Roons venner.
  • Minutten
    Roon sletter spilte låter fra køen og jeg har ikke funnet noen måte å skru av dette på. En workaround er er å velge repeat og så velge "play from here" om du vil spille en låt fra en kø.
    Reaksjoner: Toc
    Minutten
    Jeg tester ut Roon med å kjøre Server (Roon) på min mac mini 16GB/i5/SSD og musikk på NAS, ideelt så burde jeg hatt egen hardware og under er anbefalingene fra Roon på hardware.
    brian
    Brian LuczkiewiczRoon Labs: CTO
    Apr '15
    It feels like the answer to most "will it work?" questions is going to be "It'll work, but it won't be as good as it could be", because lets be honest, no-one is going to wonder whether a Mac Pro works flawlessly or not.
    I want to expand a little bit more to help you guys understand where the tradeoffs are so you can make good hardware decisions. As we've said above, Roon will run on just about anything vaguely recent. How much hardware you need to get an impeccable experience depends on how you're going to be using it.
    Most of the time, the software we run isn't very performance intensive. Web browsers, productivity software, operating systems, communication software, and so forth. No big deal on today's hardware.
    Likewise, there are a few categories where performance really does matter all the time. One is gaming. Another is professional software, like that used for graphic design, video production, and CAD.
    Roon has one foot in each camp.
    The user interface is driven by a piece of technology that could be best described as a game engine. It supports fluid animations, and we are trying to keep the frame rate at 60 frames per second (fps), just like a game. It renders graphics using OpenGL and hardware acceleration, just like a game, too.
    Under the hood, Roon is a professional grade database that manages hundreds of thousands to millions of metadata entities in order to represent a typical music collection. This degree of data management and indexing is almost unprecedented in typical desktop applications. And as a goal, we are trying to fetch and display whatever piece of data you ask for, no matter how complex the requirements, onto your screen in 50ms or less.
    At the same time, we're trying to push high-resolution audio out to your DAC in real time. If you can believe it, this is the "easy" part.
    What does a perfect experience look like?
    • The application loads in a few seconds
    • Screens displaying local content populate instantaneously, regardless of complexity.
    • Audio plays without glitches or dropouts
    • Animations and graphics are completely fluid
    • All of this remains true even when Roon is doing work in the background, like importing new content, loading metadata/artwork, analyzing audio content, etc.
    Perfection is something we aspire to and performance is an area where we work really, really hard. But, as much work as we put into making this stuff perform, if the hardware isn't up to the task, there's no getting around it. In 2007 we took control of the user experience by dictating exactly what the hardware would be. Now, we're trusting our users to make good choices instead.
    If you're thinking about buying new PC or Mac hardware, consider the following:
    • Is the hardware going to be shared with other resource-intensive applications?
    • How much music do you have? Managing 20,000 albums is way more demanding than managing 2,000.
    • Are you going to be browsing from this device, or using it headless?
    • How long do you intend to keep using this hardware before upgrading?
    With a small 1500 album library and a headless use case on a dedicated device, a very modest piece of hardware will run Roon really well.
    If you're in the middle, say 3,000-5,000 albums, something similarly midrange--on par with the current (Apr 2015) mid-range Mac-Mini (Core i5, 2.x Ghz, SSD) will give a great experience.
    If you've got a 4k monitor and 20,000 albums, look for a big scary Core i7 with plenty of ram, an SSD, and discrete graphics.
    Most people will fall somewhere between those extremes. Not everyone cares as much as we do about "perfect" performance either. That makes it really hard to talk about what "suggested hardware" should be to everyone at once, but it should give you some idea of what we consider "extreme" and where you fall.
    Some more specific points:
    Flash/SSD storage is a big win. The metadata and artwork databases I was talking about are sitting in your home directory on your boot drive. If you have a small amount of music (lets say, less than about 1500 albums), it barely matters, but as your collection creeps up towards 5,000 or 10,000 albums or more, storage performance begins to matter a lot.
    As a very rough estimate, plan to set aside about 2gb of disk space on your boot drive per 1000 albums. Expect the app to use somewhat less at first, growing over time as we expand music metadata capabilities and improve artwork quality.
    RAM isn't a huge deal. 8gb is basically par for the course on a new PC sold today: <$400 laptops have that much. That should be fine for just about anyone.
    Graphics performance is very important to Roon unless you're in a headless configuration. We run very well on Intel's integrated graphics chips starting with the Ivy Bridge architecture, which goes back to mid 2012. It will run OK on the couple of generations before that, too, with minor compromises. Generally, anything with a discrete graphics card is going to be even better. We require OpenGL 3.0 as a bare minimum, so anything too old to support that is a no-go.
    CPU cache is also really important to an app like Roon. Some CPU series (Celeron, Atom) are severely cache constrained. Once you get into Core i5 territory, there's enough cache to go around, and as usual, a top-end CPU will confer an incremental performance benefit above that.
    Another thing to keep in mind: Roon is not static. It will receive software updates over time, and as always, we're going to continue pushing the functionality forward as hardware improves. Buying something that's just barely sufficient today is a recipe for a sub-par experience in a year. Likewise, the hardware we'll be recommending six months from now (April 10, 2015) will be six months better than what we're recommending today.
