Lyngdorfs Venner!
  • Bjørn.H
    Det som er synd trist leit er at prisen på TDAI-3400 har økt en del.
    fry
    Jeg sendte lyngdorf spm om dette og fikk dette svaret ekstremt raskt. Imponert over responstiden:
    Thank you for your enquiry.
    The analog output of the TDAI-1120 was originally intended for connection of subwoofer(s), but many users do connect a separate power amp without problems.
    The noise level will depend on the connected power amp input sensitivity and the sensitivity of the speakers. The max output voltage from the 1120 is 4V RMS. Your power amp has a sensitivity of 980mV. This means that the volume control on the 1120 will operate mainly in the low settings - you can not turn up to full volume as you would overload the power amp. If we assume a digital source playing typical modern music, the level will be close to 0dB and the level on the analog output will be close to 4V RMS if you turn up to full volume.
    As most of the noise from the 1120 comes from the analog output stage, the noise will be fully amplified no matter the volume setting, as the volume is adjusted in the digital domain. So the only viable way of damping the noise is to use in line phono attenuators between the 1120 and the power amp. This will damp the signal and the noise, but as there is lots of volume range it just means that you will have to turn up volume higher to achieve the same SPL. This also means that you will have a higher level through the DA converter which theoretically gives a higher dynamic range and better resolution.
    I hope this answers your questions.
    Beretta67
    Det fungerte👍 rca attenuator virket ikke men de i xlr. Takk for tips og lån av attenuators av hornlyd😁
    fry
    Og var det da rca til xlr-kabel fra lyngdorf og inn i attenuatoren koblet til effektforsterker? Og er det 10db, eller 20db?
    fry
    Høres bra ut! Og billigere enn å bytte lyngdorfen, da er dette høyaktuelt mtp en aktiv to-veis i stedet for å begynne med minidsp.. Ser litt skummelt ut mtp vektstangprinsippet på inngangen, men en kort xlr-kabel bør ordne det greit evt.
    Beretta67
    Ja, skal lage noe kabel stæsj så det blir bra/ser penere ut osv👌 Ble litt sånn i hui og hast for å teste. Blir ikke noe annet her enn Lyngdorf på dette oppsettet mitt nå. Fungerer knall. Kjempe bonus og finne ut og få fikset susing også.
    Hornlyd
    Musikkglad
    Det var nøyaktig slik jeg tenkte.
    En ting er brum eller hiszz som er teknisk feil
    En annen ting er sus, da må gain struktur analogt eller kombinasjonen analogt/digitalt årnes på en eller annen måte.
    Nelson Pass sa at det var fint hvis volumknotten stod på klokken 1400 og ikke 900 når man spiller passe høyt.
    Hornlyd
    Musikkglad
    Gleder meg til å få fart i mitt 2240&1120 oppsett. Også tar jeg vare på min Nilai som har tre gain innstillinger sånn just in case 😉
    fry
    1120 har to mangler slik jeg ser det. Ingen digital ut (hodetelefoner) Og ikke variabel spenning på utgangen. Ellers er det en super pakke og eq-mulighetene er fantastiske. Når jeg tenker meg om ønsker jeg meg en ren pre med 3-4 kanaler ut og formfaktoren til 1120. Det hadde vært noe. Men uten hjemmekino-muligheter.
    Beretta67
    Hornlyd
    Musikkglad
    Du sier variabel spenning på utgangen? Ser at gamle miniDSP 4-10HD hadde en dip switch hvor man kunne velge lav eller høy gain (volt) UT pr kanal. Men dette er jo veldig uvanlig i HiFi verdenen å regulere gain i preamp delen på den måten. Det er jo på inngangen på effektforsterkeren man normalt justerer gain?
    fry
    Ja absolutt ikke vanlig, men veldig nyttig, spesielt når effektforsterker mangler muligheten. Mener å huske at tdai 2200 hadde dette der man kunne regulere utgangen i db. Og Wiim ultra jeg har har det fra 2v til 200mv.
    Harry Stoteles
    På TDAI-2170 kan en justere både digital og analog utgang opp og ned i steg på 0,1 dB.
    KMR
    Fyresdal
    Ganske sikker på att jeg kunne justere gain på line out på 1120, hvis det er det som menes her!? 🤔
    fry
    Men er ikke dette input man justerer ned da? For å få likt volum ut?
    KMR
    Fyresdal
    Ganske sikker på att det var gain til line out også. Då må jo være det for å justere gain på sub i forhold til høyttalere når du har deling.
