TANNOY
  • sweare
    Hi Totalsindre
    The main problem you are going to have is not the size of the speaker but the shape of your room. Your room is not going to play flat. Because it it about 2.5m x 2.5 x 2.5 i would expect you will get around -3db hole around 50hz and a +3db around 35hz and 70hz. This means a swing of 6db (3db = 2x volume) Bass booms at any volume and you lack speed and punch. You will be able to reduce the volume around the 70hz using room treatments so that its closer to the same volume as the 50hz but the 35 hz will be almost impossible to cure. To your advantage your room is so small that it will help reduce the bass problem a little. Your best bet is to choose a speaker that starts to role off below 43hz and let the room compensate for the volume, problem solved. Tannoy are a good choice as you can sit close to them and they still disapear plus they all start to role off early. Even their 15" Canterbury start to role off around 40hz (28hz -6db) The DC series are great speakers but perhapse more disco home cinima than hi end hifi. I would also recommend a speaker with forward or down firing bass ports. My advice would be to look at their prestige range. Autograph mini with a sub or Stirling would be a great match
    If you would like to reply "Jeg kan norsk"
    Steve
    grammofon
    Enig i ideen med prestige. Dette er kanskje ikke et populært forslag i denne tråden, men det går også an å tenke Harbeth eller Spendor. ....
    sweare
    Harbeth and Spendor and Tannoy, all great classic british speakers and all very musical and easy to drive. Guess there must be something in the water over there. Tannoy however is the only one of the three that you are able to sit right up close to because of sound coming from one point. The others need a little space for the elements to blend before hitting the ear.
    grammofon
    Du har nok et poeng der, selv om jeg har gode erfaringer med nærfeltslytting også med Spendor.
    sweare
    I have more experience with tannoy and proac than Harbeth or spendor but from what i have heard they all have a magical signiture that very few other makes can match. I would be proud to have any of them in my house and i although everyone will have a favoret im sure the rest will come a close second
    Dokken
    Leknes
    Glenair 15
    Hei folkens.
    Skaffet meg Glenair 15 for en tid tilbake. Tenkte jeg skulle prøve å dele noen inntrykk.
    Har i mange år sverget til Klipsch, men var sugen på å prøve noe nytt. Valget falt på Tannoy. JBL hadde vært et annet alternativ, men nå ble det Tannoy i denne omgang. Litt pga at jeg liker utseende på Glenair svært godt, og litt pga omtaler.
    Av musikk går det i diverse metal, rock, blues og endel pop/listemusikk. Hovedtyngden har alltid vært på metal, men med årene blir det mer og mer Dylan, Stones, Tom Waits ol.
    Å gå fra fra RF83 til Glenair var en stor overgang, mye større enn jeg hadde trodd. Glenair er mye mer tilbakelent og innelukket i lyden. De våkner når jeg spiller høyt, men er ganske kjedelige på lavt volum. Liker lyden på endel album f.eks. Rage Against The Machine som aldri har hørtes bedre ut, mens vokalen har en tendens til å drukne i musikken på andre. Her er Klipsch motsatt, spiller meget bra på lavt volum men er ganske slitsomme på høyt volum. Klipsch er også helt overlegne på film. Både taletydelighet, dypbass og effekter er klart bedre der.
    En kombinasjon av disse høyttalerne hadde vært flott.
    Det jeg er mest overrasket over er at Glenair har så lite dynamikk, trodde det var en av styrkene dens?
    Alt i alt er jeg nok ganske skuffet over hva de presterer, så jeg er litt usikker på veien videre. Det meste jeg har av utstyr og kabler er tilpasset å temme Klipsch, så kanskje vil et kabelbytte rette opp endel av inntrykket. Bruker pr i dag Silspeak høyttalerkabler, og de er neppe de mest oppløste men gir et fint bidrag i bassen. Byttet fra Kimber, mistet nok litt detaljer i toppen på det, men fikk tilsvarende bedre bass.
