The Horny Kid
  • bjarnetv
    oslo
    jeg planlegger iallefall å bygge noen test u-baffler med 2x seas L26ROY i neste uke for å se om jeg får til dempingen.
    hvis ikke blir det H-baffel istedenfor.
    Hornlyd
    Musikkglad
    Jeg lurer også på dette ifbm mine OB.
    Støttene er 25cm dype og bredden mellom er 45 cm.
    Dette innvirker vel ikke i det hele tatt i denne sammenhengen?
    bjarnetv
    oslo
    ganske sikker på at vingene dine fungerer som en u-baffel HEL.
    noen quotes etter et raskt søk anngående vinger bak OB-ht.
    ). There are a number of considerations that you must take into account, so it's not as simple as just mounting drivers on a flat baffle. They are:
    1. You change the radiation pattern away from a dipole figure 8 toward a cardoid where the null is in back. How much it changes depends upon the shape and dimensions.
    2. With 90 degree wings, 1/4 wave resonances come into play.
    3. Cavity resonances (hollow sounding) come into play depending upon placement and damping inside the U.
    4. Reflections of the rear wave before it even leaves your baffle. I find that if the rear wave starts to expand naturally, but then hits the wings, this results in reflections that cause a congested boxy sound. If you start the wings right at the driver, then they act as a wave guide and the rear wave expands and exits the rear of the baffle as a more coherent wave. Note this doesn't seem to apply to the bass frequencies.
    GM told me that 1" of splay per 6" of depth should be enough to eliminate 1/4 wave resonance. I just start with the look I want and make it work from there. Slightly different depths on the wings gives you the same effect as off center driver mounting and also helps reduce resonances.
    altså kan det virke som om du kan fjerne u-effekten med å vinkle vingene.
    emokid
    Skal ikke si noe skråsikkert om dette emnet, men jeg har kjørt med 300mm dype sidevanger på mine testbafler en stund nå, og dette låter ikke noe mer boxy enn uten... Jeg hadde vært veldig forsiktig med å ha disse noe særlig lenger enn dette, vi er her i grenseland av definisjonen på en ubaffel er (ref første innlegg til bjarnetv).
    Jeg har gjort noen raske forsøk på å finne presist ut av hva gutta med dempet ubaffel snakker om av problematikk, men får det ikke helt til å stemme med hva jeg opplever i praksis med mine 16" og 62cm brede baffel...
    Er det uansett så farlig å få endret fysiske betingelser bak og foran baffelen? Det er jo det man gjør med SLOB's som ble bygget i fjor, og det funker jo ikke akuratt dårlig....
    Hornlyd
    Musikkglad
    Jeg tror nok ikke de variablene har så mye å si med mindre man havner på en ren U-baffel løsning.
    Det som har noe å si er rom og evt stående bølger og bruk av EQ.
    Det er faktisk lett å få god bass med den analoge Rod Elliot EQn. Ikke støyer den heller.
    Også slipper man delay selv om det betyr lite i sub området.
    bjarnetv
    oslo
    i en åpen baffel vil jo bakbølgen påvirke frontbølgen, så om bakbølgen har store peaks vil det resultere i ujevn frekvensrespons.
    med korrekt demping vil responsen være mye lettere å ha med å gjøre.
    man kan jo enkelt og greit bare snu HT rundt 180 grader, måle bassen nærfelt og sammenligne med fronten, så ser man om den oppfører seg som en u-baffel eller ikke ;)
    emokid
    Driver og tegner både egne og andre ting i kveld. Siste ut er overgang fra ALE 4550 til JLMC 350. Lurer litt på materialvalg dog, messing eller syrefast.
    emokid
    Har fått låne måleutstyr nå i helgen og driver og forsker litt. Har i første omgang brukt dette for å stille volum på horna kontra bafflene, men også målt litt på hvordan baflene oppfører seg med\uten topplate, og opp til 1200hz.
    Første måling i lyttepos,tror jeg har brukt ørene greit for å justere hittilll. 1\6 glatting
    bjarnetv
    oslo
    anngående basstårnene så har jeg bygget, målt og dempet en u-baffel i BYOB tråden hvis du ikke har sett det enda.
    dempingen flatet ut kvartbølgeresonansen og fikset en fase-mismatch mellom front og bakbølgen.
    alt i alt en ganske enkel måte å få bedre ytelse fra elementene, så jeg vil anbefale deg å måle bakbølgen også, bare for sikkerhets skyld :)
    8x12_TOM
    Hvilken avstand er det målt på. Ser ihverfall bra ut. Med nesten 10db ekstra mellom 200-300hz sitter skarptrommeslagene som de skal kan jeg tenke meg;)
    Er det mulig for en sniktitt på det i morgen
    emokid
    Skarptrommene er...eh..de er der ja ;)
    I morgen burde det være muligheter, ja!
