Ukens vintagekjøp?
  • vega jon
    bærum
    [SIZE=+3]AR(Acoustic Research) AR-9 [/SIZE]
    278,000 yen(around the one-set and 1980 time)
    [SIZE=-1]Description [/SIZE]
    [SIZE=-1]
    [SIZE=-1][SIZE=-1][SIZE=-1]The large-sized Tallboy speaker system of the vartical series which also fully consider up the correspondence to high-output power amplifier, and was designed.
    Two 30cm corn type Woofers are adopted as low-pass, and it has composition arranged on both the sides of the enclosure. Furthermore, the wall dip phenomenon generated between a speaker and a back wall is canceled because crossover frequency shall be 200Hz.
    inside low-pass -- a 20cm corn type and a crown -- the unit of a 1.9cm dome shape is carried in the 3.8cm dome shape and the high region in the region.
    The inside low-pass unit is carried in the subenclosure, and has prevented the mutual intervention in a core.
    moreover, a crown -- the "magnetic fruid" of the shape of colloid which is tinged with the magnetism which NASA developed is put in between the voice coil of a region / high region unit, and the yoke. And distorted reduction was aimed at from the central axis as a structure as for which Bure is not, and the input-proof is improved.
    The electronic automatic transmission developed uniquely is adopted as the network part as an object for low-pass.
    This controls the low-pass characteristic automatically electrically like the missions of an automatic car,Without reducing a low-pass output, it operates so that dumping may become the maximum with resonance frequency, and even if it exceeds a bus spectrum about the part beyond resonance frequency, it switches electrically so that the flat characteristic may be secured.
    Moreover, a 17AWG sky core coil, a computer class electrolytic condenser, input-proof [ high ] ceramic resistance, etc. are adopted as the use element.
    The acoustic suspension system of AR tradition is adopted as the enclosure.
    By this system, air can achieve the duty of a spring by carrying out full sealing of the core, compliance can be enlarged, and it is possible to make low-pass resonance frequency lower.
    Moreover, the acoustic blanket which is a special sound-absorbing material was attached to the surroundings of a driver unit, and sound quality degradation by reflective sound is prevented.
    Finishing is walnut oil finishing.
    [/SIZE]
    [/SIZE]
    [/SIZE]
    [/SIZE]
    [SIZE=-1]Rating of a mode[/SIZE][SIZE=-1] [/SIZE]
    [SIZE=-1]System [/SIZE][SIZE=-1]4 ways, 5 speaker acoustic suspension system, and a Tallboy type[/SIZE]
    [SIZE=-1]Use unit [/SIZE][SIZE=-1]For low-pass: 30cm corn type x2
    For inside low-pass: 20cm corn type
    a crown -- : for regions -- a 3.8cm dome shape
    For high regions: 1.9cm dome shape[/SIZE]
    [SIZE=-1]Frequency response [/SIZE][SIZE=-1]18Hz - 30kHz[/SIZE]
    [SIZE=-1]Low-pass play frequency [/SIZE][SIZE=-1]28Hz -3dB[/SIZE]
    [SIZE=-1]System Q [/SIZE][SIZE=-1]0.5[/SIZE]
    [SIZE=-1]Output sound pressure level [/SIZE][SIZE=-1]87dB/W/m[/SIZE]
    [SIZE=-1]Impedance [/SIZE][SIZE=-1]4ohms (a minimum of 3.2ohms)[/SIZE]
    [SIZE=-1]The continuation maximum input [/SIZE][SIZE=-1]175W[/SIZE]
    [SIZE=-1]The maximum input [/SIZE][SIZE=-1]400W[/SIZE]
    [SIZE=-1]Crossover frequency [/SIZE][SIZE=-1]200Hz, 1.2kHz, 7kHz[/SIZE]
    [SIZE=-1]Level control [/SIZE][SIZE=-1]Low-pass: Automatic
    Inside low-pass: Three-step switching
    a crown -- region: -- three-step switching
    High region: Three-step switching[/SIZE]
    [SIZE=-1]Content volume [/SIZE][SIZE=-1]120L[/SIZE]
    [SIZE=-1]Dimensions [/SIZE][SIZE=-1]Width 381x height 1340x depth of 402mm[/SIZE]
    [SIZE=-1]Weight [/SIZE][SIZE=-1]59kg[/SIZE]
    pekaill
    Averøy
    Det var litt av noen høyttalere! Skriv gjerne noen ord om de:confused:
    Johan59
    Dagens köp, Sony STR 3800L.
    Smutsig, men spelar.