    Det skal i rettferdighetens navn sies at jeg er svært kresen, og har aldri i hele mitt liv hørt høyttalere som er bra nok til mitt bruk. Som regel er det bassen det skorter på, det gjelder forsåvidt Glenair også. Men det er i toppen Glenair har sine største mangler hos meg.
    Får gi de noen mnd før jeg gir de den endelige dommen. Tar gjerne imot innspill.
    Dokken
    Leknes
    I kveld spillte jeg Pantera sin Vulgar Display of Power, steintøft!! Har aldri hørt denne skiva tyngre, sintere og tøffere enn dette. Høyttalerne favoriserer tydeligvis denne typen musikk. Blir jo ikke helt klok på disse, men metal som Pantera, Megadeth og RATM funker fett. Får heller bruke Head-Fi når jeg skal lytte til mer sivilisert musikk.
    TheFlair
    Det er god-musikk. Hvordan låter det med RF-83 i forhold?
    Dokken
    Leknes
    RF83 er gode på mye, men på metal kan det låte litt hardt i mitt udempede rom. Her funker Glenair godt fordi de er mer laidback i lyden, samtidig som 15" lager et fint fundament i bunn. Men uavhengig av sjanger kan de begge funke best avhengig av innspilling. Som allround-høyttalere, også til film, vinner nok RF83.
    I et godt dempet rom vil nok Klipsch vinne på det meste. Skulle vært artig å teste Cornwall, men da trur jeg madammen tilter.
    Dokken
    Leknes
    Testing av nye kabler på Glenair 15
    Da har det uunngåelige skjedd, har begynt å teste nye kabler. Har koblet fra Silspeak kabler og jumpere, inn med Nordost Blue Heaven kabler og Nordost jumpere.
    Diskant og mellomtone åpnet seg mer opp, stemmer har blitt tydeligere. Spiller klart bedre på musikk som Dylan, Dire Straits ol. Er nok mer presist og "riktigere" lyd nå. Skal ikke begi meg ut på å beskrive holografi, tredimensjonalitet og dybde da det blir mest synsing.
    MEN, på tyngre musikk som Megadeth, Pantera, RATM og Slipknot mistet jeg litt av tyngden og drivet jeg hadde tidligere. Er nok klarere lyd her og, men litt av smekket i bassen er borte.
    Har ikke testet lyden på film ennå, men ut ifra det jeg hører så langt blir det nok bedre. Med klarere dialog.
    Det får jeg teste senere.
    Har og noe Kimber liggende, spørs om ikke jeg må teste det når Nordost har fått noen dager på seg.
    skorob
    Brumunddal
    Overrasket over at Glenair er mer tilbakelent enn RF83. Sistnenvte er den mest tilbakelente høyttaleren jeg har hatt :). Men, det sier jo mest om Glenair da :D.
    Kabeldragern
    Kristiansund
    Tannoy blir ikke ORDENTLIG bra før elementet har alnico-magnet. Det har ingen av Glenair modellene. Er nå min erfaring.....
    Dokken
    Leknes
    Overrasket sjøl jeg, men jeg synes den er veldig mye mer laidback enn RF83. Det jeg legger i laidback vel og merke. Mye mer energi i diskant/øvre mellomtone på RF83. Lyden kommer mer ut i rommet, mens Glenair er mer innelukket med langt mindre dynamikk. Må dra skikkelig på før de "våkner".
    Dokken
    Leknes
    Det er godt mulig, har kun hørt Kensington hos Stereofil. Den ble for puslete for min smak med kun en 10", så jeg avskrev den vel egentlig før jeg hadde hørt 2 sanger. Må ha noe med litt mer trøkk, derfor falt valget på Glenair.
    Dokken
    Leknes
    Da har Nordost kablene fått noen dager i anlegget. Må si jeg er mye mer fornøyd nå, lyden har åpnet seg mye mer enn tidligere. Fått testet litt på film også, svært positivt.