    Bjarne: Kikket i tråden din, det er veldig interessant det du holder på med der. Skal sjekke dette for å være sikker:)
    emokid
    Målte baflene alene til 1200hz som sagt, og kurven er mer eller mindre identisk med den jeg postet over opp til 1200.....
    8x12_TOM
    Skarptrommer går over et stort register , men grunntonen og trøkket i brystkassa er i det området
    Fint, da tar jeg en lynvisitt i morgen.
    emokid
    Da har jeg hatt fint besøk og fått utbyttet litt betraktninger og inntrykk. Fett om dere som her vil si noe om lyden :)
    8x12_TOM
    Takk for lytten.
    Har bare en ting å si, dette kommer til å bli helt rått. Blir morro når dette blir ferdig. Allerede nå var det flere parametre ved dette jeg likte veldig godt, og som jeg egentlig ikke har hørt noen annen plass tidligere. Gjett om tankene gikk litt i spinn nå, da jeg har planer om noe nytt i bassen her hjemme:)
    ganilsen
    Porsgunn
    Helt klart et frekt system med tilsynelatende mye potensiale. Og dette var kun den spede begynnelse fikk jeg inntrykk av. :D
    Lykke til! ;)
    Geir Arne
    Griffenfeldt
    I en blokk
    Jeg er spent på sluttresultatet Emo. Du får sende ut en invitasjon når det passer.
    emokid
    Her er det som alltid åpent om du vil høre, både underveis og etter ferdigstillelse :)
    emokid
    At det skal være mulig å ha det så mye moro med 45 watt er helt sykt!!
    emokid
    Ikke enda, men vi finner ett tidspunkt :)
    8x12_TOM
    Du må huske på at 45 watt på en driver med følsomhet på 115 er det samme som 4500 watt på en diskant med 95db i følsomhet, som med stor sannsynlighet har brent opp før en passerer 100watt:)
    8x12_TOM
    En meget blid og dansende banan, det passer jo ganske bra;)
    emokid
    Hehe, den smileyen er ganske bra ;)
    Det er sant, men jeg har jo ikke helt den følsomheten i bassen. Har justert litt siden du var her, mye mer punch i bassen med nye plasseringa, 30cm lenger ut på gulvet.
    emokid
    Ble tydelig i går at jeg hadde mucka opp kalibrering av lydkort og mic litt, så det var en del mer ujevnt enn de kurvene vi trodde vi hørte på. Lærepenge:)
    Er betraktelig flatere nå, mindre kansellering ved 150-300 blandt annet. Oppfattes som mer punchy, levende bassgange. Gary Willis-sporet er hysterisk!
    8x12_TOM
    Godt du sier det der, satt en stund og tenkte fælt etter lytten på søndag. Det var en del jeg ikke helt riktig kunne feste til den målingen vi så. Begynte nesten å tro at dette systemet ikke fulgte de fysiske lovers spilleregler.
    emokid
    Hehe, artig! Hva tenker du på, mer spesifikt?
    Kjenner en som også har det hysterisk moro med kun 10W! Har prøvd SIT-1 på SLOB... en enslig liten transistor som grisebanker 10 x 15" er en Gore-Texsprengende gåsehudsopplevelse og anbefales alle kilowattgutter med hageslangekabler :cool:
    emokid
    Ja, den eksersisen var jo bare ekkel!
    8x12_TOM
    Etter referansene hjemme, som ikke er helt på stell nå, synes jeg det var litt lite ved 70-80 hz og kanskje noe mye over der igjen. Men det som slo meg mest er at det ikke skal låte slik med en såpass stor hevning mellom 200-300hz. Blir litt synsing dette, men det for stå tell:p
    emokid
    Nei, men det sammenfaller greit med praktisk høring og kontrollmåling det:)
    Roald
    Det er bare til å åpne dørene det, vanskelig å forholde seg til anbefalinger man ikke har mulighet for å verifisere……..:)
    Hehe... slikt er forbeholdt laugsfolk, Roald!
    Roald
    Så det er slik at horn-folket er så usikker at ting holdes innenfor menigheten, i så tilfelle er slike uttalelser meningsløse
    :p
    Nå må du ikke skjære alle over en kam, Roald - det er stort sett bare jeg som er en kødd, de andre horngutta er generelt ganske greie.