    Jeg husker ikke denne som så veldig god lydmessig, men det er lenge siden jeg hørte den (1977 eller noe sånt. Du må gjerne korrigere meg når det gjelder lydkvaliteten. Men de har vist seg som svært solide og godt bygget ila. årene som har gått.
    Bidevind
    Bohuslän, Sverige
    Hei !
    Har "kommet over" 2 gamle rør monotrinn fra Cary Audio som er merket CAD-80M og Signature Edition.
    Ser at Cary Audio fortsatt eksisterer og modellen CAD-805AE ser ut til å være en moderne variant av de jeg har.
    Noen som kjenner til disse gamle forsterkerne: All informasjon kan være av interesse.
    vega jon
    bærum
    det er vist ar 90 jeg har. men de er nesten like bort sett fra at de har 10 woofere i bunn i stedet for 12 og noe mindre kasse volum.
    de er vist et eiers par fra en pilot på Holmenkollen som hadde bytta de inn hos hifihuset på Nesbru.
    så på de når jeg kjøpte mine sony ss-2070 der og fikk de ikke ut av hodet.
    wooferne i bunn trenger ny skum ring men ellers er de hele og pene.
    men jeg lurer på om jeg skal bytte ut de i bunn med noe annet. må skaffe no verktøy til testing først. har noen 10 tommere liggende som jeg tror gjør susen
    noen som har hvert borti dayton audio wt3 woofer tester?
    vega jon
    bærum
    jeg tror det er bose drivere i som har blitt brukt i ar 9
    etter det jeg har funnet ut
    vega jon
    bærum
    jo det er lett og få tak i rep sett men jeg tenkter på kvaliteten på driverne.her er et par bilder av filterne
    Kabeldragern
    Kristiansund
    Kom over dette for noen uker siden. Yamaha M-45/C-45. Justerte bias og sjekket litt på effektforsterkeren. Den er ok. Preampen har "uttørkede kondiser-syndrom" og det knepper når tonekontroller av/på trykkes inn. Grei lyd på hytta! Bildet lånt fra nettet.
    vega jon
    bærum
    har ikke fått spilt noe særlig på de enda da det datt in noen ar90 som har blitt stående og disse spiller bra! sannsynligvis den beste vintage høyttaler jeg har hatt.
    måtte sette ss2070 inn på kottet og legge de ut for salg:\ har for mye dill dall som tar plass
    av vintage har jeg hatt\har b&w dm6,b&w dm14,b&w dm 220,the advent 3,rogers ls3\5a,castle durham,t+a tmr70,jvc.sk44
    + sikkert noe jeg har glemt
    vega jon
    bærum
    som dac har jeg brukt en sony mds 920qs da jeg synes den låter bra.
    prøver og holde meg til en god digital kilde hvertfall men kjøpte meg en teac d-t1 i dag som jeg venter på da jeg savner
    en d500 jeg hadde. jeg spiller mest av fra pc btw. optisk fra pc til dac
    Bidevind
    Bohuslän, Sverige
    Er dette helt ukjente greier ?
    Hei !
    vega jon
    bærum
    tydeligvis ingen her som har hvert borti cary.
    hvordan spiller de?
    krisring
    Tønsberg
    hvordan spiller de?
    Cary er vel ikke akkurat ukjent (ei heller her inne). Skal ikke påberope meg noe erfaring med merket, men jeg tipper at grunnen til slunken respons er at denne modellen nok ikke er av det mest kjente de har produsert. Sannsynligvis ikke mange her som har erfaring med disse.
    habicht
    Som gammel Cary eier og fan har jeg prøvd å finne info om disse men uten større hell.
    De som blir trukket frem som evt. etterkommer AE805 er de store singel ended blokkene fra Cary.
    De bruker 300b som driver og 1 stk 211/845 som utgangsrør.
    Har en følelse at disse er en annen type konstruksjon.
    Info om bestykning og fler bilder hadde hjulpet
    Habicht
    Bidevind
    Bohuslän, Sverige
    hvordan spiller de?
    Av søk på nettet kan det se ut som om disse (CAD-80M) ble produsert en kort periode på midten av 90-tallet. Er på 80 watt. Rørene er byttet senere og det er ikke spilt så mye på de.
    De er veldig åpne, detaljerte og luftig og spiller engasjerende. Behagelig diskant og går dypt i bassen men er kanskje ikke så godt definert i bassen som jeg er vant med.
    Vessel56
    Modifisert topplate til 3012 (faktisk sjelden sak uten A dette :) ), fornuftig, Lack bord med hjul, fornuftig, SEAS kit, fornuftig, kassettspiller (kjenner den ikke igjen), fornuftig - bra vintageoppsett.
