look’en - og den spiller musikk som bare pokker. Vinyl som format har allikevel såpass mange svakheter , at jeg lever godt med å ikke ha verdens beste spiller . Jeg har blitt oppriktig glad i denne , så den følger meg sikkert livet ut.
    Der er vi helt på linje. Lett å svi av en mill. på vinylrigg i dag - uten at det nødvendigvis eliminerer de mange problemer med vinylavspilling.
    Evo III
    Hertugen
    Hjemme
    Setter du den rett frem så får du ikke spilt de siste sangene på plata😁
    Reaksjoner: THD
    J. Brünnhilde
    Forsto at det var i de baner du tenkte. Husker meget godt da jeg fant det upraktiske i å montere en 309 pekende rett fram på Thorensen her. Jøss, trenger jeg å lese instruksjonsboka?
