Elektrostatiske hodetelefoner
  • CDWMcInSpots
    Bergensregionen
    Headamp Blue Hawaii Special Edition
    Spritzer om Headamp Blue Hawaii Special Edition:
    post #51 of 4932 8/16/09 at 7:07pm
    • spritzer
    • 10,120 Posts. Joined 8/2002
    IMO this by far the most advanced headphone amp in terms of design and materials used. It's by no means an easy task to build a Blue Hawaii in the first place due to the voltages at hand and the massive amount of heat the amp gives off. This is a 200W+ space heater and Justin has gone to great lengths to make sure that it will last a long time by providing efficient ways to get rid of the heat. The tall cones are vital part of this since they allow cold air to reach the underside of the chassis to cool the tubes and the surrounding circuitry.
    As for the choice of parts, many of these amps have the best volume attenuator money can buy, a 4-gang Alps RK50. The amp is fully DC coupled so no caps in the signal path to degrade the signal and the PSU caps are made by CDE and Panasonic, both excellent choices. RCA sockets are PCB mount Vampire units and the list goes on and on.
    Pretty parts are just band-aids on a bullet wound if the circuit design isn't up to much. The Blue Hawaii and the Stax SRM-T2 stand IMHO head and shoulders above all else when it comes to circuit design and Justin has gone quite a bit further then Stax ever did with the T2. Such small design details as to make sure there is zero interference on the bias line and that there is no bias charge hiding inside the amp section when disconnected from the PSU shows just how far Justin has gone here.
    For the record I have one of these on order even though I'm more then capable of building one for myself. The reason is simple, I owned one of the old KGBH units that Justin built and it worked flawlessly for years of heavy use and was beautifully made.
    CDWMcInSpots
    Bergensregionen
    Observasjoner etter rørbytte i STAX SRM-007tII
    Observasjoner etter rørbytte i STAX SRM-007tII:
    post #4955 of 4967 4/9/14 at 8:43am
    • rgs9200m
    • 1,736 Posts. Joined 5/2006
    Thanks to the members who with the advice for re-tubing and biasing my 007t/ii amp.
    I managed to do it myself with a new Fluke 117 meter and it all went well (it's just hard to get within one volt, but I did it).
    The RCA 6fq7/6cg7 tubes sound superb with the 009 phones.
    There is a little more robust bass, and, most important, some welcome warmth and sweetness in the upper mids and highs,
    and an overall feeling of smoothness and refinement along with the extraordinary SR009 detail.
    And I can listen significantly louder now before any fatiguing highs appear, as Tyll noted in his findings with this amp.
    And this was just on some redbook CDs I tried, and I just couldn't stop listening.
    These are amazing headphones, and they are fully satisfying with the 007t amp.
    The bass is not thunderous, but the bass transparency and integration is so nice I love the low end just as it is.
    The soundstaging is not hall-like with lots of layering, but the sound is so intimate, again, I love it as I hear it.
    The character of each musical component just sounds so true, like you can feel each note and sound, and it feels really good,
    some unique goodness I don't get with any other phone or with speakers.
    And with the fatigue factor basically gone now, I can listen and take all this in with no fear at just about any volume lever I want.
    Again, thanks for the help.
    Newton
    Wow, etter at nytt familiemedlem har meldt seg har det blitt lite tid til det meste. Var selv i kontakt med "Spritzer" ang min SRM-007tII og hans oppgradering av rør og har for en gangs skyld fått tid til å sette meg ned å nyte amp og headsett. Kom dog til å tenke på denne "upgraden" og lurte på om det er noen på bjerget som har kappet baner og loddet om for å følge vår Islanske venns anbefalinger? Erfaringer og hvilke rør kjøpte du og hvor ? Rock'On
    ardilla
    OSLO
    Grattis med familieforøkelse :)
    Det er visst en skikkelig grisete og omstendelig jobb, den modden til spritzer... Bedre å holde seg til å bytte til rør som passer med ampen sånn den er. RCA clear tops gjør godt med forskjell.
    Newton
    Takker. En herlig liten krabat som tar mye tid :) Syntes ikke moden ser så gæli ut, man bytter i praksis kun til ett rør med annen pin out og må bare sørge for at pinnene får rett spenning/signal ved å patche med noen ledninger. Er det noen som vet hvor man får tak i gode rør som man kan oppgradere med uten å kappe baner?
