Technics Matsushita Electric Trading Co., Ltd
  • Laban MK3
    Plankebyen
    SL1200MK2 - 1979
    Between 1970 and 79 Technics developed a few more direct drive decjs including the first iteration of the SL1200 however it wasn't until 1979 and the MK2 that the range really came into its own. The staff started seeing DJ's using the original sl1200 as an instrument in clubs and disco's and so they developed the MK2 and took into consideration the needs of the DJ. It was the first of its kind that was made for home hifi but also catered to the pro audio scene. This was the turntable that really started the DJ scene and the basis of some of the most iconic hip hop music of all time
    Catering to DJs: SL-1200MK2 and MK3 (1979-1989)
    The SL-1200MK2 was a game-changer for DJs as it combined high-fidelity audio quality with features specifically tailored to meet the demands of club DJs and radio stations.
    Its direct-drive mechanism, high torque motor, and pitch control capabilities made it ideal for beatmatching and mixing tracks seamlessly.
    The MK3 version introduced further enhancements such as Quartz lock for improved rotational accuracy and a slip mat included to cater to DJ preferences
    Slik me ser det er SL 1200 serien et produkt levert i pro segmentet, det med Pitch kontroll har ingen ting med tilrettelagt DJ bruk å gjøre fra Technics / Panasonic.
    De aller fleste produkter i pro segmentet blir/ ble levert med Pitch kontroll +- noe prosent dette gjelder kassettspillere / spolebånd / platespillere.
    Det var nok DJ, n som oppdaget en solid spiller som leverer varene pålitelig gang etter gang og aldri noe tull.
    Surrehue
    TT.
    Surrehue
    Det var vel akkurat pitchen som gjorde at DJs ville ha akkurat denne spilleren, da de slet med Garrard SP25 mk og tilsvarende. Har du noengang prøvd å mikse med en slik Garrard, hvis så, så har du hatt en nærmest umulig jobb! Jeg regner da med at du har proffesjonell DJ erfaring?
    K.H.
    Trodde de dyreste ble laget i Japan.
    K.H.
    Litt rart, selv om den er forholdsvis rimelig.
    K.H.
    Når jeg tenker meg om prøvde jeg vel bare å erte litt. (Forholdsvis rimelig, altså sammenlignet med de virkelig dyre og gode sakene). Skulle kanskje heller ha skrevet at det skulle bare mangle til prisen du har gitt.
    Tullprat til side; jeg kunne faktisk tenkt meg en 1300 G for å sammenligne skikkelig med mine to remdrevne. Har prøvd før og da gikk det i favør sistnevnte. Men kanskje jeg bare var uheldig med min DD.
    Steinar.Sv
    Skal man investere i en Ortofon 2M 78 så man kan spille sine steinkaker på en 1210??
    Espen R
    Hvis det fortsatt finnes noen som klarer å høre på Steve Guttenberg (jeg klarer han i små doser innimellom), så har han lagt ut denne om 1300G vs. 1200G:
    Det interessante er jo at Guttenberg parkerte sin SME/SMV platespiller til $20k til fordel for sin Technics 1200G til 4,3k og har siden aldri sett seg tilbake. Han savnet heller ikke noen av de andre beltedrevne platespillerne han hadde, inkl Linn Sondek 12.
    Som en typisk audiofil som har levd på noen illusjoner, satt det nok langt inne å erkjenne at en «Dj platespiller» fra Technics danket ut et audiofilt prestisjeprodukt i ren spilleglede. Men sånn var det.
    Fikk meg til å tenke tilbake på 80-tallet hvor HiFi-politiet snakket ned direktedrevne platespillere, transistorforsterkere, metalldomer i høyttalere osv. Mytene var nok delvis drevet fram av nestorer i bransjen som ville beskytte sin egen butikk.
    Min audiofile oppvekst i tidlig tenårene var å lytte til musikk i timesvis på broderns stereoanlegg med Technics direktedrevet platespiller med S-arm, Sharp Optonica forsterkerier, og gode høyttalere. Those were the days…😘
    Laban MK3
    Plankebyen
    Vis vedlegget 1060527
    Jeg når ikke frem i det hele tatt :)
    K.H.
    Er tonearmen på Technics 1200 G like bra lydmessig som SME 309?
    J. Brünnhilde
    Evt. AT-VM95SP eller VM610SP. Sistnevnte er ferdig mono. De har begge et nåletrykk bedre tilpasset steinkaker enn 2M 78.
    Selvfølgelig: Har man en 2M allerede er det bare å bytte stift.
    Antinegativ
    Å Velstand, Velstand...
    Til steinkaker vil eg tru at VM670SP eignar seg betre enn VM610MONO. Til dei same steinkakene kan det vera ei stor føremon med regulerbar hastigheit, eller "pitch control" som nokon seier, då slett ikkje alle er meint å snurra på 78 omdr. Alt frå 60 til 90 er slikt ein kjem borti, så det er ikkje berre DJar som har nytte av ein solid Technics.
    Reaksjoner: TT.
    skranglefant
    Bartistan
    Ang pitch, så ble d ratta mye på min 1610 mk II når man skulle spille gitar til ymse LPer.
    Laaangt fra alt er stemt i 440 hz, så pitch-control har vært svÆrt nyttig for noen av oss :)
    Audiophile-Arve
    Ortofon Cadenza Black nå, men det kan jo endres senere. Hvilke pickuper mener du kan passe bra i Technics?
    Mine erfaringar med EPA 100 frå Technics er at armen er ganske fleksibel. Såleis trur eg dei fleste MC-ar (og ein god del MM) av det litt stive slaget går bra. Også Cadenza Black, reknar eg med.
