Jihad er hva som helst, akkurat som kriger buddister eller vil ikke skade en flue buddister.
Jihad er en muslimsk vei til å krige mot ondskap. Og for troen. Media og Trump bommer helt når de der på all jihad som ondt.
Det finnes jihad mot sult og fattigdom og krig også finnes det fåtall som mener at USA og vesten er onde fordi de hadde
baser på hellig land..
Feil!
https://www.thereligionofpeace.com/pages/myths/jihad.aspx
"Jihad Means 'Inner Struggle'
The Myth:
Jihad simply means 'struggle' and really just refers to a peaceful striving against sin rather than a holy war to spread Islam.
The Truth:
In Arabic "jihad" means struggle. In Islam it means holy war.
The Quran specifically exempts the disabled and elderly from Jihad (4:95), which would make no sense if the word is being used
merely within the context of spiritual struggle. It is also unclear why Muhammad and his Quran would use graphic language, such
as smiting fingers and heads from the hands and necks of unbelievers if he were speaking merely of character development. With
this in mind, Muslim apologists generally admit that there are two meanings to the word, but insist that “inner struggle” is the
“greater Jihad,” whereas “holy war” is the “lesser.” In fact, this misconception is based only on an a single hadith that Islamic
scholars generally agree was fabricated.
By contrast, the most reliable of all Hadith collections is that of Sahih Bukhari. Jihad is mentioned over 200 times in reference
to the words of Muhammad. Each carries a clear connotation to holy war, with only a handful of possible exceptions (dealing
with a woman's supporting role during a time of holy war).
Gunnar Brekke
Lad dog være med konstant at referer/linke til disse hadesider ,det er ikke seriøst at bruge disse Islamofober som reference-kilde , de har et fuldstændigt unuanceret syn på Islam og Muslimer som skal passe med deres agenda. På det punkt ligner de IS og andre terrororganisationer , de er fuldstændig lige så fundamentalistiske.
Hvis det virkelig var som disse hadesider siger, så var vi stort set alle døde (jeg var helt sikkert , da jeg bor et sted med 80% muslimer ,men jeg sover alligevel roligt om natten og lever stadigvæk).
Terror ville have et helt andet omfang end det faktisk har hvis disse hadesider havde ret, som sagt har jeg tidligere i tråden dokumenteret at terror var meget mere udbredt i 70'erne og 80'erne og der var mange flere ofre , og det var for hovedparten ikke! Muslimske terrorister som stod for denne terror.
Det er rigtig som Danke siger jihad betyder mange ting, ordet betyder at stræbe, og deles tit op i den store Jihad som er at forbedre sig som menneske og Muslim ,det er den vigtige og oprindelige Jihad, det åndelige aspekt.
Den lille Jihad kan eventuelt involverer hellig krig, men også her er der mange nuancer , man kan læse lidt her fra det Danske efterretningsvæsen
https://www.pet.dk/CTA/~/media/CTA/Jihad_og_terror.ashx
Det Danske efterretningsvæsen (PET) Som jeg tror mere på end de hadesider som der konstant linkes til i denne tråd. , de har kun en agenda som alt skal passe til det.
Også denne artikel giver god nuanceret info
https://www.information.dk/2004/09/lille-jihad
Ps. Jeg fornægte bestemt ikke der er problem ,men det er et problem som ikke har noget med Islam at gøre , og skulle det have så er det en meget lille del af "såkaldte Muslimerne" det drejer sig om.
Men der skal desværre kun en til at lave et terrorangreb, derfor er det så satans effektivt til at skabe frygt/panik osv., derudover skille terroren indirekte den etniske befolkninger (som det ses her i tråden), og den skiller Muslimerne fra resten af befolkningen, som ses i samfundet generelt og i presse radio og tv.
Og det er bl.a. lige det IS vil opnår, at lokale Muslimer bliver hadet/udstødt det giver et endnu bedre rekrutterings grundlag for dem.