    Also, in case you didn't notice, I didn't say anything about audio. That's because audio is the "easy" part. Anything that meets the rest of the application's other needs is going to play music just fine.
    I hope this helps.
    Minutten
    Kan berolige alle som vurderer å kjøpe en minipc som Rasberry pi el. og er redd for at det er vanskelig å sette opp Roon bridge. Er ikke noe raser på Linux selv, men det er bare copy paste av 3 kommandoer fra terminalen på en mac (eller fra f.eks putty på en windows pc). Har testet dette selv nå på 2 pcer og det tar maks et par minutter fra du har logget på RPI til den er klar til å kjøre Roon.
    Minutten
    Har laget en guide for å sette opp et rimelig Roon end point her: http://www.hifisentralen.no/forumet...berry-pi-som-musikk-streamer.html#post2276646 Den vil da dukke opp som Airplay device men med Roon bridge så blir den fullt Roon ut Roon ready.
    For windows bruk et program som Putty http://www.putty.org/ el og for Mac åpne ternminalen.
    Basert på spilleren i guiden over så skiver du inn: (ikke skriv enter, men trykk enter etter kommandoen)
    ssh -l root 10.X.X.X (enter) (erstatt 10.X.X.X med ip adressen til spilleren din)
    passord er moode
    Skriv (copy paste) så inn disse komandoen etter at du har logget inn ( jeg tar med sudo så de kan brukes på andre brukere en root).
    curl -O http://download.roonlabs.com/builds/roonbridge-installer-linuxarmv7hf.sh (enter)
    chmod +x roonbridge-installer-linuxarmv7hf.sh (enter)
    sudo ./roonbridge-installer-linuxarmv7hf.sh (enter)
    Ser typisk slik ut i terminalen
    Svar "yes" når den spør om du vil installere.
    Du skal få meldingen under når den er ferdig.
    Så et lite triks: Gå inn i menyen og sett I2S device til Hifiberry (kan settes tilbake etter at Roon har funnet den).
    reboot
    Du vil nå finne den under nettverk i Roon. (gul er Airplay fra guiden over)
    Vet du ikke ip adressen til spilleren så last ned https://itunes.apple.com/us/app/fing-network-scanner/id430921107?mt=8
    Du finner den ved Moode
    Minutten
    Når jeg søker på artist så kommer ikke album (som ikke er laget) fra Tidal med lenger, kan spille Tidal album fra biblioteket. Andre som har dette problemet?
    EDIT:Fixed.
    Minutten
    Problemer med Tidal i dag også. Etter en restart så virker alt men dette er for dårlig og vi får håpe på en fiks slik at det blir mer stabilt. (Kjører på mac mini i5/16GB/SSD)
    Edit: Litt kjapp ut med at alt virker, søk virker OK men ikke mulig å legge Tidal album til bibliotek.
    gwikse
    Vi får håpe de støtter mer enn Sonos Connect som end points, ellers er det ikke mye vits imo.
    Minutten
    Ingen grunn til å tro at de ikke skulle støtte Play x også ?
    gwikse
    Nei vi får vel tro at det er sonos + roon = sant
    Jeg går ut ifra at det er vanlig å ha sonos rundt om i huset i tillegg til ett hovedannlegg med sonos connect. Jeg vil jo helst slippe sonos appen og kun forholde meg til roon appen rund baut.
    Minutten
    Sonos har jo nå åpnet for 3. part apper, så jeg regner med at det er flere som kommer til å støtte Sonos fremover. Personlig så har jeg nesten ikke brukt Roon etter den første måneden, blir kanskje litt mer bruk med Sonos støtten.
    Olav2
    Til dere som er vant til grensesnittet til både Roon og sonos: hva er den største forskjellen?
    gwikse
    Personlig synes jeg roon er mer logisk.
    Info om musikken er også langt mer tilgjengelig.
    Blir litt som å ha cd`er fra en artist i 2-3 forskjellige skap med sonos.
    Med roon har jeg også mer av gofølelsen mtp album inlay, kritikk av musikken, info om hvilke artister som har hatt innflytelse / ligner på den jeg hører på og direktelinker til deres utgivelser, etc.
    Minutten
    Roon er veldig bra på å organisere lokal lagret musikk, om man kun streamer fra Tidal så er det ikke så mye å hente, Spotify er ikke tilgjengelig.
    Minutten
    Må nesten vurdere å fortsette et år til nå. Støtte for Sonos og støtte for Transporterens display passet meg veldig bra. Kan nå enkelt spille filer som er over 48/16 på Sonos (kun ned samplet, men Sonos sw støttet ikke dette).
    Lånt bilde
    Minutten
    Kun spilt noen timer, men det ser ut til å funger fint med Devialet Air og Roon.
    Minutten
    Se ut til at prisen er $1200 eller så kan du kjøpe en NUC til $400 og installerer programvaren selv, ref Roon.