    Lyden er ikke superoppløst, men flyter på en naturlig og uanstrengt måte. Og når jeg skrur opp volumet får jeg mer lyd uten at den blir spiss eller hard. Hører detaljer jeg ikke har hørt før, uten at noe stikker seg ut, det er bra.
    Den foreløpige konklusjonen er at jeg har blitt en Tannoy-venn, og at Glenair blir stående i overskuelig framtid. Så får vi se hva som skjer hvis DC10ti dukker opp på brukten med tida :)
    Dokken
    Leknes
    Romkorreksjon
    Da er jeg tilbake i sweetspot etter 2 uker på jobb. Det lå ei pakke her å ventet på meg da jeg kom hjem, Lyngdorf RP-1. Har nå fått satt opp denne, kjørt målinger og testet litt. Må si det er positivt. Ikke kjempeforskjell, heldigvis. Men lyden har litt mer kropp oppover i øvre bass, samt bedre definisjon av rom. Sitter med en øl mens Pink Floyd står for underholdningen, livet er slett ikke ille.
    Satt på noen av favorittlåtene til madammen mens jeg byttet mellom bypass og romkorreksjon. Hu likte lyden best med romkorreksjon innkoplet samtlige ganger. Synes det er en fin test da hu ikke er forutinntatt på noe vis, hu visste heller ikke om hu hørte med eller uten korreksjon de gangene jeg byttet.
    Begynner å bli riktig bra dette :)
    roeng2
    Møre & Romsdal
    Da melder jeg meg inn i klubben som eier av DC 10T, byttet i fra Elac FS 409. Har hatt lyst på disse siden de kom så når muligheten bøy seg var valget enkelt;D
    Torolan
    Det må du fortelle mer om :)
    Er litt nysgjerrig på Tannoy selv. Fortell om overgangen fra Elac også :)
    MusicBear
    Mellomtonen, i disse Tannoyene med 10" elementer, låter det likt med høyttalere med mindre mellomtoner eller har Tannoy sitt eget lydbilde her?
    Merkelig. Tenker jeg her. Det at jeg aldri har vært innom Stereofil for en lytt til disse... Kan være jeg burde det - fremfor å ta tiden til andre ved det jeg spør om :) På den annen side; noe av det som er fint med dette forumet her. Samtidig som jeg antar dere som er eiere av disse har lyttet til mye før det ble disse litt spesielle høyttalerne.
    Strømling
    Nedre Romerike
    Er jo ikke meg dere spør men har samme høytaler. Den trenger noen mnd på å bli skikkelig innspilt. Har mine i et rom på ca 20 kvm ca 4x5 m, ved vanlig bruk og ikke for bass tunge låter fungerer det strålende. Ved veldig bass tunge låter, setter de hele rommet i bevegelse og det kan bli litt en-tonebass.
    Har også forsøkt de i stuen oppe på ca 50 kvm, dette rommet passer egentlig høyttalerne bedre men der sitter kone og barn det meste av tiden.
    Opplever også at de fungerer best med litt mørke forsterkere da de ellers kan bli litt lyse i toppen.
    Stereofil anbefaler Luxman l590ax til disse høyttaleren men hos meg passer Mcintosch en god del bedre. Tross av høy følsomhet opplever jeg at det kreves en del watt for å sparke skikkelig liv i de.
    Strømling
    Nedre Romerike
    Ja klart den trykker meget bra i bassen, går dypere men ikke like fast som Luxman kanskje. Men det er egentlig toppen og mellomtonen som faktisk passer best med Mcintosh. I mitt rom passer Luxman 590ax som hånd i hanske med Yamaha Soavo p1 ( meget undervurdert høytaler).
    Håkon_Rognlien
    Kobler du da McIntosh'en fra 4 Ohm eller 8 Ohm-utgang? Jeg opplever gjengivelsen som fastere og åpnere om du benytter 4 Ohm. Da skal jeg dog poengtere at dette gjelder Mc8000 på DC10T (og altså ikke Ti).
