Den er ikke gammel, så det er nok en re-issue, grei pris ca 3800,- Sek...det har blitt endel Prospex ur på markedet den siste tiden.Er det reissue av Seiko Sammy eller en gammel ?
Liker det enkle funksjonelle no bullshit designet. Ikkno jålete posørklokke dette. En skikkelig beater som tåler en støyt og kler å få en dæng eller to.
Masahiro Kikuno is a master craftsman who belongs to an exclusive international group of independent watchmakers. These consummate artists create timepieces that reflect their deepest ideals, with no connection to commercial watch manufacturers. Kikuno's creations are deeply influenced by traditional Japanese culture. He's fascinated by a masterpiece called the Myriad Year Clock, which was built by a 19th-century Japanese mechanical genius. Containing over a thousand hand-made parts, the clock is a marvel of complex and precise engineering. Kikuno seeks to transcend that old master's achievement by giving the clock a modern rebirth in the form of an elegant wristwatch. This program documents Kikuno's exacting methods of designing and hand-machining all of the delicate parts needed to create a modern masterpiece.
Fantastisk!Masahiro Kikuno is a master craftsman who belongs to an exclusive international group of independent watchmakers. These consummate artists create timepieces that reflect their deepest ideals, with no connection to commercial watch manufacturers. Kikuno's creations are deeply influenced by traditional Japanese culture. He's fascinated by a masterpiece called the Myriad Year Clock, which was built by a 19th-century Japanese mechanical genius. Containing over a thousand hand-made parts, the clock is a marvel of complex and precise engineering. Kikuno seeks to transcend that old master's achievement by giving the clock a modern rebirth in the form of an elegant wristwatch. This program documents Kikuno's exacting methods of designing and hand-machining all of the delicate parts needed to create a modern masterpiece.
Er det en såkalt "Dancing hands"? Sett video på youtube av en slik, ikke helt min stil men fikk lyst å kjøpe den bare fordi den var litt fascinerende å se påI flere år har jeg gått rundt i den tro at jeg mistet min Seiko SM25-6000 under et sjøslag, men under utpakking av ei eske fra sist flytting i dag dukket den pinadø opp til min store glede. Batteriene har forlengst gitt opp, så jeg krysser fingrene for at det ikke har vært noen lekkasje i mellomtiden. Kjøpte den i etterkant av Lillehammer OL, der jeg tror Seiko markedsførte den som såkalt "offisiell chronograph". Håper ikke det betydde at det var ei slik de brukte til å avgjøre vinnere.
Vis vedlegget 484893
Dette er ei relativt sjelden klokke. Den ble rett og slett litt for mekanisk og elektronisk avansert for sin tid og sin pris, som jeg mener var i overkant av 6000 kroner i 1994. Husker at jeg etter noen år måtte begynne å la alarmen stå på for at den skulle fungere helt normalt. Ikke noe stort problem for meg, alarmen er ganske diskret, men ideelt er det jo ikke for de som ikke kan leve med noe som ikke er helt perfekt. Ikke ulikt mange hifi-produkter egentlig.
Det stemmer. Det finnes en video på YouTube av den litt mindre avanserte finklokken, som ikke viser tiendedeler når stoppeklokken brukes. Jeg kjøpte den et år før Lillehammer-OL og onkelbarna mine syntes det var utrolig fascinerende når jeg skrudde på kronen og viserne begynte å snurre i motsatte retninger for å komme til topps når stoppeklokke og nedtelling ble valgt.Er det en såkalt "Dancing hands"? Sett video på youtube av en slik, ikke helt min stil men fikk lyst å kjøpe den bare fordi den var litt fascinerende å se påI flere år har jeg gått rundt i den tro at jeg mistet min Seiko SM25-6000 under et sjøslag, men under utpakking av ei eske fra sist flytting i dag dukket den pinadø opp til min store glede. Batteriene har forlengst gitt opp, så jeg krysser fingrene for at det ikke har vært noen lekkasje i mellomtiden. Kjøpte den i etterkant av Lillehammer OL, der jeg tror Seiko markedsførte den som såkalt "offisiell chronograph". Håper ikke det betydde at det var ei slik de brukte til å avgjøre vinnere.
Dette er ei relativt sjelden klokke. Den ble rett og slett litt for mekanisk og elektronisk avansert for sin tid og sin pris, som jeg mener var i overkant av 6000 kroner i 1994. Husker at jeg etter noen år måtte begynne å la alarmen stå på for at den skulle fungere helt normalt. Ikke noe stort problem for meg, alarmen er ganske diskret, men ideelt er det jo ikke for de som ikke kan leve med noe som ikke er helt perfekt. Ikke ulikt mange hifi-produkter egentlig.![]()
Jeg må komme meg til urmaker så fort som mulig for å få skiftet batteri og få den i bruk. Skal til Haugesund i morgen, håper jeg husker å ta den med. Det er sjelden slike batterier lekker, men jeg opplevde faktisk det med akkurat dette uret på starten av totusentallet. Det gjør at datovisningen står fast på mitt ur, mulig det lar seg fikse hvis jeg koster på meg en skikkelig restaurering av det. Spørsmålet er om en slik restaurering er verdt pengene, for selv om det er et sjeldent ut så tror jeg ikke det har så høy verdi.Stilig! Kunne lekt noen timer med den;D
Har vel gått ut av produksjon nå så det er et godt valg, flott klokke. Har siklet på den selv men dårlig impulskontroll gjorde at jeg endte opp med noe annet.Halvveis napp i dag. Fant en lokal urmaker som hadde en slik i bestilling uten at den var reservert. Håper det ikke faller i fisk. Er ikke så lysten på å handle på Ebay eller Amazon.
Snakker om Seiko SARB017 Alpinist
Vis vedlegget 488937
Blir glad som et barn på julaften om jeg får den.
Den er designet slik pga størrelsen - 5cm i diameter...Paganien var helt jævlig. Kroner fra Graham, subdials fra 60-tallet, visere fra Mondaine i en dressuraktig kasse med Og hva gjør de «mutterne» oppe og nede?
Er denne designet for de som bærer klokken på høyre arm?
... som i tillegg mht "U" (hva nå enn det symboliserer) står i hytt og pine...Og hva gjør de «mutterne» oppe og nede?
Da bår du ha ganske grove never for å ikke se ut som en dott. Men heldigvis er smaken forskjellig, og liker du klokken bør du gi beng i hva andre mener.Den er designet slik pga størrelsen - 5cm i diameter...Paganien var helt jævlig. Kroner fra Graham, subdials fra 60-tallet, visere fra Mondaine i en dressuraktig kasse med Og hva gjør de «mutterne» oppe og nede?
Proffen
Armer og never skal nok matche den greit.Da bår du ha ganske grove never for å ikke se ut som en dott. Men heldigvis er smaken forskjellig, og liker du klokken bør du gi beng i hva andre mener.Den er designet slik pga størrelsen - 5cm i diameter...Paganien var helt jævlig. Kroner fra Graham, subdials fra 60-tallet, visere fra Mondaine i en dressuraktig kasse med Og hva gjør de «mutterne» oppe og nede?
Proffen