    (Grunnen til at eg skifta til ein tangentialarm var mellom anna at EPA 100 og VdH-pickupen eg hadde då, ikkje var noko særleg, samanlikna med alternativet Vdh + ET2 tangential. Dessiutan er det langt lettare å forstå tangentialarmar enn det meste andre, og dei er lette å justere. Spesielt ET2 )
    Audiophile-Arve
    Då eg hadde gamle, gode SL 1500, brukte eg å "stemme" platene etter gitaren eg øvde meg på. Då eg fekk meg ein SL 1000 mk II miste eg denne fasiliteten, og måtte øve på annan måte... Men då hadde eg lært meg å apele litt utan "singlaong" og denslags...
    Audiophile-Arve
    Står ikke en EPA 100 på 1200G så vidt meg bekjent.
    Det er sant.
    Eg burde vel skrive at eg uttalar meg på spelarane til Technis frå 70-talet, dei moderne har eg berre sikla på, ikkje prøvd, Men om du skrur til den magnetiske dempinga på EPA 100, oppfører dei seg ganske likt. 1200 og dei andre slektningane kan heller ikkje justere VTA i farten, slik EPA 100 kan. (Må elles nemne at ET 2, Kenwood 07 og Kuzma har endå betre løysingar på VTA i fart, fordi dei kan låsast når du er fornøgd med justeringa)
    EPA 100 har nok også langt betre lagring enn dei billegare slektningane frå Technics. Om ikkje lagersteinane er knuste (om du skulle komme over ein EPA 100 med slark i, må nok lagera skiftast. Og det vert dyrt)
    Bjørn.H
    Både 1200G og 1000r har armør i en magnesium legering 9" mot 10". VTA on the fly med lås er standard fra GR og opp.
    Her finner man noen detaljer om SL-1200G tonearmen:
    https://1200s.com/products/complete-tone-arm-base-assembly-sl-1200g
    Her er et skjema fra ASR, som riktignok ikke sammenlikner resonans i tonearmen i SL-1200G. Men det som kan være interessant her er at en tonearm i magnesium er lettere, stivere og har mindre resonans enn aluminium. Det kan gi en pekepinn på kvaliteten på SL-1200G sin tonearm.
    K.H.
    Magnesium til tross, jeg føler meg ikke overbevist når det gjelder ytelsen på tonearmen i 1200 G. Har merket meg at flere anser nettopp denne som spillerens svake punkt. Noen velger også å bytte den i en annen arm. Har hatt innom et par Technics, bl.a 1200G en kort periode, og av en eller annen grunn ga de ikke samme solide inntrykk som f.eks Jelco og SME. Håper dette ikke stemmer da jeg sysler litt med tanken på å gi spilleren en ny sjanse. Et annet alternativ er å fortsatt holde meg til de utskjelte "strikkspillerne" og oppgradere til Luxman PD-191.
    K.H.
    Du har jo en annen arm enn den som sitter på 1200G og den har jeg ingen formening om. At Windfeld trivdes bedre i denne enn i de andre armene sier vel ikke så mye annet enn at det var en spesielt god match. Med en annen pickup kunne det kanskje vært motsatt, tenker jeg.
    Evo III
    Hertugen
    Hjemme
    En 1200 G uten arm hadde jo vært bøst, en SL-120G. Da snakker vi😁
    Itamar2010
    Btw, så har Technics sl-1200 mk4 også armrør i titan. Det samme gjelder min epa-501H armrør.
    TAF
    Ser i brukermanualen til 1200G, under vedlikehold, at det ikke er nevnt noe om smøring av lager/senterleie. Hva mener folket her inne?
    HasseBasse
    Hjortshøj, Danmark.
    Om det IKKE står i brukermanualen, da er det vel å betrakte som vedlikehold-fri.
    Om det står noe i Servicemanualen, er det = ikke for brukere men for teknikkere å foreta vedlikehold ;)
    Flageborg
    Det er enkelt å følge produsentens retningslinjer, men.......
    Audiofile har en tendens til å iverksette tiltak INGEN
    produsenter nevner i sin agenda......
    1. Alt som roterer må smøres
    2. Alt som krever strøm må renses
    3. Alt som basser må fanges i feller
    4. Alle additive komponenter forbedrer lydbildet
    99. Det er ingen grenser for tiltak uten faktisk virkning (y)
    K.H.
    Litt på siden kanskje, men nevner det likevel: I manualen til min Luxman PD-171 står det "Do not lubricate this unit yourself because special oil is used for the spindle". Jeg forstår dette slik at før eller siden bør lageret få noen dråper olje, men at dette bør utføres av fagfolk. Det innebærer i så fall at jeg må sende spilleren fra meg for å få utført dette forsvarlig med riktig olje. Hvor vanskelig må ting være, hvorfor ikke heller legge ved ei lita flaske med denne spesialoljen, eller i det minste oppgi typebetegnelse, eventuelt hvor den er å få kjøpt?
    Evo III
    Hertugen
    Hjemme
    Søker du på nett så finner du nok ut hvilken type olje du skal bruke😉
    Audiophile-Arve
    Dette var vanleg før i tida, og det er framleis praksis frå Nottingham . Kjempeenkelt vedlikehaldsarbeid. Ta av tallrk og drypp direkte på kula eller i eige hol til dette.
    K.H.
    Og Linn Sondek LP12....
    K.H.
    Har søkt og funnet Luxman sin anbefalte olje. Men den må skaffes fra Japan. Får ikke til å legge inn bestilling på mindre enn 4 liter, så det er uaktuelt.