    Har jo kliss nytt oppsett så det som svir mest er tanken på å kappe baner...
    ptb
    ^ Motron har nok RCA Clear Top inne.
    ardilla
    OSLO
    Justin hos Headamp skrev at han aldri ville gjøre det igjen.. Men det nå har jo han interesse av at folk kjøper hans alternativer (BHSE) - så kanskje ikke helt objektiv.
    Motron eller ebay har RCA cleartops. Motron er tryggest, men ebay finker bra det og.
    Newton
    Noen som har testet dette - altså satt inn RCA Cleartops? Har bygd forsterkere til 1000 men dette med rør har jeg aldri brukt ett min å sette meg inn i..:confused: Er dette nyproduserte rør som øker ytelsen på lik linje med det vår islanske venn skriver om ?
    ardilla
    OSLO
    Det er bare en annen type rør av bedre kvalitet. Litt som å bruke transistorer fra ulike produsenter i en transistoramp.
    Newton
    Joa, skjønner jo det, men i transistor verdnen så er det ikke bare å bytte til noe annet. Forspenning, hfe osv vil kunne endre seg og da må kretsen rundt endres.
    Forstod det slik at de røra som islendingen anbefalte var kraftigere og hadde dermed bedre kontroll-uten at kretsene rundt måtte endres. Så skjønner jeg det rett så er det bare å banke inn clear tops og sjekke-de har samme pin out som org røra og det skal gi mer effekt ved høyere output slik det som den mod'en ga?
    Takker for feedbacken
    ardilla
    OSLO
    Ja, islendingen har referert til en annen type rør, som krever ombygging. Disse gir bedre effekt og angivelig bedre lyd, men ødelegger forsterkeren hvis dem ikke er bygget om (som du jo vet)
    Rca 6FQ7/6CG7 clear tops er ikke disse, men kun rør av samme type (6FQ7/6CG7 ) og med spesifikasjoner som er kompatible eller identiske med eksisterende konstruksjon uten modding. Man bør imidlertid justere bias ved rørbytte. Adjusting bias on Stax tube amplifiers - Head-Fi.org Community
    Newton
    Takker. Jeg tror jeg roer meg ned litt og tenker meg om før jeg orker å kappe banene på ampen. Det er minimalt brukt så langt, er vel knapt innspilt - så det er litt overkill å starte å mod´e noe som for min del funker alright enn så lenge. Har mulighet til å lage printkort så har fundert litt på om det lar seg gjøre å lage en slags løsning hvor man kan swappe pinouten uten å bygge for mye i høyden og på den måten slippe å gjøre noe med boksen - som jeg syntes egentlig er litt fy fy. Kunne kanskje lagd en slags plexi kule topp som kunne stått over hullet evt hvis boksen må mod'es. Skal lese meg litt opp nå som ferien har kommet i gang :)
    ardilla
    OSLO
    Hold oss oppdatert, da! :)
    Newton
    Akk hvor herlig head fi er! Fikk opp mitt oppsett fra gutterommet og plassert det i stua da powerampen til hovedanlegget er til hifidoktoren. Ai ai ai, at man ikke "Staxer" oftere - en blueray konsert kan jo nytes i stua uten å lide igjennom den respatex lysen som er i TV'n - og ikke minst spare fruen og Jr for "trøkket" fra kjellern :) Å hva er det med dagens TV´er - de kan jo ikke måle seg med selv det konfirmant anlegget jeg hadde fra Technics med detil plastic lyd, kviser og tannregulering!! Jaggu har tidene endret seg.
    Nyt musikk i varmen ;-)
    Newton
    Da har jeg innsett at mitt HeadFi oppsett ikke blir brukt nok og har lagt det for salg her på Torget... Stax SRM007tII og SR507 med dertil støvtrekk og stativ - alt som nytt..
    todams
    Lier
    Hei, har en SR-407 hodetelefon hvor den ene pinnen på case holder (dvs holderen for den ene telefonen) er brukket, er det noen som vet hvordan man demonterer den fra headband uten å skade denne? Har fått tak i ny case holder.
    barathsec
    Der hvor gjøken alene galer i full Stereo
    Heisann, noen som erfaring med å bytte ut rørene i Stax sine amper? finnes det feks noen oversikt over div rør og hva de eventuellt gjør med lyden? eller er rørene som disse kommer med mere enn gode?
    Beklager hvis dette er tatt opp i en tråd fra før..! :)
    ardilla
    OSLO
    Har bytta ut rør et par ganger - det gir klart en forbedring og er absolutt verdt det. Men rørene som sitter i er jo greie. Man må justere bias manuelt, det er lit knotete.