    Håkon Rognlien
    Stigimon
    Hommersåk
    Håkon Rognlien
    Hm Jeg er litt off topic til Håkons innlegg. Men på min egen Lm 218 har jeg kun testa 8 Ohms tapning til mine DC10T... Bør gjerne testa anna... Noen som har prøvd kanskje? Johoo f.eks... Du har jo hatt 218 på disse...
    Med det samme... Noen som har tanker om høyttalerkabler mellom nevnte komponenter. Bruker Kimber TC8 pr nå og har i tillegg Naim NACA4 i hus.. Kom over ett usannsynlig billig par Nordost Blue Heaven (ikke Leif Series) er det noe vits å vurdere disse i dette oppsettet?
    Stigimon
    Hommersåk
    Glemte en ting. Hva bruker folket til å drive TLC med høyttalerne sine? Noen gode forslag til produkter for vedlikehold av treet?
    Strømling
    Nedre Romerike
    Håkon Rognlien
    Hei. Jeg bruker 8 Ohm-utgang, den er merkbart kraftigere på Ma7000. Men skal ta en ekstra runde med 4 Ohm utgangen for å dobbeltsjekke. Rimelig off topic men kjøpte en strøm måler på clas for å sjekke hvor mange watt forsterkerne trekker fra veggen. Luxman 590ax lå stabilt rundt 217watt men kom opp i 290 når jeg spilte virkelig høyt. MA 7000 dro over 800w:cool: litt rart egentlig da jeg følte at det spilte omtrent like høyt..
    roeng2
    Møre & Romsdal
    Får å få bassen til og sitte på DC10T må man gi de nok plass og få de langt nok ut fra vegg. De er tunet for og stå 1 meter fra frontvegg og minimum 50 cm fra sidevegg. Først når plassering er på plass kan man bedømme om man vil prøve seg med annen forsterker. Minne står i et rom på ca 55kvm og de har ingen problem med og fylle dette med lyd. De er nok blant de høyttalerene jeg har hatt som krever mest av rom og plassering for og spille opptimalt.
    Plinius 9200 har ingen problemer med og få frem en veldefinert bass men denne forsvinner fort om høyttalerene kommer for tett på frontvegg.
    roeng2
    Jack_H
    Kanskje på tide å melde seg inn her. Har hatt Tannoy I mange år nå, men er vel ikke den som er mest aktiv med skriverier her på sentralen. Har hatt Tannoy Dimension TD 10 I mange år. Disse ble byttet ut med et par Tannoy Canterbury SE for et par år siden. Har vært og er fortsatt strålende fornøyd med det vi vel kan kalle Tannoy lyden.;D
    Jack_H
    eddie1
    Banned
    Forsterker til XT 8f. Noen forslag ?
    Bruktpris rundt 10000.- ser Tannoy selv anbefaler transe!
    Lynvingen
    Jeg kom over et par Tannoy 638 i god stand via en kompis.
    Klarte selvsagt ikke å la vær å kjøpe bare for å teste.
    Dette var vel en rimelig høyttaler i sin tid, men fy flate for en lyd i forhold til invisterte kroner.
    De har en helt fabelaktig mellomtone, og da sammenligner jeg med mye dyrere høyttalere.
    Kona ble sånn passelig fornøyd med enda et sett høyttalere i hus, så de kommer nok på brukten snart er jeg redd.
    Hva er en fair salgspris på disse i god stand og bortimot strøken?
    Totalsindre
    Kristiansand
    Hei, jeg er ikke medlem her ennå. Men har alltid fristet med tannoy uten å ha hørt noe fra de før. Hva er å anbefale av det som dukker opp på brukten innimellom? Er vel en grunn til at det er lite brukt å finne av de litt dyrere tannoy høyttalerne?
    pea
    står i et stereo hjemmekino rom på ca 25 m2. og de låter kjempe bra
    Bjørn.H
    Er det noen andre endringer enn finish?