    Bruker LACK selv
    vega jon
    bærum
    i dag ble det et par jbl lx300mk2. for en liten krafttass! de spiller bra:)
    Kjell_Kranzberg
    I går kväll körde jag bil i tre timmar... Jag kom hem kl 23:30.
    Och när jag kom hem hade jag med mig ett par "Technics SB 440" från 1976.
    Jag betalade 1000 kr.
    I eftermiddag ska jag koppla in dem till min Pioneer A 9.
    jrise
    I dag ble det en ganske strøken (om enn litt støvete) B&O 6002 platespiller til 500.-
    Da fikk jeg også med ett par strøkne CX50 på handelen (de som står bak der, oppå C75'ene jeg bruker til TV-lyd). :)
    CX50'ene skal bygges om til å bli aktive og brukes til en annen TV.
    Reaksjoner: mwt
    TT.
    The smooth jazz guy! 😉🇳🇴
    Nedre Tonsåsen
    Kjell_Kranzberg
    hvordan spiller de?[/QUOTE]
    klart och detaljerat i diskant och mellomtone
    stabil bas
    pekaill
    Averøy
    Har vært på jakt en stund nå, og i dag fant jeg den endelig. Jeg har kjøpt denne...
    pickupen.... "original Shure SC35C System + Nadel / cartridge + stylus (Made in U.S.A.)
    aus dem Jahr 1980 mit dem Original-Schraubensatz in der Original-Schatulle"
    Jeg har en slik pickup SC35C som er laget i Mexico med Jico og original nål med hvit skrift. Jeg har montert den på en standard Thorens TP16 tonearm, og jeg synes den er strålende! USA-versjonen av denne pickupen skal være bedre.
    Denne pickupen ble i sin tid brukt av BBC. Klippet fra vinylengine: "Back in the early eighties we AB tested this against other professional cartridges including the Denon 103 coil and the Shure wiped the floor with all of them! We had a Kisiki Blue moving coil as a reference and there was no audible difference between this and the SC35C"
    Spennende for småpenger!
    jorwed_
    Audio Arkeologen
    Nordre Follo
    Country:
    Japan
    Sony Tokyo
    Year: 1978–1981Type: Broadcast Receiver - or past WW2 Tuner
    Semiconductors (the count is only for transistors)57:
    Reception principleSuper-Heterodyne (Super in general)
    Wave bandsBroadcast (BC) and FM or UHF.
    DetailsHi-Fi equipment
    Power type and voltageAlternating Current supply (AC) / 110; 120; 220; 240 Volt
    Loudspeaker- This model requires external speaker(s).
    Power out180 W (260 W max.)
    from Radiomuseum.orgModel: FM Stereo/FM-AM Receiver STR-V5 - Sony; Tokyo
    MaterialMetal case
    ShapeBook-shelf unit.
    Dimensions (WHD)525 x 195 x 450 mm / 20.7 x 7.7 x 17.7 inch
    NotesSony FM Stereo/FM-AM Receiver Modell STR-V5
    AM/FM-Stereo-Receiver mit 2× 90 Watt (Sinus) an 8 Ohm
    Frequenzgang 5–50000 Hz.
    Phono IN, Tape1 IN, Tape2 IN, AUX IN
    Bass- & Treble Control
    Tape-Copy Schaltung, Monitor-Schaltung
    Ausführung: Front Silber-Metallic.
    IC's: 6
    Net weight (2.2 lb = 1 kg)18.7 kg / 41 lb 3 oz (41.189 lb)
    Source of data-- Original prospect or advert
    Mentioned inSony Katalog - IFA 1979 - Seite 41
    Fenalaar
    Dette er gode forsterkere, men ift høyttalerne dine som er 4 ohm, så kan du vinne en del på å få koblet høyttalerne til 4-ohms-uttaket. Det er enten tre høyttalertilkoblinger, eller så må du lodde om. Det er isåfall en ledning som ikke er loddet på inni, og enden er isolert. Du lodder av en av ledningene på høyttaleruttaket (det røde, mener jeg å huske), isolerer denne godt, og så avisolerer du enden på den løse ledninga og lodder den på høyttaleruttaket. Det skulle hjelpe litt på den litt sleivete bassen.
    NOS 50-talls småsignalrør hjelper MYE på lyden på disse blokkene...
    For the record - Jeg har en Cary SLA70 Signature som er omtrent samme årgang som disse. Jeg kjøpte den brukt og har hatt den i 15 år, og er nå på tredje preampen. Først en Dynamic Precision CA1, så en Cary SLP-50B av samme årgang som forsterkeren, og nå en Cary SLP-03.
    Forøvrig - Cary og Tannoy er super-match...
    Johan-Kr