    Hvordan man justere bias kan du lese her - funker på 006 og 007-ampene:
    RCA "Cleartops" er de oftest anbefalte rørene for oppgradering - men dert er selvfølgelig mange muligheter.
    barathsec
    Takker for tilbakemeldingen, har ikke fått i hus Stax ampen ennå, så ligger litt i forkant og titter på div rør, har kommet over noen men vil selvsagt lytte på de som sitter i, så får en se hva en finner på sånn etterhvert..! :)
    barathsec
    Har noen hørt på Airbow sine versjoner av Stax hodehøytalere, ser de skal være oppgraderte versjoner av Stax Sr-507 og Sr-407, vet at ordet "oppgradert" er litt ømt, så lurer på om noen vet noe mere om disse..?? :confused: :cool:
    barathsec
    Heisann, ser en test på Hifi+ der de har testet Stax SR-507 II og rørboksen SRM-006 TS "Kimik" ser de har skrevet SR-507 "II" har Stax kommet med en ny versjon av denne, ser de skriver II i hele testen, kikker på Stax sin hjemmeside men der står det ikke noe om en ny versjon, noen som vet? forøvrig fikk de en meget god omtale..! :)
    Stax SR-507 II earspeakers and SRM-006tS 'Kimik' energiser | Hi-Fi+
    Absolutt
    Kristiansand
    Hva menes med dette? Kan ikke Stax spille høyt? :D
    "Stax earspeakers have one design limitation: they do not go loud, and the SR‑507 is a fine example of just how much volume they deliver to your ears. It’s worth putting this into perspective. These are not whisper quiet designs. They go more than loud enough for most listeners, especially those who tend to know their way around audio systems and like their ears undimmed by excessive SPLs. But if you are looking to find a headphone that can play Metallica at volume, you need to be looking at headphones, not earspeakers. The SR‑507 II/SRM-006tS ‘Kimik’ is an elegantly dynamic and informative transducer, but it’s not for headbangers."
    Erlendb
    Sandnes
    De spiller mer enn høyt nok. Spilles det på max så mister man hørselen temmelig raskt. Spiller langt over det som kan regnes som forsvarlig volum.
    Reaksjoner: ptb
    ardilla
    OSLO
    Jeg har ikke hørt alt av Stax - men 009 og 007 spiller høyere uten å vrenge enn jeg noen gang vil ha behov for - ikke at jeg engang har prøvd å få dem til å vrenge. Høreslsskadet omtaler?
    Absolutt
    Kristiansand
    Nei regner med Stax, som alt annet, kan spille så høyt at du kan ta farvel til høreselen.
    Selv hører jeg vel kanskje litt for høyt... Kompenserer for bassen.
    90-98dB peaks målt med iPhone da...
    507 er vel regnet som de med mest bass & varme i stax familien?
    Jeg har litt lyst å prøve disse.
    Erlendb
    Sandnes
    Har ett veldig pent brukt til salgs. Driver har jeg ikke da.
    barathsec
    Det er også nevnt litt under en annen tråd her på forumet, men skriver litt her også, Stax har sluppet nyheten med 2 stk nye Hodehøytalere i Lambda serien det er Sr-L500 og Sr-L700, der sist nevnte skal ha bortimot det samme lyd elementet som sitter i Sr-009, men det skal være forskjell på tykkelsen.
    I tilegg kommer en ny forsterker Srm-353X, det kommer også en kombi med Sr-L500 og Srm-353X som vil hete Srs-5100, virker som at denne høsten/vinteren vil det komme endel spennende produkter innen Headfi..! Det gledes..! ;)
    ketilb
    Sør-Helgeland
    En elektrostatisk hodetelefon i støpeskjeen hos JansZen (høyttalerprodusent) også..
    "We're working on headphones.
    I've done enough so far on this project to know that it will be possible to make electrostatic headphones unlike any others. Aside from having JansZen electrostatic clarity, they won't need a special interface box. They'll plug right into a portable player or phone and go out with you like any other headphones, although of course the best performance will be with a headphone amplifier.
    We'll be using crowdfunding, probably through indiegogo.com, to raise the funds for getting these into production. Please stay tuned.
    If you'd like to be one of the very earliest of adopters, contact me at headphones@janszenloudspeaker.com for details. You'll have to wait the longest for your headphones, but get half off the final price, whereas the discount in the formal crowdfunding campaign will be 30% off."
    Link: JansZen developing electrostatic headphones - crowdfunding info...
