). There are a number of considerations that you must take into account, so it's not as simple as just mounting drivers on a flat baffle. They are:
1. You change the radiation pattern away from a dipole figure 8 toward a cardoid where the null is in back. How much it changes depends upon the shape and dimensions.
2. With 90 degree wings, 1/4 wave resonances come into play.
3. Cavity resonances (hollow sounding) come into play depending upon placement and damping inside the U.
4. Reflections of the rear wave before it even leaves your baffle. I find that if the rear wave starts to expand naturally, but then hits the wings, this results in reflections that cause a congested boxy sound. If you start the wings right at the driver, then they act as a wave guide and the rear wave expands and exits the rear of the baffle as a more coherent wave. Note this doesn't seem to apply to the bass frequencies.
altså kan det virke som om du kan fjerne u-effekten med å vinkle vingene.GM told me that 1" of splay per 6" of depth should be enough to eliminate 1/4 wave resonance. I just start with the look I want and make it work from there. Slightly different depths on the wings gives you the same effect as off center driver mounting and also helps reduce resonances.
Skarptrommer går over et stort register , men grunntonen og trøkket i brystkassa er i det områdetSkarptrommene er...eh..de er der ja
I morgen burde det være muligheter, ja!
Du må huske på at 45 watt på en driver med følsomhet på 115 er det samme som 4500 watt på en diskant med 95db i følsomhet, som med stor sannsynlighet har brent opp før en passerer 100wattAt det skal være mulig å ha det så mye moro med 45 watt er helt sykt!!
Kobla inn ALE-diskanten....
Det finnes ikke smileys her jeg kan bruke for å beskrive trynet mitt nå!
Kjenner en som også har det hysterisk moro med kun 10W! Har prøvd SIT-1 på SLOB... en enslig liten transistor som grisebanker 10 x 15" er en Gore-Texsprengende gåsehudsopplevelse og anbefales alle kilowattgutter med hageslangekablerAt det skal være mulig å ha det så mye moro med 45 watt er helt sykt!!
Etter referansene hjemme, som ikke er helt på stell nå, synes jeg det var litt lite ved 70-80 hz og kanskje noe mye over der igjen. Men det som slo meg mest er at det ikke skal låte slik med en såpass stor hevning mellom 200-300hz. Blir litt synsing dette, men det for stå tellHehe, artig! Hva tenker du på, mer spesifikt?