    Distinctive
    Når de sier 'Kjører kun Roon' så betyr dette implisitt at vi kan glemme å kjøre en fremtidig Linux basert HQP variant på samme hardware. Det var synd, men som forventet.
    Minutten
    Så litt på HQP men gadd ikke styre med det, og var vel ikke helt rimelig heller. Kan være det er noe å hente på lydkvalitet men forløping kjører jeg standard Roon på macmini og det fungerer ganske så stabilt.
    Distinctive
    Vi får se om det ikke kommer noen ekvivalente FPGA-varianter av HQP snart (innlemmet i streamer). Da blir ikke kravet til ytelse så ekstremt. Utfordringen er filtre.
    Tror Roon NUC i7 varianten med SSD ombord kan være tingen. Prisingen over er basert på i3 CPU.
    Minutten
    Siden jeg bruker Devialet Air nå så er det ikke aktuelt med Roon Rock før det er direkte støtte for Devialet.
    Minutten
    Roon har nå fått direkte støtte for Devialet, og MQA vises nå som 192/24 mot 44.1(48)/24 tidligere. Har ikke fått testet om dette er hørbart enda.
    MortenHM
    Bodø
    Tror ikke det er hørbart ennå, slik jeg har forstått det så handler dette bare om at Roon i denne oppdateringen finner MQA data. Men Roon kan desverre ikke dekode MQA ennå. Men det jobbes med og kommer med en senere oppdatering.
    Sjekk i displayet på Devaliet (hold inne source knappen) hvor mange kHz Devaliet mottar. Får du mer enn 48 kHz? Jeg får ikke mer enn 48kHz hos meg selv om det vises MQA192 som hos deg.
    Vis vedlegget 448933
    Distinctive
    Det er også et poeng at programvare som Roon kan slippe gjennom MQA strømmen transparent til en renderer (DAC end point) som kan dekode MQA. Det er nemlig ikke opplagt at så skjer.
    Minutten
    Noen som har installert Rock?
    mteinum
    Øya
    Er ROCK en Linux OS kjerne med Roon på toppen?
    https://kb.roonlabs.com/Roon_Optimized_Core_Kit
    A)
    Let's first explain what Roon OS is, and then we can talk about Roon Optimized Core Kit.
    Roon OS is a custom Linux based operating system, tailored for running Roon Server and providing a best-in-class, appliance-type user experience to host the Roon Core.
    B)
    ROCK is a do-it-yourself build of Roon OS.
    Comprende?
    Zerostat
    Lillestrøm
    A)
    B)
    Comprende?
    Roon OS? Roon_Optimized_Core_Kit? Jeg forstår ikke ut av dette at Roon allerede er i ROCK. :D Men det spiller vel liten rolle. Kan sikkert installere Roon på toppen av ROCK da... Egentlig prøver jeg å forstå jeg skal med det, bortsett fra at Devialet AIR drivern er innebygget.
    mteinum
    Øya
    Roon OS, ja.
    ROCK is a do-it-yourself build of Roon OS, a custom Linux based operating system for running Roon Server.
    Du har altså to varianter her:
    1. ROCK: sett sammen egen hardware og installer ROCK - som er en linux-variant med Roon Server installert.
    2. Nucleus by Roon Labs - ferdig hardware løsning med Roon OS preinstallert
    https://kb.roonlabs.com/ROCK:_Getting_Started
    jaeger
    Noen som har noe erfaring med import av filter fra Rew i Roon Dsp?
    Er på bleiestadiet når det kommer til romkorreksjon så det låt ikke helt optimalt her. Prøvde å korrigere opp til 200 og 300Hz. Låt tynt i bassen etterpå. Neste forsøk blir med flere målinger for å se om det gjør susen.
    Distinctive
    @mteinum:
    Jeg regner med at ditt pkt. 1 betyr at Roon utleverer en BOM for ditt pkt. 2, altså blir det samme løsning men sammenstillingen av hardware gjøres av sluttbruker og dermed blir det mye billigere.
    Minutten
    A)
    B)
    Comprende?
    Dette er en liten spesialtilpasset linuxversjon m/Roon som kjøres på en Intel NUC med ssd disk, dvs en dedikert PC som bare kjører Roon.
    mteinum
    Øya
    Nå vet ikke jeg prisen på ferdigmaskin fra Roon, men kjøper du minste DIY-anbefaling så kommer du på ca 3400,-
    Maskin: NUC7i3BNH - https://www.komplett.no/product/912...e-m-hovedkort/intel-nuc-nuc7i3bnh-baby-canyon
    Ram: CT4G4SFS8213 - https://www.komplett.no/product/866.../minnebrikker/crucial-ddr4-2133mhz-4gb-sodimm
    HD: - https://www.komplett.no/product/897...iskerssd/ssd-m2/intel-600p-128gb-m2-pcie-ssd#
    Maskin: 2849
    Ram: 459
    HD: 690
    Sum: 3.377,-
    OS - Rock/Roon OS - kan lastes ned gratis - lisens på Roon må derimot kjøpes.
    Minutten
    Ingen erfaring men har du sett denne? Digital Room Correction for Less Than $100
